Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
How to get coloured display in tata sky - Sony FD Trinitron WEGA KV-27FS100 27" TV
My tata sky remote is not working and red led fleshing continous please help me
Hi Subhash,
This is a common problem with remote controls. One of the remote keys is permanently on and is causing continuous blinking of the red led. Please open the hand set and clean the PCB and the rubber sheet thoroughly with some solvent like isopropyl alcohol. If you do not have alcohol, even the after shave lotion will do the job. If you do not have after shave lotion, simply clean the pcb and the rubber sheet thoroughly with mild soap solution and water.Dry them completely before reassembling. I hope this will solve your problem.
Jun 27, 2015 | Televison & Video
In akai black belt i unable to connect tata sky
Did you try going through the operation manual and follow guidelines step by step?
Aug 12, 2012 | Akai Televison & Video
Have sound and a black / white picture ? through our sky box
change the output to pal or ntsc on the sky box, then it should display in colour. If that doesnt work change the input on the tv to pal or ntsc.
Apr 17, 2011 | NEC 60XP10 TV
How Tata sky HD superior than Tata sky?
Tata HD has clearer picture as it has high definition technology while Tata sky just has standard definition .
Regards
Mar 12, 2011 | Televison & Video
Tips to operate without remote
You might try hitting the MENU button on the tv itself to see if you are able to select input / source that way. Some TVs also have the Aux Inputs selected by scrolling through the channels until you come to the aux inputs.
Jun 22, 2010 | Prima C2012 TV
Which is better between tata sky an dish tv
Tata sky has the best picture quality and its from sky network ,So tata sky is best one ....
Oct 22, 2008 | DISH Network DVR-625 DTV Receiver /...
PCTV 50i
Your PCTV card has got S-Video input. Just connect the S-video output of the Tata sky box if available or use a RCA to S-video adapter to input the video to the tuner card. Now for audio u can connect it to line in of PC. To watch or Record, just select the input as S-Video in the channel selection in PCTV application
Naveen
[email protected]
Dec 28, 2007 | Pinnacle VIDEO CAPTURE| PCTV PRO (PCTVPRO)
Colour banding on 10D images
Shoot in RAW mode and convert to 16 bit images to reduce banding
Sep 14, 2005 | Canon EOS-10D Digital Camera
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
24 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
