Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
Car cranks but doesnt start, replaced crack sensor and still crank but no start,what could be wrong?its a 2005 mercedes c240
I have a 2005 Mercedes c240 it cranks but will not start,replaced crank sensor and still have the same condition,what could be wrong
Display on my c240 mercedes Benz 2005 reads cannot check oil level. What is wrong?
unable because it is not on level ground? unable because sensor is bad???? unable because engine is running????
Apr 16, 2015 | 2005 Mercedes-Benz C 240
Car cranks but will not start
Maybe you're looking in the wrong area. You said it started to idle rough and kept shutting off. That could also be a fuel related issue. Possibly a clogged fuel filter or weak fuel pressure from the pump going bad. Check your fuel pressure. If you discover that the fuel pressure is correct, then make sure you have a strong blue colored spark from each coil by taking a good plug and plugging it into each coil while its out of the cylinder. Have someone spin it over and watch the color of the spark. A dull orange colored spark could mean bad coils or even the computer itself.
Dec 03, 2014 | Mercedes C-class C230 C240 C350 C55...
My 2005 c240 4matic suddenly stopped.After several tries it started but with engine light on please help
These cars are a bit sophisticated and only a guess can be offered without having some type of diagnostic equipment to read the code. If this happens when it is hot, but after it cools it restarts, chances are good it might be the CKP(crank position sensor). It is a common failure on these engines(M112 V6). It is best to have the code read and go from there.
Oct 10, 2013 | Mercedes-Benz C-Class Cars & Trucks
I have a Mercedes benz c240 sport v6 engine the car starts up fine and then when it reaches temperature 80 degrees the car cuts off.
Seems a common fault i have had with these cars ,try changing the crank and cam sensor ,you will not get a fault light but one or the other could be breaking down when its gets warm .
Aug 22, 2013 | Mercedes-Benz Cars & Trucks
I have a 2004 mercedes c240 and have a new crank censor to install. Where is the censors location on the 6 cylinder?
Pretty sure the sensor is on the top of the gearbox bellhousing, and picks up its pulse from the flywheel on this model, its held in by allen bolts and is easiers to access from underneath the vehicle ( just above starter location
Sep 19, 2010 | Mercedes-Benz C230 Cars & Trucks
2001 mercedes cl500 wont start...cranks but wont start. Happend while sitting in the garage. The car earlier in the dat ran fine
Open the air cleaner or intake hose and while someone is turning it over spray some ether into it with no more than three second bursts. If it cranks then you have a problem with fuel delivery and if it doesnt you are looking at something with the spark or ignition.
Apr 10, 2010 | 2005 Mercedes-Benz Mercedes Benz CL500
My 2002 C240 will not crank
merc 220 wont turnover.new battery ignition lights come on then turn key nothing happens?
Jul 12, 2009 | 2002 Mercedes-Benz C-Class
How to installl it and how to find it
Its buried deep within the bowels of the engine! just below the cylinder head. hard job buddy! Easiest thing to do is buy a hanes manual for about €20
Apr 27, 2009 | Mercedes-Benz C-Class Cars & Trucks
2005 Mercedes C240; looses power and check engine light comes
better to bring your car to dealer to avoid replacing part.,better to check air mass sensor or idling actuactor.
Feb 10, 2009 | 1995 Mercedes-Benz C-Class
Heating & Cooling Logo
22 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
