Compressor kicks off on thermal overload,RV rooftop air
  • 434 Answers
Compressor is locked up. Needs replaced and recharged
Posted on Jun 24, 2009
Rooftop RV Air Conditioner: temp outside 90 or above. compressor kicks off ....
It sounds like maybe an overload for the compressor is tripping and resetting once the compressor cools. Possibly due to a low charge.
May 03, 2010 | Heating & Cooling
My dometic duo therm brisk air RV a/c unit is not cooling the RV
I had the sam problem, took the thermostat cover off and tightend and refastend the wires, so far so god
Oct 27, 2009 | Dometic Rooftop RV Air Conditioner
A/c wont kick on sometimes. it works when it does and the fan on works
there is a safety switch on the compressor - thermal overload for protection - this could be weak - compressor could be drawing to many amps on startup -very long extension cord - too small wire size on cord - if the cord feels warm or hot when unit is running - this could be problem
Sep 19, 2009 | Dometic Rooftop RV Air Conditioner
PART # 7330B730 SERIAL # 109734610 1997-TIMBERCREEK R.V.
most of the time the condenser coil is dirty and needs to be washed out. with it dirty the pressures are elevated and causes compressor to kick out on overload. try washing cond. coil first
Sep 12, 2009 | Dometic Rooftop RV Air Conditioner
My doutherm first it threw a breaker and after
Sounds like the thermal overload on the compressor is tripping in and out. This is caused by either a weak thermal overload switch or the compressor is bad. Usually it is the latter of the two. If the compressor is kicking off but the fan is still running, then this is the case. If the entire unit is shutting down due to the breaker tripping, then you may have a bad Start Capacitor or PTCR Device. On the upper unit, remove the shroud and then there is an access panel on the side of the AC. Remove the cover to expose the capacitors. The start capacitor has a small black relay attached to the top of it, make sure that this relay is not burned out. If so, then it will need to be replaced. If it is fine, then I would say that you have a bad compressor of the condenser is dirty.
Jun 30, 2009 | Dometic Rooftop RV Air Conditioner
Blowing hot air. Compressor not kicking on. Where
Possibly three things, either a thermostat problem, starter relay/capictor, or a bad overload protector not closing after an overload. The starter relay should be behind a black box located on the side of the compressor.
Jun 28, 2009 | Dometic Rooftop RV Air Conditioner
This is a duo derm roof top air conditioner, possible compressor freezing up
If the compressor is not even trying to start you have an electrical problem in the circuit for the compressor. The thermostat could be open and not supplying power to the compressor or the thermal overload device could be open.
Nov 06, 2008 | Dometic Rooftop RV Air Conditioner
PROBLEM WITH DOMETIC RV ROOFTOP AIR conditioner
Check at the compressor terminals between the Red and the terminal for the overload protector to see if you are getting power to the compressor on startup.
Jul 23, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
204 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
