Question about Jolly Giant QWS3270 Plus (qws3270maint) for PC
ERROR during Conection - ws error 05a8
During a external connection through a VPN into my office it returned the following:
can't connect to 172.19.12.87 port 2423
WS error 05a8
connection failed
When accessed internally the office it works well but out of the office it doesn't work
Is there a specific configuration for DI-604 router DLink ???
  • ira1962 Jan 05, 2008
    i have
  • larryhogg Mar 02, 2008
    No connection in and out of office
I have the same problem trying to connect to mainframe computer from home.
i got ws error 05a8 , can not connet to the host at 127.0.0.1 port 10023.
please help.We tried everything we could disabling firewall, spysweeper, allowing pop ups, reinstalling the software. We contacted our computer administrator at work and the ip, port are correct.
please let me know at irvolkova@yahoo.com
Posted on Jan 05, 2008
Software: QWS3270 Secure Discription: WinSock 2.0 Connection closed by host Error performing handshake **** Error 0x80090301 returned by ApplyControlToken Can't connect to pernet1.hoffman.army.mil...
Jolly Giant is a commercial vendor of the QWS320 software.
As such, it provides technical support to registered users of its (originally "Queens university Windows Sockets") software.
Contact them for support.
Also, connect the System Administrators of 'pernet1.hoffman.army.mil', to ensure that their computer is still accepting TELNET/3270 connections from your IP-address.
Sep 01, 2010 | Jolly Giant QWS3270 Plus (qws3270maint)...
Want to make a network connection between two office 800 meters.
Buy 2 DIR 130 VPN routers and connect the two office networks via LAN-LAN VPN tunnels.
If you have the time and skills you can build two IPCOP firewall routers and connect via VPN tunnels (http://sourceforge.net/apps/trac/ipcop/wiki)
Mar 03, 2009 | D-Link (DIR-130) Router
Can't connect to AT&T VPN
as you told me that all the ports are open so in that case you can get in touch with your ISP and ask them to enable IPPASSTHROUGH on your office laptop.
Jan 17, 2009 | Zoom ComStar 56K 2818 Modem
Unable to get remote desk top computer to work on acer aspire one
I think you're trying to connect to your office computer from home/somewhere else.
If that's the case, make sure you have done the following :
  1. Your VPN Session is connected
  2. Your Office IT Administrator allowed RDC over VPN
  3. Your Office Computer RDC is enabled
  4. Your User (local or domain user) having administrative rights or allowed to connect to RDC session
  5. You got no firewall blocking RDC connection or remote registry
To check if you already connected to your office VPN, launch command prompt and try pinging your office computer name or IP Address. As an example if your office computer name is PC-100 and IP address is 192.168.1.100 then you will issue : ping PC-100 or ping 192.168.1.100. If you got ping reply than you're good to go.
To Enable RDC on your office computer there are 2 ways :
1. On your office computer, right click my computer > properties > Remote > Enable Remote Desktop
2. Via remote registry :
- Start > Run > Regedit > Enter/Return
- On registry editor, go to File > Connect Network Registry > Type in your office computer name > OK
- On your office computer registry, browse to : HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Terminal Server, find the key "fDenyTSConnections", double click it and change the value to 0
You should disable your windows firewall or 3rd party firewall for easier configuration. You can;however set up exception on your firewall but will need some knowledge to do that.
Hope it helps.
Nov 02, 2008 | Computers & Internet
VPN connection timed out
please tell me that who is your ISP at home?
Oct 25, 2008 | Trendware 54Mbps 802.11g Wireless AP
Cannot connect to SonicWall VPN
My guess is that dhcp is using the same private network scheme. Try changing your home network scheme to something different than your office.
For example:
Office = 192.168.1.x
home = 192.168.2.x
Aug 26, 2008 | Westell Wirespeed VersaLink...
DI 524 Router Not able to connect to office VPN on Wireless
I have the same model router at home, just checked the settings, you should be able to pass through the router with a normal vpn connection.
If you use a special VPN client, like a CheckPoint Secure VPN client, the router might block it. Also you might want to ask your office's sys admin if you are not blocked by the firewall or something similar. Your office's sys admin will prolly solve your problem since he knows your work network's configuration and setup and how to connect to it.
Nov 08, 2007 | D-Link AirPlus DI-524 Wireless Router
VPN
This example will demonstrate how to create a Virtual private Network (VPN) between two remote locations through the Internet. The VPN policy will use 3DES IPSec to securely send/receive encrypted data over the Internet. When the VPN tunnel is enabled, the two offices will virtually appear to be on the same local network. This example will consist of two DI-804V VPN Routers with a simple setup. The two remote offices in this example will be known as Office A and Office B. Both VPN Routers must already be set up and able to access each other. This is only an example, your setup will vary using the WAN IP address provided by your ISP. Please note the differences in the IP addresses for each office. We will begin by configuring the DI-804V at Office A. Start by going into VPN Settings under the Basic Setup menu. Step 1. In the Connection Name field, type in OfficeA. Click ADD. Step 2. A properties screen will appear for the new connection you have made. Fill in the appropriate information for Office A: Connection Name: OfficeA Local IPSEC Identifier: Local Remote IPSEC Identifier: Remote Remote IP Network: 192.168.1.0 Remote IP Netmask: 255.255.255.0 Remote Gateway IP: 192.170.0.2 Network Interface: WAN ETHERNET Secure Association: IKE Perfect Forward Secure: Enabled PreShared Key: 123456 Key Life: 28800 IKE Life Time: 3600 Step 3 Click SAVE. There should now be a VPN policy created for Office A. Now you will want to Save & Restart the DI-804V. Note: 123456 is an example of a preshared key, please fill in any secret preshared key you desire. Keep in mind that both sites require the same preshared key. Office A setup is now complete, we will now configure Office B with the other DI-804V, Follow the same steps previously with Ofice A to create a VPN policy. Step 1 Please change the appropriate information. Connection Name: OfficeB Local IPSEC Identifier: Local Remote IPSEC Identifier: Remote Remote IP Network: 192.168.0.0 Remote IP Netmask: 255.255.255.0 Remote Gateway IP: 192.170.0.1 Network Interface: WAN ETHERNET Secure Association: IKE Perfect Forward Secure: Enabled PreShared Key: 123456 Key Life: 28800 IKE Life Time: 3600 Step 2 Click SAVE. There should now be a VPN policy created for Office B. Now you will want to Save & Restart the DI-804V. After the VPN policies have been created for the two Offices, the two remote locations should authenticate and connect. To view the status of the VPN connection, go to the Device Status menu. On the bottom-left side of the menu, click on the VPN Status icon. A VPN Status pop-up screen will appear showing VPN connection status. If a VPN tunnel is active, the State should indicate Q-Estab. Go to a DOS prompt and ping the internal IP address of the remote network.
Feb 16, 2006 | D-Link DI 804V (DI-804V) Router
Computers & Internet Logo
3,170 people viewed this question
Top Jolly Giant Computers & Internet Experts
David Payne
David Payne
Are you a Jolly Giant Computer and Internet Expert? Answer questions, earn points and help others
