Question about Ricoh MP-301SPF Copier : MP301
How is it when I replaced the PCU on a Ricoh MP301 it still says replace PCU?
Changed the PCU and it still reads replace PCU
SOURCE: My printer's nuts!
you need to replace the black cpu, if you go to their website it will tell you how to replace it step by step
Posted on Oct 19, 2007
  • 58 Answers
SOURCE: ricoh aficio cl3500n reads replace colr pcu what is this?
The PCU is the photconductor unit. There is a black pcu and a color pcu. Did you replace these or replace the toner cartridges??
http://www.websitetoolbox.com/mb/copierquestions
Posted on Jan 23, 2009
  • 903 Answers
SOURCE: Ricoh Aficio AP3800c--message to replace black
Are you sure you replaced the PCU and not the development unit? When you replace a PCU on the 3800, there is a fuse or tab that tells the copier it has a new PCU. If you put a brand new black PCU in the machine and it didn't recognize it, chances are that PCU was damaged. You can either keep running the machine and ignore the message, or try to replace the PCU with a new one again.
Posted on May 29, 2010
  • 903 Answers
SOURCE: replace black PCU ricoh aficio
To replace the black PCU:
- Turn the printer off.
- Open the cover on the right side (as you're looking at the front of the printer).
- There are two green levers, one toward the front of the printer and one toward the back -- pull these out and lift the cover that they're holding all the way up (it should stay in place).
- Remove the black PCU by pinching the green lever and sliding the unit straight out.
- Take the new PCU out of the box, take off the tape around it and remove the cover on top of the unit.
- Align the new PCU along the rails the same way the old one was aligned (using the green arrow) and slowly slide it in. As you slide it in it will slide out of the bottom cover -- throw that cover away.
- Lower the PCU cover and slide the levers into place.
- Close the side door.
- Turn the printer on.
Posted on Mar 22, 2011
SOURCE: I replaced the color PCU
job printing processs colour but CMYK not print on the same position
My Ricoh Aficio SPC811DN printer keeps asking me to replace my PCU colour all the colour carteridges are over half full what do i have to rplace
The PCU is the drum unit. There is one for each colour (C,M,Y & K). Each PCU has a 'life' and the machine will ask you to replace it when it has reached the end of its expected life. The PCU life has nothing to do with the amount of toner that you have in the cartridges and they need to be changed independantly.
Jan 18, 2011 | Ricoh Aficio SP C811DN Laser Printer
I have some ricoh aficio 1224c with errors c481
SC481
Transfer belt mark detection error
• The main motor is operating; and
the lock signal is detected. → The
belt mark sensor signal does not
change for 120 milliseconds.
• Defective main motor
• Image transfer belt out of position
• Belt mark blurred or absent
I would remove the pcu unit (3 screws)and check the transfer assy belt mark and clean the sensor that reads the belt mark. Worst case senerio is replaceing the entire pcu unit.
Mar 07, 2010 | Ricoh Aficio 450 Copier
Ricoh Aficio AP3800c--message to replace black PCU, have done same and still get message?
This must be done before drum is replaced.
Resets counter.
Start the SP mode and execute the
New Unit Set:
• PCU: SP5-999-001 ∼ 004
Feb 03, 2010 | Ricoh Aficio AP3800C Laser Printer
Hi.when i m switch on the Ricoh 3310L Fax,the message is coming as shown below "time to change PCU"
Order a new PCU from Ricoh. Power off the machine and replace the pcu.
If you try and cheat it it will run for a short while and then lock-up breaking some gears. Cheeper just to order a pcu. Check Ebay, i see alot of Ricoh supplies there.
Jan 23, 2010 | Ricoh 3310Le Fax Machine, FAX3310Le...
Ricoh aficio cl3500n reads replace colr pcu what is this?
Jan 19, 2009 | Ricoh Aficio CL3500N Laser Printer
Error Message: Replace Black PCU
I'm not sure how to obtain one, but "Black PCU" stands for Black Photoconductor Unit, and according to a manual for a different Ricoh printer model, it should be fairly simple to replace if you can find one.
Nov 10, 2006 | Ricoh Aficio CL2000 Laser Printer
Ricoh MP-301SPF Copier : MP301 Logo
96 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
