Question about Karcher Plumbing
Karcher de 4002 - Karcher Plumbing
My karcher isn't giving me hot water why? It's a hds 601c
Morning Chris Taylor,
You have an igniter/burner coil inside your system that has to be
functioning properly to have good combustion going inside the coils of your heater unit (very bottom).
I tried to pull the documents to see if yours was kerosene powered (like mine: not a Karcher)... but could NOT pull your HDS 601C up on the company site (Karcher.com, sorry... It's me & my new PC).
Poor water = de-lime water coil procedure
Cool water = No combustion, check kerosene, oil (burner fuel)... filter... (etc.) and check your spark!
If your air supply is insufficient to support great combustion your ignitor & fuel nozzles can get heavily built up in soot. My manual says to clean it with detergent & water... I have only ever used Berryman choke & throttle body cleaner.
All the precautions... don't hurt yourself!!
Hope this helps...
KARCHER HDS 601c ECO STEAM CLEANER BOILER HEATING COIL ELEMENT HEATER...
Operating manuals
http://www.ultimatewasher.com/download/hot-water-manual.pdf
May 01, 2016 | Karcher Garden
When turned on blowing fuses
Short circuit inside machine. In a device typically resulting from the unintended contact of components and consequent accidental diversion of the current.
May 03, 2015 | Karcher DE 4002 Commercial Steam Cleaner
Karcher pressure washer won't switch on.
revisa el cable de corriente, verificado esto.. puede ser la tarjeta quemada
Oct 11, 2013 | Karcher K 3.98 M Electric Pressure Washer
QUE TIPO DE ACEITE USA LA KARCHER GC160
tengo una maquina honda gc160 5.5
modelo g2600 vh con seria 152 428
Jun 29, 2011 | Karcher 2500 PSI Pressure Washer
Is there a reset button on the karcher de 4002
open the lid and you will fine a red button with a clear rubber cover
press that button. When you have to reset, it is telling you that you need to descale the unit
Jun 15, 2011 | Karcher DE4002 Steam Vacuum
Whare can i get a pump head for a karcher hds 1000 de
I work for one of the top Karcher dealers in the US and we can get this part for you. Visit our website at www.landanw.com for contact info or call 800.247.8103.
Sincerely,
Aron Kerr
Landa Northwest, Inc.
www.landanw.com
Feb 26, 2011 | Karcher 2500 PSI Pressure Washer
Mi maquina luego de varias horas de uso la presion bajo totalmente . mi maquina es una excell de la honda modelo vr2522
Dispense porque mi espanol no es muy bueno aci como usted. El presion comiensa con el nozzle. Nozzle debe de ser el que fue hecho para la machina. El nozzle debe de tener el numeracion de gallons por minuto marcado. Su machina sera marcado con (gpm) gallons por minuto. 2.5 or 3.0 or 3.5, Y si el abuhero de el nozzle es muy grande, no va tener presion. Tambien, no debe de tener agua tirandose de connections. Y se el presion es muy bajo con el correcto nozzle, va a tener que combier partes adentro de la pompa. Y si ya tiene bastantes horas corridas, sera mejor combier la pompa entera.
Nov 10, 2010 | Karcher 2500 PSI Pressure Washer
Where do i get replacement gears for this schredder?? dertroyit 4002 thanks
I have a Destroyit 4002 cross cut paper shredder. I have ordered parts twice from shredderparts.com
Both times they were friendly and sent me the correct parts.
Jun 12, 2010 | Destroyit 4002 SMC Shredder
KARCHER HDS 1000 de
Hi Jim,i have the same unit to,can you tell me are you connecting to mains water via the small black header tank at the back next to the boiler or is it connected straight to the pump head inlet?
Theres more than one reason i'll just start with this one 1st.
chris
Aug 08, 2008 | Karcher 2500 PSI Pressure Washer
Plumbing Logo
22 people viewed this question
Top Karcher Plumbing Experts
Paul Carew
obsteiner
JOHN BROWN
Are you a Karcher Plumbing Expert? Answer questions, earn points and help others
