Question about Sony STR-DE625
RECIEVER TURNS ON THEN OFF FOUND BLOWN FUSE STR-DE625
RECIEVER TURNS ON THEN OFF FOUND BLOWN FUSEREPLACED THEN STILL HAVING SAME PROBLEM
    President:
  • Sony Master
  • 1,114 Answers
Disconnect all speakers, then test power. if it cuts off, your receiver needs serviced. If it stays on, Check all your speaker wires for shorts and connections at speakers. If they seem ok, re-install one speaker wire at a time and test power. once you find the speaker that's causing the problem, replace the wire and connect a different speaker (that you know works) and test again. If it cuts out, the problem is in the receiver and needs serviced. If it plays, put the original speaker on the new wire and test again, If it cuts out, it's a bad speaker or internal crossover depending on the model. Unless you are very proficient with a meter, this is the easiest way to check your connections. If you still have questions, post a comment and I'll help some more Hope this helps
Posted on Jun 23, 2009
PROTECT shows every time I turn my reciever on. It's a SONY model #STR-DE335
Turn it OFF. Look for shorted speaker wires or shorted speakers.
None found? Disconnect all speaker wires and try to turn it on.
Turns on ok? One of the speakers/cable pairs is shorted. Check them again.
No good? It's dead. take it to a tech.
http://www.retrevo.com/support/Sony-STR-DE335-Receivers-manual/id/387bh942/t/2/
Jan 08, 2011 | Sony STR-DE335 Receiver
The protector flashes STR DE625
Chances are it will need replacement parts (output transistors and a couple of resistors) Probably best left up to a repair shop tech.
Feb 01, 2010 | Sony STR-DE625
When I power the reciever on all i hear is a click noise and it does nothing else.
Check the main fuse if it is open (blown) it will probably need output transistors MP1620 MN2488, if not it may need the main power transformer.
DO NOT use a slow-blow fuse this will cause more damage to the receiver!
Oct 21, 2009 | Sony STR-DE485 Receiver
Need remote,"Sony AV system2", STRK740P
You need following remote for STR-K740P
clear_spacer.gif 147720411 RM-U306 REMOTE CONTROLand it is available, click Sony Accessories Store, for $35
May 12, 2009 | Sony STR-DE625
SONY HT-DWW1600. WHEN GETS NICE AND LOUD TURNS ITSELF OFF AND SAYS PROTECT ON THE DISPLAY. HELP!!!!!!!!!!!!!!!!
It is getting too warm and shutting down to protect itself. This could be caused by insufficient ventilation or by shorted speaker wires.
Feb 26, 2009 | Sony STR-DE625
Sony home reciever
If the problem was blown "output transistors" expect a cost of about $6-$8 per transistor (there are 4 total in the receiver) plus a few bucks for an emitter resistor and perhaps $2 each for the driver transistors (4 max per receiver). Also add in the local labor rate.
Please note that these are estimates and that additional parts may be required depending upon how smoked the output section actually is.
Dan
Mar 25, 2008 | Audio Players & Recorders
Protection error
Your speakers or the wiring to the speakers shorted out, and a fuse inside of your receiver is blown. You can purchase a new unit or attempt to replace the fuse yourself.
Nov 24, 2007 | Sony STR-DE425 Receiver
Sony STR-DE625 Logo
155 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
