Question about Whirlpool 24 in. GU2500 XTP Built-in Dishwasher
My pots and pans and normal light is blinking how do I reset
3 Suggested Answers
  • 2516 Answers
SOURCE: the pots and pans and the normal light blinks but
most likely you have a bad touch pad,you can first try this,shut the power down to the dish washer,open it up and unplug the ribbon from the touch pad that goes to the control board,unplug it off of the board for 5 minutes and then reconnect it the same way it came off and then run it and see if it repaired it,if not you'll need a new touch pad.hope this helps,one more thing,on the back of the kickplate or bottom panel has a tech sheet on the back of the panel,you can check it with the diagnostics to see what part is bad but most likely it will be the touch pad.good luck with your dish washer.
Posted on Oct 21, 2011
  • 16 Answers
SOURCE: pots and pans and normal lights blinking
That reset sequence code didn't work for me. We tried everything on a ton of forums.
What I did to fix our Whirlpool dishwasher was to disconnect the drainage tube from the garbage disposal. I noticed it smelled really bad so I figured it was clogged. I used a bucket to catch the water left in the tube. I took the sprayer from the sink and flushed out the tube. 4 pumpkin seeds and a couple of beans landed in my bucket. I flushed it a couple times. I hooked the tube back up to the disposal and sure enough all the lights returned to normal. I pressed start and it came on.
Posted on Nov 16, 2011
The pots and pans light and normal light is blinking
Kenmore Elite Dishwasher blinking light Control Board FIX ...
? 1:37
www.youtube.com/watch?v=flzhfmIIYpM
Apr 14, 2011 - Uploaded by MegaHowtoMan Kenmore Elite Dishwasher blinking light Control Board FIX ....year old washer, did a google search for the problem, and your video came up.
Sep 01, 2015 | Dishwashers
Quiet Partner IV. Why is the pots and pans light blinking and it won't run?
Its normal for the drain pump to run for 5 to 15 seconds and then your washer should fill and you wash pump should run if your was pump is not running and just makes a humming sound then your start capacitor may need changing see the link below this is a simple task and not expensive. When ordering a new capacitor make sure it is the same size in ?F.
Washer Motor Capacitor part 8572717 How To Replace
May 28, 2015 | Whirlpool Dishwashers
Pots/pans and normal wash cycle lights blinking fast and soak/scoure continuously lit and start light blinking slow all at the same time. Tried cutting power to reset, it didn't work.
Normally removing the power will clear this error code, if not the touch pad is bad. This is a simple repair, you can watch a video that explains how to repair this yourself at the link below.
http://www.appliancerepairlesson.com/
Mar 08, 2011 | Dishwashers
Unit will not run. cannot enter diagnostic mode.
i would say that you have a bad touch panel..99 percent positive
May 10, 2010 | Dishwashers
Pots and pans and normal lights blinking
Feb 22, 2010 | Whirlpool GU2200XTSB GU2200XTSQ 24 in...
Miele g892 and just like everyone the red light comes on and dishwasher stops running> why cant you answer thic common problem>
The red light tell you there is a fault. You have to read the fault code and it will give you a general idea of the problem - to do this you have to enter the service mode of operation - close the door and turn the dishwasher on.
The Start/Stop light must be blinking. If the Start/Stop light is not blinking, press and hold
the Start/Stop button for at least 3 seconds to exit the cycle. The Start/Stop light should now be blinking.
Press and hold the Start/Stop button while turning the dishwasher on. Release the
Start/Stop button and immediately press it 2 more times. Flashing Intake/Drain and
Salt lamps and a lit Rinse lamp indicates successful accessing of services mode
Fault codes
F00 Pots & Pans Lit
F01 Sani Wash Lit
F02 Normal Plus Lit
F03 Normal Lit
F04 Economy Lit
F05 Rinse & Hold Lit
F06 Pots & Pans Lit
F07 Sani Wash Lit
F08 Normal Plus Lit
F09 Normal Lit Flashing
Sep 19, 2009 | Miele G880 Dishwasher
Pots and pans and normal wash blinking
Try resetting it. Locate the switch in your breaker box, and flip it off- then on again. Hope that works!
Aug 09, 2009 | Kenmore 13743 Staimless Steel Built-in...
All 4 lights on my haier dishwasher Model CG206B blink and beep.
I had the same thing the drain hose was plugged.To reset You have to tilt the washer back 45 degrees.Mine is now running hope this helps.JIM
Jan 04, 2009 | Haier ESD200 Built-in Dishwasher
Lights on pots and pans blink constantly
try disconnecting power for a bit. try the cord under the sink. if its hard wired (no cord) you can try the breaker.
may reset itself.
otherwise, you have a logic board issue.
consult the manual first for explanation of blinking lights etc.
then call the mfg for further info and if needed, schedule an approved repair person.
good luck
mark
Dec 21, 2007 | Kenmore 24 in. 17482 / 17484 / 17489...
Flashing pot and pan light
shut off the power and see if the unit will reset. if its plugged in, it will be easy, look under the sink. if not, try a breaker.
let the power stay off for about a minute.
then back on.
if not restored, then you have logic boards that failed.
sorry,
good luck
mark
Oct 24, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool 24 in. GU2500 XTP Built-in Dishwasher Logo
26 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
