Question about Dometic Rooftop RV Air Conditioner
Penguin model 610012-001a/c compressor won't start
Fan runs in all 3 speeds, control display cycles thru all modes. Room temp display reads "LO" (whatever that means). If I close the compressor relay on the circuit board manually the compressor runs and cools.
I've thought about removing electronic control and replacing with manual switches and relay's. Anybody ever done this?
I have a clicking in the fan. It appears to be the squirrel cage fan touching the side of the cage. It is worse on high fan speed and very irriating. What can I do?
Rush
Posted on Jul 27, 2010
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 127 Answers
I would check to make sure that the control is sending the "cool" signal to the control unit. LO on the room temp display usually means that the fan speed is set to low. Is LO and Auto showing on the display at the same time. Try resetting the thermostat first. Hold down the Mode and Zone buttons with the tstat off. While holding them down, turn the tstat back on and hold the buttons down until FF appears on the screen. Release the buttons and try the AC.
If this does not work, on the control board is a freeze control switch plug (blue usually). Try unplugging this unit and insert a small jumper wire. If the Compressor comes on and runs then you have a bad freeze control switch. If not, then you should replace the control board.
Hope this helps,
Jeff
Posted on Jul 05, 2009
Fan always runs, speed doesnt change (low/high), setting humidity level doesnt impact...is this a control board or circuit board issue?
Verify the humidity reading with another device. Perhaps the humidity sensor is dirty or bad.
Another possibility is the switching device that runs the compressor and fan is shorted. If it's a mechanical relay, the contacts may have welded together, or if it's a solid-state relay, it's got a punch-through or meltdown in a device junction. My guess is it's a mechanical relay since you mention it used to click on and off and now you don't hear that. The relay may be on the control board, or it may be mounted separately - I don't have a photo or diagram of the inside of your model available.
Jun 25, 2015 | Dehumidifiers
When I turn my window unit on, it will cool for 2 - 3 minutes. Then the fan turns off and the compressor continues to run for maybe another 90 seconds, then shuts off.
Make sure the filters are clean. Check what mode it is on as well. On heating, it is normal for there to be a delay before the unit starts up and then "run on" when turned off. Also check what temperature is set on it. If the temp is too high, the machine will cycle on and off as it thinks it has already reached the temp you want.
May 25, 2015 | Heating & Cooling
Ok So We Bought This. But We Have A Problem Does It Take Water Or Not? Thats What I Need To Know! Please Help!
The DeLonghi PACA120E Portable Air Conditioner quickly cools rooms up to 400 square feet and comes equipped with several functions that make operation easy and low maintenance. Its 3 operating modes are supplemented with no-drip technology, an adjustable thermostat, 24-hour timer, and much more. This unit truly takes the work out of cooling medium- to large-sized spaces. Multiple Modes and Functions The DeLonghi A120E-also known as the Delonghi Pinguino PAC A120E-offers 3 operating modes and 3 additional operating functions that make this model versatile and energy efficient. Cool Mode: 12,000 BTUs of cooling power help cool large rooms, offices, or basements. Dry Mode: Reduce room humidity by removing excess moisture from the air. Fan Mode: Circulate air to keep your room comfortable without using a lot of energy. Low, medium, high, and an auto-speed are all included (auto speed selects a fan speed for you). Smart Function: Your AC uses Cool and Fan mode based on ambient room temperature. This function will also select your fan speed and keeps your room comfortable without wasting energy. Sleep Function: Using a low fan speed, the AC gradually reduces operation so your room remains comfortable but the AC runs more quietly and efficiently while you sleep. Boost Function: This function is ideal for the summer months and uses the maximum fan speed to rapidly reduce your room temperature. Useful Features Using DeLonghi's patented no-drip technology, this unit is "dripless" under normal conditions, meaning the AC will discharge all of the moisture collected from the air-so you typically won't have to worry about draining the water. When dehumidifying a lot of moisture in Dry mode, excess water may collect in the internal collection tank. Once the tank is full, the air conditioner will automatically turn off to avoid overflow damage. You can also use the included continuous drain hose as a no-fuss way to eliminate excess water as needed. An adjustable thermostat provides additional convenience by allowing you to set your room temperature. The DeLonghi portable AC will cycle on and off to eliminate over-cooling and maintain the set temperature. Additional Features Washable Air Filter: A washable air filter helps remove allergens and other particles from incoming air and saves you money on replacement filters. Quiet Operation: High efficiency compressor and components result in quiet performance. Electronic Controls: The LCD screen displays the timer and temperature settings, while intuitive indicator lights accompany each operating mode. 24-Hour Timer: This feature lets you program your AC to turn on or off up to 24 hours in advance, so it only runs when needed. Window Bracket: Double window bracket is included with purchase for flexible installation. Self-Diagnosis System: The unit includes a self-diagnostic maintenance system that identifies malfunctions should they occur. Remote Control: Use the full-featured remote control to change modes, set the timer, and select a fan speed up to 23 feet away from the receiver (on the front of the unit). Portability: Easy-roll casters and dual carrying handles make it simple to move this model from space to space.
Aug 06, 2012 | DeLonghi PAC A120E 12000 BTU Portable Air...
The compressor and fan won't come on but there is power supply working for the lights
Without your MAKE & model number; all I can do is tell you what can cause this symptom.
At the end of the defrost cycle the defrost control is supposed to get a signal from either a 60 deg bi-metal thermostat or thermistor (depending upon make & model) That signal starts the clock either mechanical or electronic that signeals the compressor to start. The fan automatically will run when the compressor runs. If the defrost thermostat or thermistor is not working correctly the unit will start a defrost cycle but never finish so it completly defrosts.
The termperature control will also cause this symptom. If the corntacts in the temp control fail the compressor will not restart.
Just from reading your symtoms I think you have a problem with one of the following:
1. Defrost thermostat or thermistor
2. Defrost control
3. Temp control
Most of the time it is either 2 or 1 above in that order.
If you respond with a make and model number I will use that to determine if there is anything you can do at this time to troubleshoot.
Thanks for choosing FixYa,
Kelly
Aug 07, 2011 | Refrigerators
Which symbol on remote is cooling? I dont have a manual but is on the wall, symbols are a fan on the bottom LH, an a sun on top LH I think? Are you able to help me with modes to select please?
Symbols:
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode.
L-means fan speed low
M-means fan speed of med H-means fan speed of high.
To get proper cool, mode "cool" and less 3 degree minimum than your room temp.
To get proper Heat mode "Heat" and 3 degree more than room temp. Hope, helpful
Jan 30, 2011 | Sanyo Heating & Cooling
Compressor & fan not running.
Hi and welcome ti FixYa, I am Kelly.
Since you did not include your model number this will be a GENERIC response.
Reasons for the compressor and fan not to run.
1. Defrost control problem. Mechanical defrost timer stuck or failure. On units with Electronic Adaptive Defrost controls; a PCB failure.
2. Defrost thermostat or defrost heating element failure.
3. Fresh Food temp. control failure.
These are the 3 most common failures. The fans should run anytime the units temp control is above the "set temp" and the unit is NOT in the automatic defrosting cycle.
If you provide a model number I can pass on some troubleshooting tips to hopefully help you isolate the failed componenet.
Kelly
Jan 26, 2011 | Kenmore Refrigerators
Heatpump r-22 rudd system,unit runs starts out heating then compressor stops in middle of heating ,this unit has a out side air temp. sensor just wondering if possible bad board or not
If compressor stops in middle, check the following.
1.Thermostat setting must be minimum +3 degree than your room temp
2. Check it's in heat "mode"
3. Check indoor and outdoor coils are clean.
4. Check fan motor is working alright.
5. Outside sensor and room air sensor is placed correctly.
6. Gas pressure is o.k
7.Check compressor is overheated, even all the above is o.k.
Jan 12, 2011 | Ruud UAPA024 Air Conditioner
Fan kicks on but compressor does'nt start. Humidity control checked out. Compressor ohmed out. Fan runs for about a minute then it shuts down.
i would do a continutity check on you relay and overload, other than that
what is the humidity level in the room, as well as the ambiant temp. these mahines cycle for that very reason, the fan will come on, do a check and then determine if it should start the compressor.
check if you have voltage at the compressor when its supposed to be running ( just a last thought)
ive seen compressors ohm out, but in fact be bad
Oct 09, 2009 | Kenmore 54351 Dehumidifier
Penguin 13500 ac short cycling
UNITS THEMOSTAT IS BAD REPLACE THERMOSTAT IF DONT SOLVE PROBLEM MAKE SURE UNIT IS NOT FREEZING UP AND BOUNCING OFF A "FREEZE STAT" CASING COMPRESSOR TO SHORT CYCLE
Jul 31, 2009 | Dometic Rooftop RV Air Conditioner
Sharp Air Conditioner. Model # AF-S85NX. Does this A.C. fan cycle on & off in the auto cool mode or does remain on continuously. I need a small A.C. that cycles off and on with the compressor.
If you set you r AC to FAN mode the unit will not cool, it only runs in the indoor but the outdoor will off. If you set to AUTO the unit will cool but the indoor blower will automatically run slower when the room is cool or attain the room temp. setting. If you set it to COOL the fan speed is fix depending on your setting and it also operate in cool.
Apr 19, 2008 | Heating & Cooling
Dometic Rooftop RV Air Conditioner Logo
275 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
