Question about AM Auto Parts 1978 Pontiac Trans Am Stainless Steel Gas Tank Sending Unit Stainle
How to remove oil pan 1978 pontiac trans am 400cu
Oil pan removed
How to put in a tranny filter on a 91 gmc 4x4 4.3l blazer
You remove the transmission pan and then remove the old filter. Make sure you remove the old seal out of the valve body and install new filter with new seal and re-install pan. Fill with fluid and you are done.
Nov 15, 2014 | Cars & Trucks
How to take out oil pan 1997 pontiac trans sport
you have to raise the motor for 4 inches then you can remove the oil pan
Dec 05, 2012 | Cars & Trucks
Removing oil pan from saturn l300
the ac compressor bolts to the side of the pan and the trans bracket near the pass side of the trans
Sep 12, 2012 | 2003 Saturn L-Series
I have a 1978 chevy caprice, how do you remove the oil pan while the motor is installed?
OK,here we go. Remove starter, exhaust pipes if in way, flywheel pan. Your have raise engine 3 in. Unbolt pan.1_6_2012_11_53_35_pm.gif
Oct 22, 2010 | 1978 Chevrolet Caprice
Changing the tramission filter on a 2007 Saturn Vue Hybrid
Hello and welcome. here is the instructions for removing the trans filter. you will need to drop the bottom trans pan off to gain access to the filter.
  • Remove the oil pan bolts from only the front and the sides.
  • Loosen the rear oil pan bolts about 4 turns.
  • Lightly tap the oil pan with a rubber mallet or pry in order to allow the fluid to drain.
  • Remove the remaining oil pan bolts.
  • Remove the oil pan.
    Install the oil pan attaching bolts.
    Tighten
    Tighten the bolts to 12 N·m (106 lb in).
    Aug 13, 2010 | 2007 Saturn VUE Green Line
    The car is leaking oil and the mechanic said it was because there is a whole in the oil pan and it will cost 1800 to fix. can i buy another oil pan and put it on myself?
    OIL PAN
    REMOVAL
    Drain engine oil.
    Remove front engine mount bracket.
    Remove power-train bending strut.
    Remove structural collar from oil pan to trans-axle Structural Collar - Removal and Installation
    Remove trans-axle lower dust cover.
    If equipped with air conditioning, remove oil filter and adapter.
    Remove oil pan.
    Clean oil pan and all gasket surfaces.
    INSTALLATION
    Apply Mopar® Silicone Rubber Adhesive Sealant or equivalent at the oil pump to engine block parting line Oil Pan Sealing
    Install a new oil pan gasket to pan.
    Install pan and tighten screws to 12 N·m (105 in. lbs.)
    Install oil filter and adapter.
    Install trans-axle lower dust cover.
    Install power-train bending strut.
    Install front engine mount and bracket
    CAUTION: The torque procedure for the structural collar must be followed, as damage to oil pan or collar could occur.
    Install the structural collar Structural Collar - Removal and Installation using the following 3 step torque sequence:
    Step 1: Install the collar to oil pan bolts and tighten to 3 N·m (30 in. lbs.)
    Step 2: Install collar to trans-axle bolts and tighten to 108 N·m (80 ft. lbs.)
    Step 3: Final torque the collar to oil pan bolts to 54 N·m (40 ft. lbs.)
    Fill engine crankcase with proper oil to correct level.
    Auto Zone carries the Oil pan you need for around $75.00 and they will have the step by step instructions for you to replace the oil pan. will take just over 2 hours for the average person. Good luck and keep me posted.
    Nov 30, 2009 | 2002 Dodge Neon
    Change ingnition switch on 1978 pontiac firebird trans am
    Use a steering wheel puller to remove the snap ring that holds the big spring. Remove the screws that hold the signal light mechanism, and the signal light handle has to be removed. Lift the signal thing up to expose a "torx" headed screw. Remove that screw and the tumbler should pull out fairly easily. That torx screw should have an unthreaded part at the bottom of it. Make sure that comes with it. Sometimes they break off.
    Sep 23, 2009 | 1979 Pontiac Firebird
    Gear does not shift while in drive...1978 Chevrolet Caprice
    clutch plates worn or more common is the modulator went out it is a small unit on the trans with a hose relace from a junk yard becareful when you remove tranny fliud will come out measure how much you lose and replace better yet remove pan an relace gasket and trans filter and put new dex merc fluid in also check fluid level in 2 gear
    Jun 02, 2009 | 1978 Chevrolet Caprice
    AM Auto Parts 1978 Pontiac Trans Am Stainless Steel Gas Tank Sending Unit Stainle Logo
    10 people viewed this question
    Top AM Auto Parts Heating & Cooling Experts
    Mike
    Thomas Perkins
    Thomas Perkins
    Bogdan Odwazny
    Bogdan Odwazny
    Are you an AM Auto Parts Heating and Cooling Expert? Answer questions, earn points and help others
