Question about Mitsubishi VS-70707 70" Rear Projection Television
How to move a 70 mitshibishti tv
Let me find out
Can I move the closed captioning text to the bottom of the screen on an AQUOS Quattron Sharp 70" TV? (LC70C8470U)
On some sets the captions can be placed on different parts of the screen. Check out your manual to see if your set has this feature.
Sep 09, 2016 | Sharp Televison & Video
Why do I have to rescan my tv several times a day
The main system memory IC to your TV is faulty. It must be replaced with same type and number. It is a skilled work. Seek assistance of any experienced service technician for help.
Jul 04, 2012 | Vizio VL Televison & Video
No power
Check the color wheel, take out lamp and look at color wheel with flashlight see if moving, make sure you tape down or up lamp door switch. If color wheel turns or not? Have same tv my probelm was the color wheel. cost around $70 easy to install>>>>
May 31, 2010 | Samsung HL-S5686W 56" HDTV
When i turn onmy xbox it comes up with a black scream an little green moving dots i can still hear the sound !!! why this happing
Try the switch on the xbox cable and make sure it is switched to appropriate TV (TV/HDTV). Try HDMI if possible and try a different cable. If none of these work it is a GPU or Motherboard fault and may not be fixable. Good Luck
Nov 23, 2009 | Video Game Consoles & Games
My tv from usa not working in india
It needs 50hz or 60. Won't work with both. US TVs are no good in India.
Oct 01, 2009 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Estimated Weight
Direct quote from 2001 Mitsubishi Product Catalog Specs. Gold Series
VS-70707
Weight (approx. lbs.) 365
Jul 19, 2009 | Mitsubishi VS-70707 70" Rear Projection...
Blue convergence
replace both STK392-110 convergence ICs. You can get replacements with instructions at the following link.
http://servicemanuals.vstore.ca/
Dec 28, 2008 | Panasonic PT-53WX52 53" Rear Projection...
Mitsubishi WS 65909 Power
The constant blinking green light means that the TV is not booting up. This is a common problem on this set.You need to remove the shield from the DM board (standing upright on the left where the DTV RF connector is)and inside you will see the four leaky capacitors (1000 MFD 16 VOLT)replace them,plug the TV in and wait 70 seconds for the blinking light to stop,then turn on the TV.The hard part will be removing the board from the TV(lots of screws and connectors,takes time)
a3d2d2a.jpg You must do some checks first:LED does not stop blinking after plug in. Verify the standby supplies, 12-volts at connector KA pin 17, 6-volts at KA pin 18 and the 28-volts at KA pin 19, if the supplies are present suspect the DM PCB part # 934C067001 LED does not stop blinking after plug in. Check C9B01, C9B02, C9B10, and C9B11 (1000 UFD 16) on the DM PCB, if they are bad replace them with part # 181P734030 (680 UFD 16 V). LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature; this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds . LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector RF pin 4 and 5 on the Signal PCB if low suspect problems with the switches/buttons on the Control PCB part # 935D736001. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector RF pin 4 and 5 check good suspect the E2P PCB part # 934C061001.
Just click below for more information.; http://www.fixya.com/support/t838883-mitsubishi_wd_52825_tv_wont
Hope it may help you ;
Regards,
VOTIT
Sep 27, 2008 | Mitsubishi WS-65809 65" Rear Projection...
How to disassemble a VS-70705 for transport
I found the problem. Mitsubishi put 2 strips of what looks like rubber caulking inside, presumably to keep the TV from rattling or something. Peel them off from the inside and the top comes off just fine. Both pieces are still very heavy, so its at least a 2 man job moving either piece. Most of the weight seems to be the LDF more than the TV though.
May 25, 2008 | Mitsubishi VS-70707 70" Rear Projection...
Mitsubishi VS-70707 70" Rear Projection Television Logo
32 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
