Question about Uniden Cordless Phone
Idect solo plus triple phone.Base not charging battery
Hi my cordless phone froze when someone tried to call me. How do i unfreeze it?
Pull the battery out and let it set for 3 min. This is assuming it is battery operated....
Mar 23, 2016 | Idect Solo Vintage Styled DECT Cordless...
Handset 1 not charging on either base unit
Check to see if there is any build up on the contacts that voltage flows through and clean it with DEoxit
Feb 24, 2016 | Idect Solo Vintage Styled DECT Cordless...
My idect twin solo second handset only works through speaker phone
My second set no display on Panasonic Mode KX-TGACM
Dec 21, 2013 | Lands Phones
Check voicemail messages on idect phone
This worked for my iDECT Solo 5035 phone. Pity manual has no reference to Voicemail that I can find. Thanks heaps for your help (and thanks to Google for getting me here...).
Jan 17, 2012 | Lands Phones
Helllo could you please help my binatone idect s2i cordless phone bleeps when the phone is on the base...why? thanks.
Hello bgryan!
The iDECT S2i seems to use the same proprietary 'operating system' as the old BT cordless DECT telephones I grew up with, and the beep is actually just a tangible confirmation that the unit has commenced charging.
To turn it off, you need to undertake the following with the phone on its default screen (i.e.: displaying the handset's name, date and time):
  • Press the right softkey (next to the 'R' key and above the end call button) to enter the telephone's menu
  • The new screen that pops up should have the text "Answer machine", with a little cassette icon
  • Press down on the square directional arrow pad located in the middle of the telephone (this key also has an [MSN-like] icon of two cartooned silouettes)
  • This should present you with the "Sound" portion of the phone's menu
  • Press the right softkey again to enter the sound sub-menu
  • Press the down arrow key on the directional arrow pad to highlight the "Tones" option
  • Press the right softkey once more to enter the tones sub-menu
  • You should be presented with the following: "Key beeps " (this "" portion of the above should be highlighted in white) and "Confirmation"
  • Scroll down using the down key to reveal the other settings - in total, these are: "Key beeps", "Confirmation", "Battery low" and "Out of range" - each having its own "" or "" option located directly below it.
  • Using the right and/or left keys on the directional keypad (these have an envelope and book sign on them, respectively, also) turn each of the "" options for all four of the above settings to "".
  • This should prevent the telephone beeping once placed back on the base to charge!
Just in case, here is a quick guide to what exactly those four settings control - should you want to selectively re-enable any of them:
"Key beeps": This setting controls both the beeps made by pressing down any key on the telephone, AS WELL AS the beep produced by the phone being returned to its base to charge. One to definitely avoid enabling.
"Confirmation": This setting controls the rather annoying beep produced every time a setting is confirmed, after changing it, or when the right softkey is pressed to "OK" the change. Again, this is one to avoid enabling!
The "Battery low" and "Out of range" settings control the beeps made when the telephone is low on battery and out of the range of its base unit/reciever respectively. If you rarely charge your phone, or use it often in the garden/more than one hundred metres away from the main base unit, it may be wise to leave these options enabled. Otherwise, I would suggest selecting the "" settings for these, as they can cause some particularly loud beeps at rather inopportune times, especially when telephoning someone late at night.
I hope this helps, and as a fixya newbie I apologise if I have provided a somwehat too comprehensive answer to your query!
Kind regards,
Ghost3203 - the purported resident iDECT S2i guru... :)
P.S.: Should anyone require a Binatone iDECT S2i manual, this is the only online-available copy - actaully produced for the British department store Marks and Spencers: http://www.binatonegps.com/_global/files/S2i%20user%20guide%20for%20UK%20M&S_080513%20v1.pdf. However, Adobe PDF Reader (or equivalent) is a prerequisite to reading the above document.
Nov 25, 2010 | Cell Phones
My iDect X1 phone flashes and beeps on and off when on the charging base
The sound and flash is when the contacts on handset touch contacts on base, if the handset is positioned correctly- check the contacts, wipe them over with a clean lightly damp cloth. If the problems persist I suggest new batteries which can be purchased from Idect directly by calling 0845 345 9677- they will be posted by First Class Post and do not charge P+P.
Nov 14, 2010 | Uniden Cordless Phone
My idect D1i phone keeps asking me to register
Hi , The phones which keep saying Register mean that they have lost the coding for the Base. To re-code them all you do is
press the menu button,
Press down Button 3 times until Setting comes on the screen,
Press the Button Phone/Ok,
The Display should display HANDSET SETTING,
Press the Button Phone/Ok ,
Then Press the Down button about 4 times until Register Comes on the screen,
Enter Base pin ( 0000 )
The Display will show REGISTER IN PROGRESS,
then immediatly press the Handset Locator Button on the Base and hold it in until you hear a tone.
Thats it , the screen should display Register Done.
Mar 06, 2010 | Lands Phones
Mobile will not hold its charge
Battery going bad. Replace battery and you should solve your problem. Batteries plus sells every battery you can find, if you have one close to you.
Aug 28, 2009 | Panasonic KX-TG1033S Cordless Phone
Ineed a user manual for idect D1i triple modle number 2615bk
I have just bought an iDECT D1i triple and it had a sheet of instructions with it. There were so many sections that they crammed onto one sheet that it was too tiny for me to read. So I scanned each individual section and c&pd it into a WORD document. It's brilliant! I would be happy to share it with anyone who needs it but I don't know how to make it available apart from emailing it individually to people. Anyone any ideas?
Mar 09, 2009 | Lands Phones
Idect x1
Could be that you need a new battery inside the handset, sometimes wont charge properly if battery is old
Feb 24, 2008 | Uniden Cordless Phone
Uniden Cordless Phone Logo
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
