Question about Weather King 10AJA3601AH Air Conditioner
Ac blowing hot air , help me , umemployed and broke and hot
    Sergeant:
  • 340 Answers
Check your circuit breaker be careful resetting stand off to the side if tripped the breaker tripped for a reason. you going to need service. i know its not what ya wanted to hear.
Posted on Jun 23, 2009
Why when I start my car is there an odor coming from vents that smells like something is burning, and my Air Conditioner still blows, but it only blows out hot air. 2008 Chrysler Sebring. Help?
have an accredited ac shop as an ac cannot produce hot air only cold air so that means that the ac is not working (leaks low on gas etc). The hot air is from the heater in the car and the smell is probably wire overheating or the resistors are burning.
Aug 16, 2014 | 2008 Chrysler Sebring
The heater in my 1999 Land Rover Discovery Series 1 won't blow cold.
As per your problem mentioned.There are few solved help links to troubleshoot these problems.Go through the list and Click the link below:----
Air conditioner blows air but not cold air http://repairhelpcenter.blogspot.in/2012/07/air-conditioner-blows-air-but-not-cold.html
Car overheats and Air blows hot at idle? http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
Heater blows cold? http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heat blows cold on drivers side and hot on passenger side? http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html---------- Hot air on the driver's side vents only? http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
2005 Chrysler PT Cruiser: A/C Blows Warm? http://whoisbyme.blogspot.in/2012/06/2005-chrysler-pt-cruiser-ac-blows-warm.html
1992 Toyota Camry: A/C Control light Flashing and A/C not Blowing Cold? http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
No heat, blower blows only cold? http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
These will help.
Thanks.
Nov 22, 2012 | Cars & Trucks
My AC blows cold air for a few secs and then there is a thump and it blows hot air
It sounds to me like yu are describing the symptoms of a broken blend-air door or blend air door actuator. In either of these cases, dash removal is required to repair it.
Jun 02, 2012 | 1998 Lincoln Town Car
Just replaced my Damper Pulley and a new battery on my 2003 Kia Sdona Ex but now my heater will not blow hot air and the AC will not even come on? The AC lighted button will not even light up to show it is...
you havent put the fan belt back on by the sound of it or the pulley you put on has the rubber insert broke and its not turning the belt ,have a good look
May 24, 2012 | Cars & Trucks
My AC is blowing out hot air after getting my crank shaft position sensor replaced last week, that took three days to do. I had AC before I took it in, now all I have is hot air blowing in my face while...
they might have emptied the system to remove the part or broke a pipe not knowing to find out if the system is full you need to have it tested and to find out if its leaking or the belt on the ac is loose causing it to malfunction i would take it back and ask politly that it was working before and now it stopped could you see if they emptied the freeon please
Jun 02, 2011 | Kia Sorento LX Cars & Trucks
Ac blows hot air
If your a/c blows only hot air you need to have it charged. Hope this helps to get you cool
Jul 24, 2009 | 1997 Mercury Mountaineer
My ac also blows hot air, any suggestions
how did you empty your refrigerant?if you broke the system open or allowed it to get the slightest bit of air in it, it will need to be ran into a vacuum before you recharge it in order to make it work properly. in a refrigerant system, 9 parts per million moisture content is enough to slug a compr
Jul 09, 2009 | 1996 Ford Taurus
Automotive AC Prob
Automotive AC is a complex thing to resolve. I have rebuilt many and have seen what it takes to make them work correctly. Now send me make, model, year and engine type and from there I can help you solve your problem. Thanks, Sea Breeze
May 30, 2009 | Heating & Cooling
Climate control does not blow cool air. When I turn the temp down there is no change in air temp. It blows full hot air. Sometimes I can give the dash a smack with my hand and it will blow cool air, but...
you going to have to tear the dash apart (ac control panel) to see why your switch is not working. The control valve unit works on vacum systems and you need to find out where is leaking or the hoses is old and broke off. If your ac compessor still working and blowing cold air but does not adjust the temperature, it will be in the control valve. Is very easy to fix if you locate the leaks or a bad valves. hope that help some.
May 14, 2009 | 1991 Buick LeSabre
No cold air
air doors stuck broke or not getting vacuum.
Apr 16, 2009 | 1998 GMC Jimmy
Weather King 10AJA3601AH Air Conditioner Logo
291 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
acrman404a
Level 1 Expert
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
