Question about Frigidaire Affinity ATF7000E Front Load Washer
Affinity washer flashing EFO - Frigidaire Affinity ATF7000E Front Load Washer
  • Official Brand Answer
  • 2,267 Answers
Good Morning Friend,
I understand that your Frigidaire Affinity washer, model# ATF7000E, is flashing an EFO code. I do not show an EFO code for your appliance.
I do show an EF1 code, which means the drain pump is clogged. In this instance you would unclog the drain pump.
I also show an EF2 code, which means too much soap was used. All you would do for this would be to try using less soap.
It could also be a false error code. I suggest resetting your washer, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When you restore power, start any cycle on your washer. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Posted on May 17, 2014
3 Suggested Answers
SOURCE: Resolved QuestionShow me another » What
efo enter prblem what is the problem
Posted on Mar 07, 2010
blueextc3221
  • 15935 Answers
SOURCE: Affinity ATF7000E Front Load Washer: where do i find what efo means on my affinity wash...
Frigidaire, Zanussi, AEG, & More....
EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
1. there is a blockage in the filter or drain hose.takes too long to drain out.
2. over dosing of powder or liquid. again can cause an air lock in the pump which slows the drain pump down.
Check the filter and drain hose and test again. this fault will only come up at the end of a cycle.
You do not need to reset the machine to get rid of the fault code as this is automatically deleted.
Run an empty load with no detergent in an attempt to get rid of the code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Posted on Sep 16, 2010
EFO code cameup.
Its not EFO its EF0 .Theremust be some thing blocking the pump .For example socks,underwear etc. The water was not cycling through properly. Cleaned it out and everything works fine.Use proper detergent mentioned for your model because even SUD formation can cause this error.
Jun 18, 2010 | Frigidaire Affinity ATF7000E Front Load...
While washing the letters EFO flash. what does this mean?
If your washer displays EFO it means that you are not using HE detergent. You must have used too much detergent on a particular load.You have to use He detergents to fix this issue or else not using it will ruin your washer because regular soap makes too much suds.
Thank you!
May 28, 2010 | Frigidaire Affinity ATF7000E Front Load...
Flashes efo on display halfway through cycle
May 20, 2010 | Frigidaire Affinity ATF7000E Front Load...
May 16, 2010 | Frigidaire Affinity ATF7000E Front Load...
Error messages
Sep 11, 2008 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
I have a front loading washer and it was flashing an error code "EFO' What does that mean?
I just spoke with customer support for my Affinity. They told me it was over sudsing (sp?). from using too much soap or not using high efficiency soap. Suggested running thru a cycle without soap to clear things out.
Aug 09, 2008 | Frigidaire Affinity ATF7000E Front Load...
Flashing EFO error code
spoke with electrolux and they tell me that it is over sudsing problem. The washer must use HE detergent or use only a the lowest amount on the cup.
Jul 19, 2008 | Frigidaire GLTF2940ES Front Load Washer
Error messages EFO and E10
It is simple. The wrong soap or too much soap will caused EFO to flash. I overfilled the machine with soap by accident. It started flashing with EFO and I went nuts. What could be wrong with it now?! Too much soap or not the right kind of soap will cause this problem.
Plus, I found a sheet of paper that gives the codes.
This is better than when the strainer plug gets filled up and you have to take the machine apart to clean the little strainer.
Apr 16, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire Affinity ATF7000E Front Load Washer Logo
300 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
