Question about Scotts Company Scotts& Accugreeen 3000 Drop Spreader 3 Pack
Setting for scotts speedy green 3000 for pelletized lime?
ProductdoctorX Pelletizedlawnlime granulated dolomite limestone: initial application 50-8- lbs per 1000 sq ft (no soil test taken) :
3 Suggested Answers
SOURCE: need spreader settings for Scotts Speedy Green 3000
I found this:
For 18-24-12 %50 PPSCU
Product Application Rate:
*LBS PER 1000 SQFT 4
Coverage:
* 12000
Craftsman 3
Craftsman Drop 7
Cyclone 4.25
Earthway 14.25
Lely 4.5
LESCO HD-1 7
LESCO R-94 7.5
LESCO Rotary (80# & 100#) 15
Ortho 3
Precision 6
Red devil 6
Republic 3
Scott's Accu Green 7.25
Scott's Easy Green 26.25
Scott's R7- X F.5
Scott's R8-A J.5
Scott's Speedy Green 1000 6
Scott's Speedy Green 2000 7
Scott's Speedy Green 3000 6
Spyker 4.5
True Temper 1500 \ 5000 5.5
Vicon 28
Posted on Oct 24, 2010
  • 25 Answers
SOURCE: I have a speedy green
listed below are the SpeedyGreen 2000 suggested spreader settings for lime:
(Please note that these are not exact measurements but they are close enough for lime applications)
30# per 1000 sq. ft. - Setting of 10
40# per 1000 sq. ft. - Setting of 7.5, go over the area twice
50# per 1000 sq. ft. - Setting of 7, go over the area three times
Posted on Mar 07, 2011
I need to know how much stone in tons I need to fill 8.5 acre at 1.5 ft depth
Stone is approximated at about 2700 lbs. per cu. yd.
An acre is 43560 sq. ft.
8.5 acres is 370260 sq. ft.
There 9 sq.ft. per sq. yd., thus there are 41140 sq. yds. in 8.5 acres.
A cubic yard is 3 feet by 3 feet by 3 feet (LxWxH).
Since you are only going to be at 1.5 feet, each square yard is equal to 1/2 cubic yard, so to figure the cubic yards divide sq.yds. by 2, thus you get 20570 cu. yds. of stone.
20570 x 2700 = 55539000 pounds. Divide by 2000 to get tons:
55539000/2000 = 27769.5 tons.
Nov 16, 2016 | Office Equipment & Supplies
I have a scots edge guard spreader and need to put on weed and feed at 4 lbs per 1000 sq feet what setting on spreader should I use
Hi Mike:
The setting will depend on the size of the weed & Feed pellets.
The package usually has setting instructions on it.
If all else fails, the rate is 1 lb per 250 square feet.
Mark out an area about 10 ft by 25 ft long.
The spreader cast is about 5 ft, so down and back should use 1 lb.
Set the spreader at a minimal rate and see how far 1 lb goes, then adjust the setting accordingly.
May 22, 2015 | Scotts Garden
Convert 30pounds per sq.foot to pounds per cubic foot(concrete=150#/cubic foot at 1in. thick conc. slab).
These are not the same, so cannot be directly converted.
Pounds per sq ft is a measure of pressure, while lbs / cu ft is a measure of density, weight per unit volume.
I think maybe what you are doing here is converting the weight of concrete in a 1" slab, where a sq ft would contain
1 x 1 x 1/12 = .0833 cu ft
The figure of 150 lb/ cu ft is correct for the average density of concrete, so the above slab would have
1/12 x 150 = 12.5 lbs/sq ft at 1" thickness
BTW that is a thin slab of concrete, insufficient even for a light-duty pathway. If you are referring to a screed for tiling or similar, that is cement.
Mar 01, 2015 | Office Equipment & Supplies
How do i convert 60 tons of ashpalt to square yards
AC is approx. 145 lbs per cubic ft.
there are 27 cubic ft in 1 cubic yard
60 tons x 2000 = 120000 divided by 145 = 827.58 cubic ft divided by 27 = 30.65 cubic yards
square yards would depend on thickness of AC.
you can take thickness x sq ft to get cubic ft
in concrete 1 cubic yard =
4 inch thickness = 81 sq ft or 9 sq yrds
6 inch thickness = 54 sq ft or 6 sq yards
Feb 16, 2015 | Heating & Cooling
Ez republic broadcast setting for expert gardener St Augustine Weed and feed for southern lawns
The bag should have a phone number for customer support. They would be the ones to give you the conversion rate for your spreader. How many square feet are you treating?
www.naturewestinc.com
Mar 04, 2012 | Earthway Ev - N - Spred Model 2050p Estate...
What are the settings for 5 lbs. 1000 sq ft on a scott speady green 2000
the low end od the stting bar is for 1/2 pound per thousand sq ft each mark adds 1/2 pound
Sep 24, 2011 | Scotts Lawn 73740 SPDY GREEN 3000 B/C S 3...
Republic EZ broadcast spreader...what number to use when lining up the mark to calibrate the spreader...lost the instruction book
Hello, to solve your question about what number to use to calibrate your broadcast spreader, please use the step-by-step instructions below:
1. If you don't already know the square footage of your lawn, please walk off or measure, multiplying the length by width. For example, my lawn is 100 ft wide by 100 ft long; this equals 10,000 sq. ft.
2. Use this figure (30,000 sq ft) to determine how much fertilizer, insecticide, fungicide,apply etc., to purchase and apply.
3. To calibrate the spreader for applying your product at the correct rate, first weigh and hold out an amount of product to cover a pre-determined test area; for example, enough for a 200 sq ft space.
4. Because most lawn fertilizers are packaged to cover areas in 1000 sq ft increments, it's easy to figure how many 1,000 sq ft applications you need for your lawn.
5. Set your spreader to 3 and measure 1/5 of the recommended application on your product, to cover a 200 sq ft area.
6. Use your spreader to cover this 200 sq ft area.
7. If there is product remaining in the hopper after walking this 200 sq ft area, increase the setting number and move to another test area, repeat steps 5 and 6.
8. If there wasn't enough product to cover the test area, back the number down, move to another test area, and repeat steps 5 and 6, until you finish with product and lawn test area at the same time.
9. Remember to never leave product in your hopper because many chemicals are corrosive and can destroy the moving parts, making the spreader inoperable.
I hope this helps!
Apr 02, 2011 | Garden
Can I use my dlx spreader to apply lime? How do I figure the setting to use. My soil analysis calls for 50 lbs per 1000sqft.
Yes, lime can be applied in the in the Scotts DLX spreader. for a 50# per 1000 square foot application rate it is suggested to use a spreader setting on 7 on you model, and to walk over the same area three times. If you have any further questions feel free to contact Scotts @ 1-800-543-8873
Feb 22, 2011 | Scotts Company Scotts Lawns Edgeguard...
I have a speedy green 2000 broadcast spreader and need to know what setting I need to use to spread 40 lbs per 2000 sq ft dolomite peletized lime? Thanks.
first 40lbs per 2k of lime will do nothing, rate to chemnge ph 1 point is 50lbs per 500k which would be all the way open slow walk. for your application you should be about half to 3/4 open normal walk
Feb 06, 2011 | Scotts Company Garden
Need spreader settings for Scotts Speedy Green 3000
I found this:
Coverage:
* 12000
Craftsman 3
Craftsman Drop 7
Cyclone 4.25
Earthway 14.25
Lely 4.5
LESCO HD-1 7
LESCO R-94 7.5
Ortho 3
Precision 6
Red devil 6
Republic 3
Scott's R7- X F.5
Scott's R8-A J.5
Spyker 4.5
Vicon 28
Jul 21, 2009 | Scotts Company Garden
Scotts Company Scotts& Accugreeen 3000 Drop Spreader  3 Pack Logo
757 people viewed this question
Top Scotts Company Garden Experts
john h
Nick Olsen
lnbn1975
Are you a Scotts Company Garden Expert? Answer questions, earn points and help others
