Question about Continental Manufacturing Company Commercial Freezer Value Line 1FX-LT-GD-HD Stainless Steel
What is a PT chart - Continental Manufacturing Company Commercial Freezer Value Line 1FX-LT-GD-HD Stainless Steel
I have a Magic Chef freezer built older than 20 years. 15.2 cu. ft. pt. no. 101403-1
Hello Darrell;
My name is Peter. I am a retired field service technician.
Why do you think your Magic Chef is still working after 20 years? Your unit was manufactured with reliable cast steel components.
Do you want to purchase a new unit with more efficiency with components manufactured with plastic and cast ceramic. If you do decide to purchase a more efficient unit, do not discard your well build Magic Chef. When the new unit fails after 5 years, you will always have the older well built unit.
Nov 13, 2014 | Magic Chef Freezers
Need to know what suction pressure and head pressure should be to have a-20 degree evap. model 6151S Delfield Freezer
Head pressure = ambient + 25*F convert to pressure, look at P/T chart for type of refrigerant.
Feb 02, 2011 | Delfield Freezer 6125XL-S
What should be my pressure on a 404a freezer
usually depends on the temp of the conditioned space. Most freezers run about a minus 10 evap to get a 0 degree box. So look for a low side pressure of about 25. High side is ambient plus 30. A 75 degree ambient, for example, add 30 and get 105 degrees. That, on a P/T chart converts to about 253 psi. Those are approximate but I'm sure you can use this to fugure out what to look for.
let me know if you need more help.
Sep 27, 2010 | Continental Manufacturing Company...
6 beeps on km500mah ice machine. Starts to fill unit and when it switches to compressor mode, the system stops and 6 beeps.
Hi, this is one of the largest ice machines that Hoshizaki make, with the remote air cooled condenser on the roof. As far as the code of 6 beeps, and the compressor starts and stops, you should have a error chart on one of the panels that tells you what the 6 beeps means, a dirty condenser up top that is shutting the unit off on high head or what. You need to find this code error chart, and it will direct you to the point of the problem. I have the service hand book buried in mt service van, so that's not much help.Try and check the remote condenser for a dirty coil, as the is is where you condenser fans and coil are located. It may lust need to be serviced If you have access to nickel safe ice machine cleaner and the unit has not been cleaned in awhile, this I find to be about 80% of problems with these machines. You can by a gallon at a appliance parts house or a/c parts house to clean it up. Some you will nee to do by hand, as they get slimmed up really bad and thing quit working. If you are not tied into a water softener , this is really hard on the machine. Try and look at the fans and coil up top and get the nickel safe flip the switch to the cleaning cycle, and start cleaning. This should take care of that problem. Please rate me , and be kind as I know you will and I will be here to help you. Use my user name below.
Sincerely,
Shastalaker7, A/C, Heating, & Refrigeration Contractor
Aug 12, 2010 | Hoshizaki Freezer Commercial Ice Machines...
T-23f not freezing
Depends on how technical you want to get. Generally, measure the ambient temp of air entering the condenser coil. Add 30 degrees to that temp and convert to psi using a P/T chart. This will get you to a starting point.Remember, charging a "Hot" box takes time. Don't over charge.
Oct 27, 2009 | True Freezers
I have a haier deep freeze model hcm050ec what is the pressure suppost to be
I am assuming you have some refrigeration smarts. As a general rule the evap in a freezer is 10 degrees low than the box temp. Take the pressure of the low side then look on a P/T chart for that refrigerant and determine if it is where it needs to be. Usually somewhere around -10 to-15 degrees for a zero or colder box.
Sep 25, 2009 | Freezers
Whirlpool mod.ev200nxan auto defrost does not freeze.temps.range from 20's to 40's.auto defrost works.coils are not frosted.any ideas?
Is the freezer fan working ? If not , pt # 4357004 . If it is working , then compressor is bad . One of the internal valves are bad . Non repairable unless compressor is replaced (too much money ) .
Aug 25, 2009 | Whirlpool Freezers
MAYTAG MODEL# MQU1556AEW, HAS POWER, LIGHT COMES ON, QUIT COOLING, WE LIVE IN THE HILLS, NO APPLIACE REPAIR PEOPLE, HAVE ELECT TESTER AND BASIC KNOWLEDGE, I COULD USE DIAGNOSTIC MANUAL OR HELP,, THANKS
If the fan in the freezer is working , but the compressor is not , then the overload/relay is bad ( pt # 4356738 ) . If you hear nothing , then the defrost timer is bad ( pt # 4357124 ) . This part looks like its located close to the compressor or in one of the corners of fridge on back with about 1/2 " hole to access manual turning slot . Turn the slot and see if fridge starts .
Aug 24, 2009 | Maytag Freezers
My ice machine only harvest 2 time and start to 3 beep eveaperater very clean no scales inside because i descale every 2 weeks can u help me
In most cases, there is a chart on the inside of the front cover. It may also be located on the side of the box where the control circuit board is located. It will tell you what the 3 beeps mean. Hoshi has a great tech support. It's worth the wait.
Feb 02, 2009 | Hoshizaki Commercial Freezer KM-500MAH
Icemaker makes 2 dumps of ice & then shuts down.
Look on the inside of the front panel. Should be a chart to tell you what the beeps mean. Hoshi has a great tech support line in Peachtree City. It's worth the wait to talk to them.
Jan 26, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Continental Manufacturing Company Commercial Freezer Value Line 1FX-LT-GD-HD Stainless Steel Logo
83 people viewed this question
Top Continental Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Continental Freezer Expert? Answer questions, earn points and help others
