Polycom Soundpoint Ip321 Ip-321 W Power Adapter Logo
A
Anonymous Posted on May 15, 2014
Polycom customer service contact
How to set this system up?
How to reset the password of polycom hdx 7000
You can use the hardware restore button on the Polycom HDX system to reset
the system in one of these ways:
• Restoring configuration-Restores the configuration, which resets most
system settings to default values.
• Factory restore-Completely erases the system and restores it to the
software version and default configuration stored in its factory partition.
If you follow this procedure while a USB storage device is connected, the
system restores from the USB device instead of the system's factory
partition.
The restore button is on the front of the Polycom HDX 9000 series system, as
shown in the following figure.
The restore button is on the front of the Polycom HDX 8000 series, Polycom
HDX 7000 series, and Polycom HDX 4000 systems, as shown in the following
figure.
The restore button is on the left side of the Polycom HDX 4500 system, behind
a wire mesh screen, as shown in the following figure.
Use a paperclip to press the restore button through the wire mesh covering
that side of the system. to reset the HDX Series system we can press the restore button over 15 second.
I need viewstation software! I have a system that has 3.x software, but I need to install 7.2.. where can i get 5.0 or a middle step software?? polycom does not show it on their website anymore.
I have looked all over trying to find this for you and you are correct, it is no longer listed anywhere, but Polycom definitely has it in their archives on a server somewhere.
Contact them at 1 925 9246000 and request the software, they should be able to email you a link to it.
All old links are dead / gone but it must still exist, they wouldn't just leave their customers hanging like that.
Tim
1helpful
Polycom SE225: my verizon line provide caller id does not displa
Due to the age of the SoundPoint Pro, it some of its features are not compatible with newer phonesystems, such as CableVision. There are no software updates for the SoundPoint Pro, and as long as the Caller ID is enabled there are no other settings or adjustments that can be made to workaround these kind of problems unfortunately. I recommend contacting your service provider to see what kind of caller ID signaling they are using; most likely they will be using a newer digital system, or MDMF which is not backwards compatible with SDMF or earlier CID receivers.
"Couldn't contact DHCP" error
Check on the router if you are distributing enough IP addresses.
2helpful
3answers
Polycom 7000 series System Settings
Web into the unit by it's IP address and go to "Home Screen Settings" and check "system".
MWI doesn't work on Polycom SE-225
The issue isn't exactly resolved. This appears to be due to an incompatibility of the Polycom Se-225 on our Meridian 1 phone system. But Converse handsets with MWI work fine. I have a partial solution by disabling the lamp (LPD on class-of-service), while leaving MWA setting. This allows the interrupted dial-tone when the user lifts the handset.
3helpful
2answers
Polycom ip501f error, application is not present
Make sure you have the latest BootROM and SIP config files for this polycom(sip.ld, sip.cfg, etc...) on your TFTP server. If you do not have this - download from here - http://www.polycom.com/support/voice/soundpoint_ip/soundpoint_ip501.html
If you do not have a TFTP server, you can download one for free.
I have a polycom 501 that is not working correctly. The speakerphone microphone is only recording static. This is as tested using the builtin diagnostics. If I record with the handset and then play with...
Best to contact your phone system provider, to determine if it is or if it still under warranty.These types of items are generally not user serviceable.
VSX 7000A connects domestically but cannot connect internationally
Please check with your Internet Service provider. They might have a firewall which blocks the ports used for video conferencing
Top Polycom Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Polycom Audio Player and Recorder Expert? Answer questions, earn points and help others
