Question about Briggs & Stratton Garden
24 hp engine. one bent push rod, second rod missing lost some power, no other problems
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 95 Answers
This happened to me,the engine sat for some time and the valves were varnished with stale fuel,they stuck in the guides.This bent the push rod and it was only running on one cylinder.The missing push rod worked its way into the crankcase through an oil passage . I took the engine sump of and found the push-rod. I cleaned removed the head,cleaned the valves and guides replaced push rods and gasket and it ran fine after that.I use fuel stabilizer now,it keeps the varnish from forming.
Posted on Jul 31, 2009
2 Suggested Answers
  • 21 Answers
SOURCE: 24 hp engine. one bent push rod, second rod missing
just found the same problem on my father in laws mower (24 hp briggs) I took the engine off of the mower, drained oil, turned on its side and removed lower case. There was the missing pushrod wraped around the camshaft gear. no clue on how in the hell it did that! It also ended up breaking the govenor (quick look) will look for more damage tomorrow.
Posted on Jul 27, 2009
Only getting oil in one side of valves ? 24 hp briggs, twin
clean all the passages i usually drain the oil and replace with diesel fuel run for 30 seconds drain and replace with oil sae30
Aug 31, 2012 | Briggs & Stratton Briggs Stratton Intek V...
24 hp engine. replaced head clinder now won't start
check the valve adjustment they sound to tight and the valves are not closing
Aug 23, 2012 | Briggs & Stratton Garden
My engine has loss power I have changed all filters and oil clean spark plug and have checked muffler. Still same problem What do I check next. Its a sear 17.5 hp lawn tractor
If it has a two cylinder B&S engine I would trying running it alone one one cylinder and then the other. This can be done simply by pulling off one plug wire starting the engine and then do the same with the other plug wire pulled. It is not rare to get bent valve push rods on these engines and a bent valve push rod will kill its cylinder causing lack of power. If it runs with one wire off, but not the other then you are on to the problem.
Oct 25, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 16 HP Electric start 41" mower - on a overhead valve briggs and stratton two stroke engine the hollow push rod bent. We pulled the head and everything seemed in working order. The replacement...
On any pushrod engine you have to make sure that the timing is correct or nearly correct when first firing it up, if you had the cam in the wrong position the pushrod had no place to go when the cam lobe came around=bend push rod.
Sep 24, 2010 | Garden
My 24hp Briggs and Stratton ohv engine has bent push rods on one side. The top valve can be pushed in but the bottom one will not push in. Is the valve stuck in the open position? If so how can it be...
unable to answer if valve opened or not but does sound like ur bottom valve is bent or piston made contact and bent it to fix need to remove head and replace valve also need to inspect piston face is not damaged from possible contact
Apr 12, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
While driving it there was a rattling in the motor then it lost power and now all it will do is turn over what do i do to fix it
This motor has a known problem for bending push rods.
RECOMENDATIN:
Check for bent push rods.
Change oil every 30 hours of operation or less.
Use a hi quality of oil only.
Hope this tip helps..
R/
David
Feb 02, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I have crafsman 48" riding mower with a 24 hp intek motor
Bent push rods are a function of the valve guide coming loose in the head. The valve binds and you end up with a bent pushrod. Fix: Replace head. $94.00
Jul 13, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Jun 23, 2009 | Briggs & Stratton Garden
My Biggs and stratton446777 rockers dont move as it spins over
you my have a broken rod pull spark plugs out and see if pistons are moving,if so check for bent push rods,if push rods aren't bent then you may have bad cam
Apr 28, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
1,241 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
