Question about Olympia 14.52C Cross Cut Paper Shredder
OLYMPIA Shredder C-668 - Olympia 14.52C Cross Cut Paper Shredder
How to find switch settings in ceiling fan to match remote
Most people use a paper shredder, not a fan. Try posting in the correct area. Fantastic question but I have no idea what your asking. Make model etc helps a lot.
Nov 22, 2014 | Olympia Office Equipment & Supplies
Our Olympia paper shredder forward switch does not work but the reverse does.
Move the power switch to AUTO (l) position and depress the manual forward button for five seconds to clear paper blockage. Make sure the paper is engaging sensor located in the center of the shredder opening.
Good luck..
Apr 15, 2011 | Olympia Office Equipment & Supplies
Takes the paper and then it backs up
This happens when the shredder detects an overload or potential jam condition. try making sure the cutters are lubricated with the correct machine oil and it will take paper in correctly. Experiment with feeding in different numbers of sheets to see what it is capable of. Avoid paperclips and stapes as they can damage the cutters and force the cutting blades to become misaligned which in turn puts additional stress on the motor and will mean that you will be able to successfully shred less paper than if the blades were OK and in good condition.
Oct 07, 2009 | Olympia Office Equipment & Supplies
Sensors not working correctly ... jamming
Try blowing some canned air down into the feed slot to clean the sensors.
Sep 23, 2009 | Olympia 1500.1C HS Shredder
Looking for replacement shredder bag clip for olympia model 3801A
I have been trying to find the clip you are asking for. I think what you should do is go to the Link and fill out the form so you can ask for the part. It is not on their website so you might need to explain what you need. Hope this helps.http://www.olympia-shredder.com/contact-us.html
Aug 24, 2009 | Olympia Office Equipment & Supplies
The shredder jammed (too much paper) then stopped and won't shred. It makes a noise, but when I insert paper, it won't shred. Is there a reset button? I picked paper out of the blades with a pair of...
Chances are, the overfeed caused the teeth of the gear that operates off of the motor to break.
This is very common in less expensive machines. I don't know if OM will let you return it because I don't know there policy. Most of the time retailers will attribute broken gears to abuse, which in turn is not warranted. These machines are mainly mass produced in China and obviously are very cheap. The labor and part (s) to repair are more expensive than replacing the machine.
If you do, look for a higher quality German machine i.e. Intimus, Olympia, HSM or Dahle. They cost more but they have a nationwide service arena and parts are always available.
Mar 07, 2009 | OfficeMax 0M96431 Shredder
Olympia Shredder Jammed and not working
likely a spacer has broken, if you can see the underside of the cutting heads you will see a spacer or two hanging out, If this is the case the heads will have to be bebuilt or replaced.
Mar 06, 2009 | Olympia - 1452C CROSS CUT OFFICE SHREDDER
Shredder Errors before Paper Touches Blades
When the paper shreds it pulls both the blades inward. Reverse spins them outward.
There must be something too large between the blades because it can be pushed up just not pulled down.
Has a staple or paperclip been inserted into the machine?
Try one of these two things:
When you're vacuuming the machine, hold the reverse button in and see if that helps.
Unplug it, take out all loose pieces like the bag liner, tape the door closed, get another individual to help you flip it upsidedown and GENTLY tap the machine to break free any obstructions.
Hopefully one of these solutions will work for you.
Jan 15, 2009 | Olympia 1500.1C HS Shredder
Olympia shredder 1280.6
On this model, make sure the hopper is all the way in. If it is, remove paper hopper and check to make sure the hopper is not broken. There is an electromagnetic switch in the front and the hopper has a magnet built in to it. run a stick magnet across the right underside and front to see if it extinguishes the light. If not, then the board is bad.
Jun 12, 2008 | Olympia 1280.6 Shredder
Olympia 14.52C Cross Cut Paper Shredder Logo
Top Olympia Office Equipment & Supplies Experts
James Cagle
James Cagle
Daniel Thibodeau
Level 1 Expert
Michael Galve
Michael Galve
Are you an Olympia Office Equipment and Supply Expert? Answer questions, earn points and help others
