Question about Zebra Office Equipment & Supplies
Why won't my zebra 450 ctp will not stay calibrated?
I can go all day with my zebra 450 printer working just fine, or it will print 1 label and then a blank label. It is wasting allot of labels. What can I do to fix this. I have tried calibrating it, but it won't stay fixed.
itdude4321
  • 13 Answers
SOURCE: Zebra S600 printer continues calibrating
The factory default settings for the S600 is to auto calibrate every time the printhead is closed and every time the power is cycled. If the media sensor is not positioned correctly for the media you are using the label size will not be detected during a calibration. You mentioned the media has no markings, doe sthe media have a space between the labels? If so, the media sensor may not see the gap in the labels adn therefor is not calibrating properly or not calibrating at all. Check the media sensor position. I have found that the media sensor must be at least 1" from the inner wall of the printer so it doesn't see the edge of the backing in oder to read the size of the labels.
Posted on Feb 02, 2008
  • 5 Answers
SOURCE: Printer = Zebra TLP 2844-Z Problem = will not calibrate
just switch off the printer ,and then hold the green button power on the printer now and wait upto 4 bliknks of green led then remove the fingers.now printer will calibrate the label..
if still the problem exist .check the notch in the ribbon core.an adjust the spring tenson of rippon supply and take of roolers in printer
Posted on Dec 05, 2008
jwr1914
  • 31 Answers
SOURCE: Zebra Z4m calibration doesn't work with different labels
You need to run the internal media sensor calibration setup that is built into the menu. This can take a few minutes but will solve this problem. The machine needs to be setup for the media you are running. This is no fun if you have to change a lot during a day and each media type has diferent qualities. It ususually happens when you are using labels from one manufacturer and then switch to a diferent brand. The backing material has diferent characteristics that the machine needs to be setup to be able to handle.
Posted on May 27, 2009
  • 31 Answers
SOURCE: I have a zebra TLP 3844-Z printer. My printer
Sounds like it is set to do a label length check at power on. Go into your printer preferences and set it to "do nothing" on power up.
Posted on Jun 27, 2009
SOURCE: Zebra printer is printing two copies when only 1 is checked
Same problem exactly and was not able to get a response from UPS or the zebra company, someone please help!!!!!!!!!
Posted on Aug 04, 2010
My zebra tlp 2824 won't line up to the labels
Either your printer needs calibrated: Calibrate Zebra Desktop Printer
Or your label template size( in the software) does not match the label size. I recommend the calibration then looking at the software label templates.
Jan 20, 2014 | Zebra Eltron LP 2824 Thermal Printer
On the Zebra it was printing 4x13 labels without a problem. However when I tried to print a 4x6 label it still thought there was 4x13 stock in the printer. I played around with the label format size, even...
I think this is more related to the calibration of the label each time you change the new label size. I use ZM400 and your printer should also have the same setting. Under setting, put the When Head Close setting to Calibration. This will let the calibration perform automatically when ever you load a new label size and close the print head. Well 2 label will be lost every time.
Aug 31, 2011 | Zebra 105SL Thermal Label Printer
I have a Zebra 2844 CTP printer: Recently changed from 2x1 hard labels to 2.25x1.25 sticky labels, and now my printer will not print my category on the label, and I get an additional blank label printed,...
The printer may need recalibrating.
Switch off - hold down feed button and switch on when indicator flashes release button.
Printer will fedd then print a configuration label. Should now be OK
Jun 03, 2011 | Zebra Eltron TLP 2844 Thermal Label...
I have a Zebra Z4M printer. We use it to print on various labels - pre-printed and blank labels (semi-gloss). I've been struggling to print on one of the pre-printed labels. Everything else prints...
some labels are hard to calibrate, nee to calibrate the sensors with manual calibration.
1} go to the MEDIA AND RIBBON CALIBRATION,
2}take 2 or 3 labels from the base paber, load the way to the based paper stay unther the sensors, 3}close printhead.
4} press ok.
5} Move the ribbon out from sensors and close the printhead.
6) press ok
7) wen printer ask RELOAD ALL, load the labels correcly and the ribbon, close the printhead and the top door, and press ok. The printer run the calibration it self.
wen finish, saved (press setub twice) and test.
Jan 21, 2011 | Zebra Z4M Printer
I have a Zebra ZP 450 and I use the standard sized UPS labels (4x6). I cannot get the labels lined up properly - that is to say, this printer will always print the address on two separate labels,...
there must be a label gap sensor in there somewhere. see if you can find it in the label path and clean anything you see off of it. does this printer have a calibrate function? if so do that after you clean the sensor. here are the calibration instructions from zebra https://www.zebra.com/us/en/support-downloads/knowledge-articles/zp-series--calibrating-the-printer.html
Jun 01, 2017 | Zebra Office Equipment & Supplies
LOOKING FOR LABELS FOR ELTRON-ZEBRA 2844 CTP UPS THERMAL PRINTER
If you are printing UPS labels, call UPS and ask for some. They will give them to you for free!
Aug 24, 2010 | Zebra TLP 2844-Z Thermal Label Printer
I have Zebra LP 2844-Z printer and the barcodes
Here are 3 suggestions.
Check that your label size definition is correct, measure your label height in mm and check that your printer driver settings match.
Perform a calibration. How?? when printer is on labels loaded and green light, hold feed key and wait for 2 blinks then release feed key. (If you release it after 1 flash you will print a configuration label)
If you are using Zebra Designer, download latest version of Zdesigner V2. Install latest printer driver V2.63. This driver & Zdesigner allows you to calibrate the printer directly from within Zdesigner. Go to File/Printer settings/ advanced options and click calibrate at bottom of page. when printer calibrates then tick the box USE PRINTER SETTINGS and printer will now work properly.
Jul 01, 2010 | Zebra LP 2844-Z Thermal Label Printer
Problem with my Zebra LP2824 printer
You have to calibrate the printer to solve this problem
Check following to solve this problem
1)Press the feed button and hold it for 1-2 seconds switching printer on.It will calibrate the labels.
2)Install Zebra Designer driver from CD.After installing Zebra designer Add printer Zebra Designer LP2824.After installing driver right Click the printer Zebra Designer LP2824 and go to printing preferences then select advanced option and calibrate printer.It will calibrate printer
3)Check the label size is properly set in printer or not.Label width and label height in printer settings should be same as label which you are using .
Aug 22, 2009 | Zebra Eltron LP 2824 Thermal Printer
Zebra stripe s500 skips 5 labels prints 1 skips 1
He are the steps you need to calibrate your printer
Label Length Calibration
Note: This is typically the only procedure required when first installing the labels.
1. Load the printer with media and ribbon.
2. Press the printer front panel MODE key until the CALIBRATE LED is lit.
3. Press the FEED key and allow the labels to feed.
4. When the labels have stopped press the MODE key once to save the value in memory.
Jul 10, 2009 | Zebra Stripe S500 Thermal Label Printer
177 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
