Frigidair lra127ct1 I just put my A/C in the window from being stored all winter in a cool dry area in my finished basement.I plugged it in it beeped and the screen on the A/C/lit up for a second and went out now nothing i tried resetting the reset on the plug and nothing
  • 11 Answers
SOURCE: treo 650 won't turn on
Could be a dodgy power connection this seems to be happening a lot at the momentif you look at other threads here.
Kevan
Posted on Nov 18, 2007
SOURCE: Frigidaire Tumble Action Washer - lights flash, beeps, does nothing else...
If you have had a lightning storm or power surge it may have fried the electronics panel. That is what happened to mine. Once it is fixed you should put a surge suppressor on it that is rated for major appliances.
Posted on Apr 27, 2008
hemantraj
  • 638 Answers
SOURCE: Frigidaire AC Window, Model # FAC107P1A2
you have clearly mentioned in your question itself that electrical cord does have power going into the unit.i feel it may be the problem with your power cord wire . try replacing the cord first and check whether the power reaches the unit.
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
Posted on Jun 29, 2008
jbjaxiis
  • 95 Answers
SOURCE: GFI plug trips when pluged in, no reset
You are trying to draw too much power from the dedicated electrical line, or you may have an outlet that is needing replaced. Try to use another plug, in another room to test
Posted on Jul 21, 2008
  • 534 Answers
SOURCE: when i plug in my frigidaire fac125p1a the reset
compressor has gone to ground. In other words the reason the reset button trips is to prevent any electrical shock due to the compressor going bad. Only way to fix this is to have the compressor replaced
Posted on Jul 16, 2009
User guide or manual for frigidare 12,000 Btu window air condition model number lra127ct1
Here is a link to the manual. http://manuals.frigidaire.com/prodinfo_pdf/Edison/2020211a1417en.pdf
If the link does not work leave me your email address and I can send you a copy of the pdf file.
Sep 13, 2013 | Heating & Cooling
End of cycle keeps beeping even after clothes are finished and removed
this could range from a simple processor hanging problem to a defective pcb
please start from a hard reset by leaving the unit plugged off from wall power for one night
Jul 30, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire Air Conditioners make alot of noise when running
Hi James - Thank you for your question! I am happy to assist you. I understand you stated it sounds like a bad bearing, however may you please describe or me more specific in the particular noise the air conditioner is making? Does the noise occurred at all times? With this information I can better address the issue at hand and provide you the most accurate information. Thank you and I look forward to your response.
Jul 18, 2013 | Frigidaire Heating & Cooling
Frigidaire Freezer acting goofy
Make sure everything is clean of debris and I would personally see if you could cool the area around the unit. Maybe use a fan or turn the air down in that room. Humidity and hot temps kill a unit's sealed system.
Jul 24, 2012 | Frigidaire 21 cu. ft. / 595 liter Upright...
Hello there, I have a split entry home with a finished basement. I was wondering: on nice warm days, with a wind blowing through the upstairs, if I can leave my windows open upstairs while the...
Connie, it will only work if all of the interior doors to the basement are closed during this time. Even putting an old towel at the bottom of the door(s) leading to the basement will stop the air flow.
Hope this helped you and thanks for choosing FixYa.
Aug 23, 2011 | Dehumidifiers
MODEL DM 162EBS. Why is it when I switch my dehumidfier on 10 minutes later it goes to defrost. [ WHY?]
Let's think thru the dehumidification process--
A dehumidifer needs to create a COLD surface, on which to condense the moisture in the room.
If your room is quite cool, it is esily possible that the COLD surface can go below freezing-- Now the water is trapped in the ice-- So-- it has to defrost, to melt off the ice, and start all over again!
Can you move the Dehumidifier to a warmer spot-- maybe near a radiator, or a heat register? -- You will remove much more moisture in that way, too..
Just a question: Most homes are WAY TO DRY during the winter months-- are you sure you need to dehumidify your living area? (Maybe you are drying the basement?-- or a wet area?)
Just seeing if I can help
Mack B
Jan 20, 2011 | Dehumidifiers
Air conditioner won't stay on, rapid cycles, beeps and turns off
mcdevito75 Here, It should be service, Look online for an A/C shop in your area, could need claening, Freon ETC. should be done every 1--2 years.
Jun 23, 2010 | Maytag M6X08F2ACOM Air Conditioner
Clothes come our smelling bad
Run a load empty on the hottest setting with a cup of bleach.
Then, after finished using the machine each day, leave the door open for a few hours to allow the rubber seal to dry.
Jun 30, 2009 | Zanussi FLA1001W Front Load Washer
Frigidaire Model FSE446RHS shuts off mid cycle
Hi, If the motor is shutting down mid cycle and can not be restarted untill cooled, the motor will need changed. It is shutting off on a safety overload. These motors cost about $145.00
Please let me know if I can assirt you further.
Vic
Jun 01, 2009 | Dryers
Works well but
Yup, they eat energy.
An electric dehumidifier includes a refrigeration cycle that is very similar to a window AC units and refrigerators. They cool the air in the basement to condense and collect water and remove humidity, heat the air as a required consequence of the refrigeration cycle and dump it back to your basement.
Two sources of humidity in basements include warm outside air that naturally cools due to below grade earth contact and water passing from the ground though the floors and walls and evaporating into the basement. Dehumidifiers do most of the work in the summer when higher temperatures outside enable air to hold more water content.
In the winter, cooler outside air contains less moisture by weight eventhough it may be raining and the relative humidity in basement will be less because the air is warmed relative to the outside. The lower moisture content in the winter also absorbs the water passing through the walls and floor.
From an energy perspective, you may want the humidity set NOT below 50%. This will keep humidity below the level mold desires, but prevents the dehumidifier from doing more work and eating more energy than needed. A cheap battery powered temp/humidy meter left in your basement will help. Sources that include the "mold triangle" (temperature, water & food) often separate fact from expensive hype.
If the dehumidifier doesn't keep up, consider adding a moisture barrier to the basement walls and floors such as Dry-lock and floor paints to ****** moisture entry. Moisture barriers act very similar with water as insulation does with heat. They don't eliminate the need for a dehumidifier, but they reduce the work they do and energy they eat.
Oct 02, 2008 | DeLonghi DH40P Dehumidifier
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
