How do i fix error code U2-22 on imagistics 3511 copier
Cogz
  • 1326 Answers
SOURCE: malfunction code C0200
A C0200 is a Charge Corona problem and it is a Minolta error code.
Posted on Feb 18, 2008
jqsababa967
  • 145 Answers
SOURCE: What is c0920 error code on Imagistics copier?
check you trays ?
Posted on Mar 18, 2009
  • 149 Answers
SOURCE: how to reset malfunction code C0500 of a imagistic
On the side of the control panel, there is a little hole, use a paper clip unbent to press the switch inside hole. The touch screen will restart. watch the left hand side 2/3 up, a little dot will appear, when it does, press 3. The login in is all zeroes. press trouble reset and then turn off and on using the switch at the left side, lower back edge of machine.
Posted on Nov 07, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: Hi, My Toshiba E-Studio 3511
I am assuming you have emptied the old waste toner "box" and not replaced it with a new box. This is not a problem, just clarifying. If this is the case then you have toner packed into the sensor block which is telling the machine that the waste toner box is still full. Just look behind the waste toner box and look for a little set of wires. They lead to a small black sensor. Now look at the waste toner box where it mates up with the sensor. You will see a small square box area on the waste toner bottle. The sensor looks thru this block and if it is blocked with toner it will tell the machine the box is full. Just tap on the little block and make sure there is no toner in it and re-install the waste toner box and the indicator should go away.
Good Luck and Thank You for using Fixya.
Posted on Aug 11, 2010
SOURCE: iMAGISTICS 2620 Error code C0500
How to reset malfunction code C0500 of a imagistic
Posted on Sep 20, 2011
Error code C0110 on imagistics copy machine which model number is C650
The only reference to that particular code is:
C011
Backup memory problem
Problem with thebackup memorydata.Defective backup ram.
Jan 21, 2013 | Pitney Bowes 460-4 Toner for Imagistics...
Getting error sc 479627 toshiba e studio 3511
479627 is your meter not the error code.
3511 and 4511 color machines will be obsolete at the end of this month. Advise you call your local Toshiba dealer and talk to them about a trade in upgrade.
Jan 13, 2013 | Toshiba E-Studio 3511 Color Copier
Toshiba e studio 3511 F120 error need to know what this error is and how to fix?
F120] Database abnormality
(1) Rebuild the databases. (Perform 08-684.)(2) If the error is not recovered, initialize the HDD. (Key in "2" at 08-690.)
Any money the HDD is duff. Srri
Apr 28, 2011 | Toshiba E-Studio 3511 Color Copier
Error code cf30 in toshiba 3511 what its mean and how can fix it
(CF30) - Reference plate detection voltage abnormality: The output
value of the color auto-toner sensor against the reference plate
is out of a specified range at the light amount correction during
an auto-toner adjustment or when a print job has finished.
Your color auto-toner sensor and reference plate are located under the input tray cover on the left side of the copier when you are facing it. It is on a bracket that hangs down into the copier and sits close to the revolver inside the machine. It is an optical sensor and if either it or the reference plate get stained with toner it will give you this error message, you may attempt to clean them with rubbing alcohol.
This error message may also occur if the solenoid that drives the reference plate is faulty so you will need to check that as well.
I would sincerely recommend that you get an authorized toshiba technician to take a look at the machine for you as this is a fairly difficult problem to fix right.
Sep 29, 2010 | Toshiba E-Studio 3511 Color Copier
Our imagistics 8130 has the replace waste toner bottle error message on but the waste bottle is empty and I turned a wheel above the waste toner bottle and nothing.
Hi how are you this is jack ... jack_pak@hotmail.com
Dear you wash the waste toner bottle clearly. But error still your copier you check the waste toner bottle dection SENCER OR IS DIRTY CLEAN IT..
PLEASE VOTE ME .
Thanks
Best Regards,
Aug 14, 2010 | Toshiba E-Studio 3511 Color Copier
Ca 20 error on toshiba 3511 copier
CA20 indicates H-Sync detection error.
U need to check whether the cable (flexible flat type) between the connector (CN334) on the LGC board and connector (CN201)
on the LDR board open circuited, broken or disconnected. Try to replace another cable.
Jan 05, 2010 | Toshiba E-Studio 3511 Color Copier
Imagistics Error Code C-0B77
May want to check the stapling unit and hole punch. To reset open close front door. After openclosing finisher door
Jul 03, 2009 | Office Equipment & Supplies
F2-02 Error on Imagistics ZB35 machine
Sharp AR-5620N getting f-2 error. What is the solution
Mar 03, 2009 | Sharp AR-M237 Copier
IMAGISTICS 2620 Error code C0500
Feb 03, 2009 | Konica Minolta DiALTA Di200 Copier
48 people viewed this question
jasbo
jasbo
