Question about Air Vent Inc Gable Attic Ventilator 53320 Whole House Fans
Which way should the rotation be on a whole house fan cw or ccw
Which way cw or ccw
Have a small safe with a three number combination. I am not sure how the numbers should be rotated.
Depending on the unit,, Make , Model etc.
It is usually CCW, CW, CCW sometimes 4 rotations to clear
go to first number, then 3 rotations CW to the next number, then 2 rotations CCW to the last number, rotate CW till the tumbler stops,
Then pull the handle to open, if in doubt,
Call a local locksmith who sells or services the unit and ask the
procedure for that model ,
They may be able to set you straight
Aug 22, 2014 | Home Security
Tip
Fan Clutch R&R With Confidence Using Griller....Glitter Tool
...ever found you self asking which way to turn a mechanical fan clutch's inline coupling nut to remove clutch-fan assembly (It) without mangling a thread or special wrench? Well then, consider the Griller...Glitter mnemonic system described below and never fail to be "thread-wise in the know."
If you know or can bump the starter to see which way the fan spins viewed from the radiator, then knowing any or all of the easy-to-remember devices below will let you get that clutch off, or on, with confidence. For instance, with a left thread clutch nut, the installed clutch-fan assembly will always spin right/clockwise.
Remember, you only need to remember the ones that are easy to remember.
    ·GRILR
    ·GOES RIGHT? IT LOOSENS RIGHT.
    ·If fan clutch spins right/CW, turn its nut right/CW to loosen.
    ·GRITL
    ·GOES RIGHT? IT TIGHTENS LEFT.
    ·If fan clutch spins right/CW, turn its nut left/CCW to tighten
    ·GLILL
    ·GOES LEFT? IT LOOSENS LEFT.
    ·If fan clutch spins left/CCW, turn its nut left/CCW to loosen.
    ·GLITR
    ·GOES LEFT? IT TIGHTENS RIGHT.
    ·If fan clutch spins left/CCW, turn its nut right/CW to tighten.
on Jan 12, 2015 | Vehicle Parts & Accessories
Firing order
Depends on which engine you have.
1.9 1-3-4-2 rotates ccw
2.0 and 2.5 same order but rotates cw
4.3 1-6-5-4-3-2 cw
Oct 22, 2013 | 1993 Chevrolet S-10 Blazer
Maytag bravo washer model number MTW6700tQ0 wont finish spinning please help!!
Hello c bellone,
If you rotate the clutch pulley by hand CW the tumblers should rotate in the wash basket.If you rotate the clutch pulley CCW the tumblers will rotate until the clutch spring comes under tension then the wash basket will begin to turn CCW and the tumblers will stop rotating because the transmission rotates with the wash basket. Do you have this action?
The clutch has been an issue for many are you taking dc or UC errors to the display?This clutch incorporates a Drawn Cup Roller clutch bearing (one way clutch bearing) designed to rotate freely CW and lock up CCW to rotate the spinner shaft in spin cycle rotating the wash basket/transmission CCW.You are halfway thru the clutch removal process, I would drop the clutch out and inspect the roller clutches, clean them up with WD-40 and some light bearing grease.If they are rusted up beyond clean up and or the clutch spring is broken as in this post you will have to replace the clutch.You will know what you are up against once the clutch is out and opened up for inspection.
Here is the process I use for clutch removal;
Access and remove the Clutch for maintenance
Disconnect 120VAC power cord.
Nov 27, 2012 | Maytag Bravos MTW6700TQ 4.6 Cu. Ft. Top...
G.E Table Fan Form A E 1, No F 83711, spec-272113-1, cat 73423, voits 110, cycle 60
Hi wendy, In this case if you have the defective one, you can see the specs on it. So very important is, the rotation facing shaft, cw. or ccw, voltage, capacity, for example 10 watt, 15 watt, shaft diameter and you can use an universable one to replace it. Good luck!!
Sep 26, 2011 | General Electric WR60X10126 MOTOR...
How to rewire dayton 2m034 to change rotation from CW to CCW.
Check and see if there is a plug with 2 wires coming out of the motor, connected through the plug to two other wires. Reversing the orientation of the plug should change the rotation.
--W/D--
Jan 24, 2011 | Dayton Permanent Split Capacitor Motor Fan
I am replacing the electric motor in my gas dryer I have it disassembled, and am removing the fan on the back of the motor. does this fan turn counterclockwise or clockwise to remove
Look at your fan and the way the blades curve...to deterimine the rotation of the motor. They can run either direction... some run CW and some CCW....
Once you determine the rotation you can then determine the way the blower comes off. The motor will always spin to tighten the blow on the shaft..... so going the reverse direction would be the way to take it off.
I wish that I could give a definitive answer like yes it goes CCW... but that would not be the correct answer all the time...hope you understand....and that my explaination is clear...why it could be either way.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 02, 2009 | Refrigerators
What does line and tape mean dayton motor
L 1 is power in .L 2 is also power in.line means this is were the power needs to be hooked to . cw / stands for clock wise rotation . ccw stands for counter clock wise rotation.
Sep 28, 2009 | Air Tools & Compressors
Tub rotates CW during agitation, out of balance, hits side of metal cabinet, but no error code
Hello srcoray,
Did you replace the clutch, just trying to get a feel for your hands on experience with the machine? If you did the work did your machine use the upper roller clutch bearing along with the clutch pulley mounted roller clutch bearing?
The FAV6800AW uses a reversing motor and motor controller that powers the motor and clutch pulley to rotate CW in Wash/Agitate cycle and CCW in Spin Cycle.
In Wash/Agitate cycle the roller clutch bearing should rotate freely CW allowing the agitator shaft to drive the transmission in wash cycle driving the tumblers to rotate only not the wash basket. In spin cycle the roller clutch bearing will lock up (one-way roller clutch bearing) driving the spinner shaft to rotate the wash basket and transmission CCW. Unless my thinking is wrong it sounds like the one way roller clutch bearing is frozen or dragging and not rotating freely in wash cycle rotating the wash basket CW. I’m an owner like you and will try to help.
Just a few other questions;
If you have a load of wet clothes in the wash basket and you select Spin Only cycle will the spin cycle complete with out dc/UC errors?
With the lid raised can you rotate the wash basket CW? It should not; it should only rotate CCW and do that with very little resistance.
Rich
May 22, 2009 | Maytag Neptune FAV6800AW Top Load Washer
No manual for my CDM Alpine radio that came with my new used car HELP!
HOLD LOWER RIGHT TIL TIME BLINKS VOLUME CHANGES HOUR DON'T KNOW ABOUT MINUTES YET
Dec 11, 2007 | Alpine CDM-9821 CD Player
Air Vent Inc Gable Attic Ventilator 53320 Whole House Fans Logo
75 people viewed this question
Top Air Vent Inc Water Dispensing & Filtration Experts
ray gallant
Bill Boyd
Tom Chichester
Are you an Air Vent Inc Water Dispensing and Filtration Expert? Answer questions, earn points and help others
