Question about Kitchen Appliances - Others
Pilot only stays lit when holding the gas control knob on my pleasant hearth vff-ph32dr
  • 790 Answers
Have a technican check the pilot safty valve
Posted on May 16, 2014
SOURCE: Pilot light will not stay lit
gas valve needed to be replace
Posted on Jul 20, 2008
r carbo
  • 21 Answers
SOURCE: wont come on
low gas pressure to unit must check and see if gas valve in back of unit is fully on or same for regulator if there is one if the gas valve is open and the unit has a regulator ajust regulator regulator with center screw clockwise all the way down this will give you more pressure
Posted on Nov 18, 2008
tborn6
  • 700 Answers
SOURCE: Imperial propane fryer won't stay lit.
check the high limit it tripping out
Posted on May 22, 2009
my pilot is lighting but my deep fryer wont light
Posted on Nov 21, 2009
  • 10 Answers
SOURCE: Light pilot on Royal deep fryer. Pilot will not
there is a small adjustment screw on the gas valve,turn it clockwise to increase pilot,if that does not work the vent cap on the gas regulator on the back of the unit could be stopped up,remove that cap ,clean out or replace unit can operate without it just fine.If you increase the pilot and it still wont stay lit replace the thermocouple
Posted on Feb 06, 2010
Pilot light blew out by a fan..I turned the control off..How do I Ignite Please
First locate where to light pilot. You can do this by following thin aluminum colored tubing from control valve to inside heater.In general on top of your gas control valve is a knob. Turn indicator of this knob to pilot and depress knob. This will start gas flow to pilot at end of thin tube. Hold this knob in the depressed position and light pilot. DO NOT release knob for 30 -45 seconds. Then release knob and pilot will remain lit. Then turn knob to on position. If pilot will not stay lit you may need a new thermo coupler, which senses heat from flame to keep pilot gas flow open.
Good luck
Mar 10, 2015 | Heating & Cooling
American range fryer will not light...the knob you turn to light the pilot light will not turn.you can push it in but won't turn.please help
From the Owners' manual:
LIGHTING
1. Before attempting to light this appliance, the door if so equipped, shall be open.
2. Turn the appliance manual gas shut-off valve to the OFF position.
3. Turn the combination gas control knob to the OFF position.
4. Turn the thermostat control to the OFF position.
5. Wait 5 minutes.
6. Turn the appliance manual gas shut-off valve to the ON position.
7. Turn the combination gas control knob to the PILOT position.
8. Light the pilot with a match while depressing and holding the combination gas control knob until the pilot remains
lit upon releasing the gas control knob.
9. Turn the combination gas control knob to the ON position.
10. Turn the thermostat control knob to the desired temperature to turn burners ON.
11. Ensure that the door is closed during operation.
12. For complete shut-down, repeat steps 2, 3, and 4.
It won't turn any further until the pilot is lit and stays lit.
Jun 14, 2014 | Kitchen Appliances - Others
My remote is beeping on my gas fireplace model Vff-PH32DR
Check the batteries. in the receiver and remote.
Jan 23, 2014 | Pleasant Hearth Home
Can't locate pilot on vulcan lg300
TO LIGHT THE PILOT
1.Open the door. 2. Turn the thermostat OFF The thermostat is located behind the door. 3. Push the gas control valve knob and turn to OFF. Wait 5 minutes for unburned gas to vent. 4. Push and turn gas control valve knob to the "L" in PILOT. 5. While still holding the knob in, light the pilot with a lit flame. Continue to depress the knob until pilot remains lit when knob is released. If the pilot does not remain lit, repeat step 3 through 5. 6. Depress and turn gas control knob to ON
Jun 02, 2011 | Frymaster FPEL217 Deep Fryer
How do i light the pilot?
Turn the Gas Control Knob inside the heater compartment from OFF to PILOT. Push in the knob and hold it, at the sametime push the ignitor button (will probably be a Red button). Once the pilot lights, continue to hold the Control Knob down for one minute. Then ease off of it. If the pilot stays lit, turn the Control Knob to the ON position. The burner should light, if the Thermostat is set higher than the ambient temperature in the house. If the Ignitor button doesn't work, you can match light the pilot. Just be careful and follow the instructions above, once it's lit.
Hope this helps solve your problem.
Feb 23, 2011 | Williams (5009622) Ceramic Gas Wall...
Once I get the pilot light lit , hold for 30 seconds, and the let the knob out to turn to low or high, the pilot light won't stay lit.
From what you're describing, either the Thermocouple needs cleaning or it needs replacing, However, these are not easy units to work on for a Do it your-selfer. so I would recommend taking it in to a pro who can get the part if necessary and replace it if necessary. Most independent hearth stores that sell and service gas logs and gas fireplaces can help you.
Jan 24, 2011 | Endless Summer 233000 Open Flame Patio...
How do i light pilot light?
Remove front cover,or just lower section if you can. they usually just need to be lifted up about an inch or so and pulled out. However some have covers that snap in place. After you remove cover locate gas valve. It should have a control knob on top with markings for on, off, and pilot. Set control to pilot. Follow lines from gas valve to burner compartment, one goes to main burner one ,small copper colored line is the thermocouple, other line is the pilot. Turn thermostat down as far as it will go. Make sure gas supply valve in line to heater is on and then depress pilot control , when you have pilot control depressed have a match or other small flame source close to pilot assembly. If it lights then hold down on pilot control for a couple of mins. Slowly release pilot control and if it stays lit turn gas control to on. Turn thermostat up to call for heat and burner should light. If pilot doesn't stay lit when you release pilot control then try again holding pilot down longer. If it still won't stay lit then thermocouple will need replace. Good luck. Thanks
Nov 22, 2010 | Williams 6508732 Gas Heater
I can not lite the pilot
Turn the control knob to "pilot", while holding the knob down, press the piezoelectric spark button repeatedly until you see the pilot light through the observation glass. Once its lit, hold the button for approximately 30 secs. If it stays lit when you release the knob, turn to "on" Then operate normally. If the piezoelectric is not sparking, you can open the glass and light manually. Good luck and please rate my answer if it was helpful.
Dec 29, 2009 | Williams 1403622 Gas Compact Heater
My magic chef kitchen range oven won't turn on, no gas
Some of the models require you to push in the oven thermostat knob to set the pilot if it blows out. So try pushing in the knob and hold it while lighting the pilot. When the pilot lights continue to hold the knob in for about a minute. When you let go of the knob the pilot should stay lit. If it does not stay lit then try it one more time. If it continues to go out the thermocouple or aso might be bad and will need service.
Sep 11, 2009 | Magic Chef 31000 Gas Kitchen Range
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
