Question about Garmin Golf Logix GPS
UNIT COMES ON BUT LOCKS UP IMMEDIATELY
AFTER IT COMES ON IT LOCKS ON A COURSE BUT WON'T SCROLL TO ANY OF THE HOLES. IT ALSO WON'T LET ME CHANGE TO A DIFFERENT COURSE. AT THIS POINT THE ONLY WAY I CAN EVEN TURN OFF THE UNIT IS TO REMOVE THE BATTERIES.
OK, the only things you can do is take it back or buy a new one, but here is a list of things that make PSPs do that:
1: Dropping them(Accident or not)
2: Putting water in them(So don't wash it)
3: Thumping them(Even if you lost that level)
4: Over-charging them(Charge it for 1-2 hours only)
5: Putting it in the microwave
6: Putting it in the oven
7: Leaving it in a steamy room
8: Removing the game while power is on
9: Bashing it with a hammer and finally...
...10: Opening it up and fiddling with the bits inside it.
Posted on Jun 25, 2009
What could be the problem if the fan on outside unit starts and then kicks off after a minute.
look for timing in your remote maybe your entered a timing mode, if not you must see for coolant is the unit full of it or you have some holes in system an your unit run out of coolant who is a freon gas of course, if all of this is ok you have to change the transponder unit in your inside block because is out programmed , if srvice is doing a new reprograming of this block ok if not you have to replace it
May 10, 2014 | Intertherm Heating & Cooling
Figidaire FTF630as0 won't agitate. The door locks and water drains but won't agitate or spin
Hello Tina Kaha - Often when a unit does not spin, it is because the unit cannot properly drain and dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Apr 19, 2013 | Frigidaire ATF6000ES Front Load Washer
My asb light comes on when starting and stays on. Lights won't come on , power locks won't work, power windows won't work, radio won't work. All fuses are good and car runs fine.
Those are all really common symptoms of the alternator going bad on those cars. I would have it checked to make sure it's charging properly.
Dec 15, 2012 | 1996 Oldsmobile Cutlass Ciera
Unit won't turn on. Yes it is plugged in.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on; or it may turn on but produce no audio to the speakers.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Sep 13, 2011 | Technics SA-AX720 Receiver
Game got stuck in ps3 and then i got the game out and now it wont turn on and a yellow light comes on
Yellow Light of Death. Contact Sony immediately. 800-345-SONY. My local repair shop won't touch Yellow Light of Death. If your system is out of warranty, Sony will offer to exchange it for a recertified unit for $99.
Jun 17, 2011 | Sony Playstation 3 (PS3) Console
Wont turn on
lg has a problem with that model--usually bad electrolytic caps(most of the time the tops of the bad caps are swollen)if you take apart the unit you should see them problable in the power supply--if you dont think you can change them--contact a local shop-ask 4 price 2 change them or u can go to shopjimmy.com--enter model number--scroll down til u find power supply--if not in stock write down part number--google part number to find one
Sep 18, 2009 | LG 32LC2D Television
Water is leaking from freezer door. may have put holes in something, putting locks on door. locks are on left side of unit(facing unit).4 holes in door,about half way up door. four more across from them......
good evening sir.
well about ur problem, plz check it out in a near service center, as ur freezer is fragile part, connecting directly with compressor, any slight damage r rough handling may result in leakage of Coolent !! which is sometimes quite toxic.
or else, if u can manage then try fixing it a rubber washer of reqired size. this will definetly stop the leaking of water..
thank u
Jul 17, 2009 | Refrigerators
Estro magic delux (now saeco i think) water leaks below brew unit
There is a small metal plate with holes below the square funnel shape on the brew unit. This plate has a pink rubber seal and a stem that goes up into the brew unit. The stem is knurled with ridges and is attached to a screw on the plate. The screw has become loose and the plate is not held tight against the seal. Turn the knurled knob clockwise until it tightes the plate against the bottom of the unit. Make sure the plate is centered as I believe there is a slight lip that it recesses into. Should stop the water in the grounds collector. Of course the seal must be in good condition. Paul
Feb 02, 2009 | Saeco Magic De Luxe Espresso Machine
Change blade on old model Black & Decker circular saw
I drp a screwdriver through one of holes in the blade; that "locks the blade" when the screwdriver comes up against the sole plate. Works great for tightening as well.
Oct 25, 2007 | Black & Decker S500 ScumBuster Handheld...
Garmin Golf Logix GPS Logo
188 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
