Question about Amana Easy Reach 18.1 cu. ft. Bottom Freezer Refrigerator BR18V
Refrigerator model BR18 has a defrost problem, have removed the back panel in the freezer and melted the ice, now what?
  • 351 Answers
Well there is a few things to check like defrost thermostat, timer or heating elements, give me a call and i can walk you through it for free..whirlpoolpartssurplus.com
Posted on Jun 23, 2009
Refrigerator won't cool
seal on door must be letting moisture into compartment, need new door seal
Aug 20, 2012 | Kenmore Top Freezer Refrigerator
Ice has formed on the bottom of the freezer about 1/4 inch thick. Refrigerator section is hot.
Most likely the cause of your problem is a faulty defrost system. The ice is building up on the evap coil in the freezer, so the air from the fridge can't get cooled by the coil. The common failures are the defrost heater burning out, or a defective defrost timer if yours is an older model. The heater is mounted on the coil. To get access, you will need to remove the back panel in the freezer. There you will find the coil and heater. You will need to use a hair dryer to melt the ice off the coil.
Jun 30, 2011 | Kenmore Top Freezer Refrigerator
GE model # GSS25JFPHWW looking for the defrost timer on this one is it behind the ice maker in the freezer
Defrost is controlled by the mother board, behind small rectangular panel on back of refrigerator. Part # WR55X10942 . (you can not use the board to manually defrost) If you are having a defrost problem, the most likely cause is the defrost heater (WR51X10055) and while you're at it, you might as well replace the defrost thermistor (WR55X10025) located at the top of the cooling coils. Manually defrost freezer by unloading freezer, removing shelves, and removing back panel inside freezer, then use hair dryer to melt frost. (you have to take those parts off anyway to get at the heater and thermistor)
Mar 31, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator not cooling-Freezer Coils Freeze Up & Don't Defrost
check the fan assembly theres not enough air flow going over the coils
Feb 11, 2010 | Maytag MBB2254G Bottom Freezer...
Amana refrig refrig wont get lower than 42 degrees
that is defrost timer every 8 hrs it turns on heater to defrost evap coils, unless there is major ice behind freezer panel after 1 day which i doubt, that would not be problem ...im trying to go through steps i would take as tech at your house
Jan 03, 2010 | Amana Easy Reach 18.1 cu. ft. Bottom...
The freezer drainage
you have a clogged defrost drain, remove the bottom basket, and freezer shelves to expose the screws for the back panel remove back panel,carefully chip away ice, and or use boiling water to melt the ice from the drain hose, check complete drainage by removing back panel behind frige at bottom and inspect that the water is draining completely into defrost pan. reoplace all parts.
Aug 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice melts water drips out of icemaker & freezes in a column
If your model is doing that I would consider looking at the defrost components. Look inside back of freezer for frost building a thin layer on the rear wall. If yes then unplug and remove the rear panel in back of freezer and defrost with a hair dryer. You have and air circulation problem or a defrost problem. Sounds like it's trying to defrost but we need to have a look at the evaporator coils in the rear behind that cover. First let me know what you find and we will go from there, Thanks Sea breeze
Aug 17, 2009 | GE Profile PSW26P Stainless Steel Side by...
Freezer not working
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 17, 2009 | Viking Professional VCBB363 Bottom Freezer...
Model 501-64822 is a self-defrosting Kenmore that is building up ice in the freezer and then somehow melting and running down the inside of the fridge and onto the floor.Any suggestions??
Hi, Look that model # up again please. The problem you are having is the defrost drain is plugged. Remove the rear panel inside the freezer and melt all the ice. Locate the drain hole and flush it out with hot water. Some modles need an after market drain heater kit. Get me the model # and I can look this up for you.
Vic
Jul 04, 2009 | Kenmore 64802 Top Freezer Refrigerator
unplug appliance, melt ice on back of freezer, remove panel rear of freezer, find leads to defrost heater and test with a multimeter, if you have condinuity replace defrost termostat, if no condinuity replace defrost heater. after removing panel you will have to melt ice in rear with heat gun before testing.
Jun 22, 2009 | Admiral Refrigerators
Refrigerators Logo
307 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
