Question about Brother MFC 490cw Color Inkjet Multi-Function Printer
How to repair Brother printer MFC-495CW machine error32
  • 286 Answers
SOURCE: Brother MFC-5440CN Printer Problem
If this only happens when you are copying.
1. Your scanner glass is dirty. Open the lid, use windex to clean the flatbed. Look on the left side. You should see a strip of glass, with the scanner sitting under it. This strip is used when the document feed is being used. Make sure it is clean. Most common problem is getting a little whiteout or the sticky residue from scotch tape on this glass, which causes lines down your copies.
Clean it with alcohol which will dissolve the sticky stuff and the whiteout.
If this does not solve the problem, the CCD scanner in your machine might be going bad.
Posted on Dec 30, 2007
  • 7 Answers
SOURCE: "brother mfc 7840w printer goes offline and i cannot print need turn printer on and off.
The solution, and it took me a long time to find the simple solution, is to right click on your printer, click properties, click the ports tab and click on your Brother printer and click on configure port (or you can delete the existing one and then add another one). What you want to do is update the IP Address. The problem is that the printer does not have a static IP address, it is dynamic. If you want to confirm that, go to your printer and press the reports button and print out the network configuration report. Your IP address will show on that. It's really the last digit in the IP address that changes. This will absolutely solve your problem. Good Luck!
Posted on May 17, 2009
  • 583 Answers
SOURCE: machine error 46
Here is the answer to the Machine Error 46 (have just fixed my own MFC210C):
Machine Error 46 – Purged Ink Box Full MFC620CN/420CN/410CN/210C and FAX2440C
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An “initial purge”, for example, advances the purge counter by 187 + 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unuseable.
When an internal Machine Error 46 is generated, the user will see an “Unable to Clean” external message and will be unable to use the printer. The “Unable to Clean” external message can relate to many different internal error codes however.
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
If there is a Machine Error 46, it is necessary to dismantle the printer, replace the ink absorber box (or possibly break the ink absorber box open and clean its absorbent sponges under a tap), re-assemble the printer and reset the purge counter to zero.
Resetting purge counter MFC620CN/420CN/410CN/210C and FAX2440C
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Carry on printing !!
thanks.
Posted on Jul 08, 2009
pineworks
  • 4041 Answers
SOURCE: problem paper jam printer brother no mfc-490cw
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 27, 2010
  • 159 Answers
SOURCE: Have Brother MFC-495CW, and I recently changed
It's not your ink. Error 36 means either the printhead carriage is unable to travel back and forth properly, or it does, but the machine can't get the proper feedback from it. It might be an easy fix, once you get the top cover off the printer section. (Start by prying the narrow covers out of the main cover, then unplug the cables under those covers.) Often it's a small scrap of paper that got into the path of the head. If so, it's probably black with ink and hard to see, but fishing it out with tweezers should fix it.
The machine keeps track of where the head is by counting nearly-microscopic stripes in a quarter-inch strip of film that runs across the printer section. That strip should be oriented vertically and sitting in a slot in the head. If it's stretched up across the top of the head instead of down in the slot, the head can't see the stripes and panics, giving the error 36. Gently lift it and drop it into the slot. If it's smeared with ink, gently clean it with a wet cotton swab.
Posted on Apr 07, 2010
Cannot clear memory on brother mfc 495 cw
go to the printers and devices near the control panel of the computer , click on printer and see what is printing
cancel any task pending not completed
Sep 30, 2016 | Brother 495CW MFC-495CW Copier/Fax...
How to change printer head on brother printer mfc-495cw
Do not try it on yor own unless you are a technician. Too many parts must be removed and counters have to be cleared and programmed. You might try calling brother, they will cover printhead replacement on certain models. Call 1-877-brother.
Feb 17, 2015 | Brother MFC-495cw Color Inkjet All-in-One...
How do you remove mfc-495cw printer head
This is a common problem with Brother ink jet units. Cleaning the head will not fix the problem. Call Brother at 1-877-brother and tell them your unit is "missing black" on prints. They will probably cover this problem under a special warranty for this problem at no charge to you.
Sep 04, 2012 | Brother Mfc-495cw
How to remove brother mfc 495cw printhead
You can download the manual here: <a href="http://www.pdfsnatch.com/2013/05/brother-mfc-495cw-manual/">Netgear n300 manual</a>
May 14, 2012 | Brother MFC 490cw Color Inkjet...
I installed a new black ink cartridge(lc61bk) on a brother mfc-495cw and now nothing is printing.
Check out if you've installed it correctly. Also check out other ink cartridges, are they empty? If yes you won't be able to print anything. However, if all ink cartridges are OK then try to reset the printer or reinstall the drivers. You can find help in MFC 495cw users manual
Feb 27, 2011 | Brother MFC 490cw Color Inkjet...
My brother mfc 495cw keeps giving an "unable to init." error message. chris.iya@lausd.net
Hi. my machine model MFC 495 CW. I did any step but my machine till show up unable to Init. 4 F. please can you help me about that. thanks you very much
Tien
Sep 07, 2010 | Brother MultiFunction Center MFC-440CN...
My Brother MFC-495cw will not print. It pulls paper through but nothing prints.
This is due to the ink...Check you ink cartridges if they are still full of if the ink has dried out thats wht printing is not working
Jun 11, 2010 | Brother MFC 490cw Color Inkjet...
Wireless printer problem
Brother has posted a Network Connection Repair Tool on their site under downloads. Worked great to put my MFC printer back on line with my network.
Mar 28, 2010 | Brother MFC 7840W Printer
My Brother MFC 495 cw scanner won't work
Hello i just bought a Brother MFC-495CW printer and for the life of me cannot get wireless to connect even though i have setup everything correctly as far as i know. Any help would be appreciated.
Dec 16, 2009 | Office Equipment & Supplies
Brother MFC 490cw Color Inkjet Multi-Function Printer Logo
19 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
