Question about Dryers
Gas dryer does not provide heat - Dryers
  • Mike Price
    Mike Price May 11, 2010
    I could be one of many problems, does the dryer have a small peep hole or access panel on bottom front?...the peep hole would be a piece of plastic about the size of a quarter.
  • 351 Answers
What is the model number, it could be a igniter, coils or a thermal fuse... whirlpoolpartssurplus.com
Posted on Jun 23, 2009
Dryer runs but not heating up. Changed elememt . But still not heating up. Wat else could b wrong?
Did you change out the thermostat atop the element with the new one provided?
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 26, 2011 | Crosley CDE6000 Electric Dryer
1. When you set the timer knob for the dry cycle it gets stuck and dryer keeps running. 2 The dryer turns on and runs but does not always ignite to provide heat. Heat source LP Gas.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 20, 2011 | Whirlpool Dryers
My natural gas maytag dryer does not provide hot air to dry the clothes. It apperas the gas is not igniting because after it tries it smells like gas. I beleive it could be the ignition source.
heatman101
Jul 17, 2011 | Dryers
My dryer wont provide heat, i have replaced the thermal switch and the thermestat.
heatman101
Jun 28, 2011 | Kenmore Dryers
My dryer will not heat. The manual says to first check the dryers fuses. Where are these fuses located?
They mean the fuses or circuit breaker in your house that provides power to the dryer...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Apr 26, 2011 | Dryers
No heat provided by the unit
heatman101
Apr 03, 2011 | Maytag MDE3706 Electric Dryer
On my gas dryer... timer and knobs all seem to be working. But it is not providing any heat...
heatman101
Jan 27, 2011 | Maytag LSE7806A Top Load Stacked...
Gas Dryer no longer putting out heat.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 14, 2010 | Whirlpool GEQ9858J Dryer
Gas dryer tumbles but no heat
Depending on the model, you may have a gas vale problem. The ignitor is working but gas is not being allowed to flow to the burner. It could also be one of the temp sensors or the control board for the system. Try unplugging the dryer and then replugging it back in after a few minutes.. If that fails to work after that.. provide brand and model so we can provide more detailed assistance...
Regards
Oct 11, 2008 | Dryers
Dryer will not heat
You may have a temp switch tripped inside the dryer that will disable power (if its electric) or gas ( if its gas) from providing heat.. Since you've provided very little information on your particular dryer.. those would be my best guesses.. Hope that helps you..
Aug 18, 2008 | Dryers
Open Questions:
Kenmore Elite Dryer HE4 Quietpak 9, has 4 dim lights showing on the console display but won't start or respond, I have bought brand new and replaced all sensors. Replaced heating element. looked like the original heating element. Pack came with new sensors. I did not test with a multimeter. My plan is to measure continuity on all the old sensors. Then do the same on the new ones. The electronic board looks good, does not smell burnt or old burnt smell. I cleaned all the lint in this dryer but unfortunately the motor has some lint in it which I surfaced cleaned. The only way to get to the motor is to remove the drum. So far I have soent $40 on all parts and a week works of troubleshooting as a novice. On the main display read, it shows two small dim lot red lines, wish I could send you a picture. Also when the fuse is off I plugged in the dryer and all the lights turned on normal. All looked in working condition except of course it did not turn on, I have not replaced the switch and with the new fuse, by the way, I bought 5 to 6 of the same fuses thinking I was burning them, that's why I bought a multimeter to retest them to see if they are not burnt. When I plug in the fuse it goes black but the door light works. I have held down the start button, nothing, held down the cancel button, nothing, I have done the crazy push all buttons even shook the machine a bit just in case something was causing whatever myth I was conjuring. I am about to give up and just buy a used one from someone else but I think I can fix this, it should be very simple to fix.
Aug 20, 2018 | Kenmore Dryers
Dryers Logo
51 people viewed this question
Top Dryers Experts
Marvin
Marvin
