Question about SkyScan 86709 Atomic Wall Clock
After installing new batteries will the clock reset itself
Allsttings on the clock are incorrect
Radio controlled clock no JM818WF does not receive signals. New batteries are put in. No signals on display
Replacement batteries could be defective or installed incorrectly.
Nov 14, 2016 | Home
Model no. BAR338PA
The replacement batteries may be no good or installed incorrectly
Jul 10, 2013 | Audio Players & Recorders
Need to reset atomic clock to Virginia time zone; now 4 hours ahead
To set up your clock simply install one fresh AA, LR6 ALKALINE battery. Due to the nature of long wave radio signals it is normally not possible to receive a signal during the day so it is best to install the battery late in the evening. Select your time zone by pressing one of the four time zone buttons PT-Pacific Time, MT-Mountain Time, CT-Central Time, ET-Eastern Time. The time zone buttons may be pressed any time after installing the batteries. If multiple buttons are pressed the clock will set to the time zone selected last. If no time zone is selected the clock will default to Pacific Time. Another time zone can be selected during or after the clock has set itself. Your clock can only set itself to one of the four time zones stated above. For time zones outside of PT, MT, CT or ET you must manually set the time using the Manual Time set button on the back of the movement.
When the battery is installed the second hand will advance eight seconds (two seconds per step x four steps). The clock is now searching for a signal. For the initial setting it is recommended to stand the clock in an upright position near a window. Within five minutes the clock will either receive the WWVB signal and set itself to the exact time, or it will determine that the signal is not receivable at its current location and time of day. If a signal is not receivable it will fast-forward the hands to the 4, 8, or 12 o'clock position and search for WWVB each
hour until a signal is received. If the time is manually set the clock will continue to periodically search for a signal and automatically reset the hands when the signal is received.
May 31, 2012 | La Crosse Radio Controlled Atomic Clock
How to reset a clock on a kenwwood kdc-mp2032 car stereo after a new car battery has been installed?
if its a detach face, most of the time there is a reset button on radio itself behind faceplate....push it
Sep 17, 2010 | Car Audio & Video
Bmw 318i se auto clock reset problem?
a little more information would be nice but im going to make a guess
you installed a new deck in the car, now every time you turn the car off the clock resets?
if thats correct.. the deck will have 2 power inputs, one that turns the radio off when it does not have a power signal, the other that should have a constant voltage to maintain the stereo memory, now if I'm correct you have either the 2 wired opposite to how they should be or both wired to something like the ignition wire, and it is acting like the battery has been removed every time you turn off the car, which means you need to check your stereo wiring.
if this is incorrect please leave some more info telling everyone when the clock is automatically reseting.
Aug 06, 2010 | Car Audio & Video
Emerson SmartSet Dual Alarm Clock Radio Won't Stop "Flickering"
Problem was solved. When clock was plugged in after a few more days, it finally stopped flickering and reported an incorrect time and day. Low battery was now blinking! Checked calendar and found all memory was lost. Purchased and installed a new battery and this time when clock was plugged in it correctly set itself! Fixed.
Sep 27, 2008 | Emerson Audio Players & Recorders
Emerson Smartset Clock Radio
For the Clock/Radios that are having problems with the clock display and settings. You will have to reset the Clock/Radio's microprocessor. To do this you must unplug the Clock/Radio from the wall outlet and remove the internal battery. You must let the Clock/Radio set with no power for at least 1 hour to discharge the microprocessor circuits. The microprocessor should then be able to reset itself. You can then reinsert the battery and plug the Clock/Radio into the a/c wall outlet. The functions should have reset and be working normally. If this does not solve the problem, try putting in a new battery (CR2430). Before putting in the new battery, unplug the clock radio and remove the old battery and let it set again for a few hours this time to try to reset the microprocessor. If this does not solve the problem (This includes the person with the complete Clock/Radio operation failure) you can call the Emerson customer support at this telephone number 1-800-898-9020. Give them the make and model number of the Clock/Radio. Tell them the problems you are having with the operation of the Clock/Radio and ask them for assistance. I hope this information helps you solve the problems your are having with your Clock/ Radios.
Dec 17, 2007 | Emerson Smartset Clock Radio
Wrong date on the radio.
RESETTING THE CLOCK AFTER A TOTAL MEMORY LOSS
If you do not change the built in lithium battery within a reasonable period of time after you see the ‘flashing’ LOW BATT. warning indicator, the lithium battery may become exhausted and will no longer be able to supply back up power to the SmartSet internal computer.
If the unit is disconnected from the AC outlet after the battery is exhausted, or if a power interruption occurs, the SmartSet memory will be lost and the clock will need to be reset when the power is restored. Be sure to install a fresh lithium battery before you reset the clock, otherwise the clock will need to be reset each time the power is interrupted.
If the lithium battery is exhausted and you experience an interruption in the AC power supply, the clock will reset itself to its initial default setting when the power is restored.
The initial default setting is “12:00 AM, Saturday, January 1
(1 1), 2005”.
If you notice that the time on your SmartSet clock radio is completely incorrect, and the day indicator is also wrong, press the MONTH/DATE button to see the date. If the date display is showing “1 1” (January 1 ), you probably experienced
a total memory loss. To reset the clock after a total memory loss, proceed as follows:
1.) Install a new CR2430 lithium battery in the battery compartment.
2.) Connect the radio to your AC outlet and let the clock set itself.
3.) Depress the MONTH/DATE and TIME buttons together. The display will change from ‘time’ to ‘year’. While holding the MONTH/DATE and TIME buttons, press the UP button to
set the display to the correct year, then release the buttons.
4.) Depress the MONTH/DATE button. The display will change from ‘time’ to 'month/date’ (mm/dd). While holding the MONTH/DATE button, press the UP button to set the display
to the correct month and date. The Day indicator will change automatically as you adjust the month/date settings. When the correct month and date appear on the display, release the buttons.
5.) Depress the TIME button and the UP button to set the display to the correct time. Be sure to confirm that you have set the time correctly to ‘AM’ or ‘PM’ by observing the AM indicator.
6.) After you set the time, reconfirm that the Day, and Month/Date displays are still correct. Make final adjustments if necessary.
The SmartSet clock memory is now reset and the new lithium battery will maintain it for the next 5 to 8 years, depending on the number and duration of the power outages you experience.
IMPORTANT NOTE:
After resetting the clock, don’t forget to reset your wake up times, and alarm mode settings, and sleep timer settings as well.
Oct 22, 2007 | Emerson SmartSet CKS1850 Clock Radio
Clock out of control
I have a Jornada 568 but I've never seen the behaviour you describe. Is it possible that you damaged or caught a small part when you installed the new battery? Your new battery, was that the small round battery or a battery pack on the back of the unit. "Resetting to Factory defaults" suggests that there is no power at all, doesn't it? If the small round watch battery is dead then that might effect the clock.
Sep 12, 2005 | HP Jornada 568 Pocket PC
SkyScan 86709 Atomic Wall Clock Logo
Top SkyScan Home Experts
Jerry Greenberg
Jerry Greenberg
Rick Goldsmith
Rick Goldsmith
Level 1 Expert
Are you a SkyScan Home Expert? Answer questions, earn points and help others
