Question about OfficeMax Office Equipment & Supplies
Om02750 shredder where can I purchase replacement carbon brushes for the shredder motor?
defrankond
  • 65 Answers
SOURCE: Carbon motor brush source?
unfortunatly the only way you could purchase the carbon brushes is from a vacuum parts dealer directly. the brushes will most likely end up costing you close toth price of a new motor anyway. sometimes its best to just get a new motor as the newer designes rotate teh brush much faster for better cleaning.
Posted on Nov 29, 2008
rowdy45176
  • 2176 Answers
SOURCE: carbon brush sparking and cause no power for electric motor
You have either one of 2 problems. Either you have a brush that is hung up and burnt or the armature is bad. If you are comfortable in removing the brushes first unplug the tool and remove the brush caps. Pull brushes out and look at the spring making sure not collapsed and then the end of brush that rides on armature for a burning look. Then I would look into brush tube and try and turn by hand the roller to look at the segments of armature best you can. If this needs anything other than brushes I would take it to a repair shop. Good luck
Dave
Posted on Dec 28, 2008
barkencoa
  • 3463 Answers
SOURCE: installing carbon brushes on Bosch WFK 2401
Remove rear panel of washer.
Remove drive belt.
Unscrew the 2 bolts that hold motor to tub back.
Remove motor plug
Lever notor back with a screwdriver or similar, keeping a firm hold on motor.and remove motor
At the rear end of motor away from pulley you will see the brushes and the armature.
Remove brushes, and if there is less than 4 or 5mm of carbon left, then replace them.
Lightly clean the armature with emery cloth.
Refit in reverse order. Test.
Plz rate my solution.
Thanks.
Posted on Jan 15, 2009
SOURCE: how do I replace the carbon brushes?
Go to the link below there is a video How To..
http://www.videojug.com/webvideo/how-to-replace-hotpoint-carbon-brushes-in-your-washing-machine
Posted on Mar 10, 2010
karmacanic
  • 16 Answers
SOURCE: Replacement carbon brushes, where to buy.
Hi, Just go to the Clark tools site & brushes can be bought on-line & sent to you.
http://www.clarkeusa.com/support.htm
Here is the link for you. Best of luck Ian Wallace
Posted on Apr 09, 2010
Testimonial: "Don't know why that site exists. Clarke filed for chapter 11 in Feb. 09. April 30th article in the Toledo Blade states they went out of business."
I have a drill model ARPBD 1500. Set no 8161501. Can I buy a set of brush's for the motor.
yes the carbon brushes are available, you need to do a webseard with the make and model and the word brushes. my search found an auction on ebay so they must be available through the service centres that service your equopment
Jun 03, 2015 | RTO 1:1.2 Mower Gearbox Brush Hog Rotary...
PROBLEM SENSOR PAPER DETECTION
There is a lever inside the shredder that is connected to a micro switch that detects the paper. Its usually located in the center of the opening where you insert the paper. This switch will make a very slight click if you turn the shredder off and insert a sheet of paper at the opening. If you can hear it click and it still doesn't work the motor could be defective.
Feb 19, 2015 | OfficeMax 10-Sheet Micro-Cut Shredder...
Toro mower over heats
If you're Toro electric blower is slowing down, throwing sparks, overheating or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower and "850" Vacuums)
Search E-bay for: "Toro Blower Carbon Brush"
- 12 Amp leaf blowers Toro Super (Old model 51552) through Toro Ultra (New model 51609).
- Toro 850 Super Blower Shredder-Vac 12 Amp (model 51575).
- 10.5 Amp leaf blowers Toro Old through Toro New model 51573.
- 7 Amp leaf blowers Toro model 51586 and other Toro 7 amp blowers.
Jul 10, 2014 | Toro Lawn Mower With Toro Power Tools
Why will my toro 5198 leaf blower not start?
If you're Toro electric blower is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Jun 28, 2014 | Toro 51599 Electric Blower 12 Amp
Blower does not turn on
Apr 03, 2014 | Toro Garden
Bin full door open
I found the nylon "bin full" flapper in the center of the head of the shredder is supposed to trip a microswitch indicating bin full. I removed the flapper and tapped on the switch. It came loose with a puff of paper dust. I replaced the flapper and it's back to good as new. Seems the dust built up around the switch and it was stuck.
Mar 31, 2014 | OfficeMax 10-Sheet Micro-Cut Shredder...
Snow blower shorted out
Feb 17, 2014 | Toro 51599 Electric Blower 12 Amp
Motor was losing power and burning
Jan 13, 2014 | Toro "Toro" Super Blower/Vac
Where to find replacement carbon brushes Campbell Hausfeld pressure washer pw1350
Parts for Campbell Hausfeld can be found at www.chpower.com. Campbell Hausfeld does not however, sell motor parts for many of their tools. You would have to call their 800 number and speak with a parts person to determine availability. You may be able to purchase a close match at a local True Value hardware store. They sell a variety of brushes for many major brands of tools. Purchase a slightly larger set of brushes and sand them to size. If the connector is different, cut off the old connector and solder it to the new brush.
Dec 15, 2011 | Campbell Hausfeld Garden
My OM02750 overload light goes on even with a single sheet? How do I fix this?
I have a OM02750 out of warranty exhibiting the same symtom. I opened the unit (power disconnected) and found some bad solder joints on the bottom of the circuit board. Re-soldered them and now it works.
Nov 17, 2010 | OfficeMax 0M96431 Shredder
74 people viewed this question
Top OfficeMax Office Equipment & Supplies Experts
Colin Stickland
Colin Stickland
Steve
ka4iup
ka4iup
Are you an OfficeMax Office Equipment and Supply Expert? Answer questions, earn points and help others
