Question about Malibu ML600TW - Low Voltage Power Pack - 600 Watt - With Timer and Ground
Need to buy timer pins - Malibu ML600TW - Low Voltage Power Pack - 600 Watt - With Timer and Ground
  • Malibu Master
  • 5,245 Answers
Looking to buy the red pin to set the sign timer
1) Timer is not identified.
Question posted under Intermatic T100 series which has metal trippers, and not green and red.
2) Copy following links to help identify timer:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
http://waterheatertimer.org/Tork-timers-and-manuals.html
http://waterheatertimer.org/Paragon-timers-and-manuals.html
3) Add a comment Dec 2012 and describe timer in detail. Or attach a photo of the timer for possible identification.
Dec 10, 2012 | Intermatic & Indoor/Outdoor Rain Tight...
My timer works fine but I need to buy extra trip pins so that I can turn my waterfall off for three hours at a time. Where can I buy extra trip pins?
Copy following links for intermatic timers, and trippers:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#trippers
Jul 16, 2012 | Hardware & Accessories
Hello! I have a 59017 timer, and this is my problem: When I put the timer in Timer option, If I have all the pins in off, the timer run ok, but if I put one Pin in On mode, The timer run ok but when find...
You don't say if this is new timer installation.
Or if timer was working before and suddenly stopped working.
I also own Woods 59017 timer from Home Depot.
1) New timer installation:
Open following link to access manual and read wiring instructions.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59017
2) Old timer that stopped working:
If timer dial does not rotate, then the timer is broken, does not have power, or is wired wrong.
If timer stalls when it gets to a pin, then the clock motor has gotten weak, and is overheated and will stop working.
3) Buy new GE 15070 timer from Home Depot for $18
http://waterheatertimer.org/GE-timers-and-manuals.html#15070
4) Buy new Woods 59017 at Amazon for $11 plus shipping
http://www.amazon.com/Woods-59017-Mechanical-Repeats-Switch/dp/B002MO3LWQ
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 03, 2011 | Woods Mechanical Inwall Timer 59017
I have a old Ringgrip timer with little pins which allow the timer to switch on and off. I need to buy more pins
1) I specialize in timers, and search timer information each day.
The only tripper pins available on internet are for Intermatic box-type and some outdoor timers.
http://www.electricsupplyonline.com/prod/intermatic-trippers.php
And not all Intermatic timers have trippers, because Intermatic manufactures timers for a lot of other companies, and sells timers under many brands.
2) Open following link to find same/similar timer
3) You can add a comment and describe your timer, and I might know of same/similar product
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Feb 12, 2011 | Electrical Supplies
Is there anyway I can get a replacement Pin for model #49529/TM 158DS? I'm missing one Pin. Any help would be greatly appreciated! Thanks
Woods 49529 is a segment timer.
http://waterheatertimer.org/Woods-timers-and-manuals.html#49529
Woods timers do not have replacement parts or pins since local retailers Walmart, Lowes, Ace, Target, CVS etc sell them inexpensively.
Buy similar timer on-line for $9.
http://www.amazon.com/59366-Appliance-3-Prong-Outlet-Repeats/dp/B001D8VIKE
If You have a different timer, add a comment with description of timer.
There are Intermatic and Tork timers that have replaceable pins.
For a price, expert speaks with you over phone while you work on any do-it-yourself project.
Jan 19, 2011 | Woods Hardware & Accessories
Intermatic T101R turns off automatically, but does not turn on automatically again when "On" pin rotates through to the set time. "On" pin is screwed on tight and I verified it is the...
If timer has been working fine up until now, you probably need a new tripper pin
http://www.grainger.com/Grainger/INTERMATIC-Timer-Tripper-2E054?Pid=search
If lever is worn out, then you need new timer.
You can but a T-101 and swap insides without changing box
The T-103 will also work because it has a 120V clock motor
The T-104 is a 240V timer and will not work
You can buy the replacement timer mechanism and swap out
http://www.grainger.com/Grainger/INTERMATIC-5225438-2E021?Pid=search
http://www.grainger.com/Grainger/INTERMATIC-24-Hour-Dial-Timer-Mechanism-2E354?Pid=search
http://www.lowes.com/T-103
When wiring new timer, put wires back the same as old timer
For T101 and T-103 wiring schematic, see following link
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Oct 28, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Installed new T104 timer 3 mos. ago. Bldg. owner says the dial "hangs up" on pins--has to use manual on/off. Wiring is correct.
1) The clock motor might be bad if trippers hang up on pins
2) The timer might be exposed to dirt dust and moisture, in which case the T-104R raintight might be better
3) The tripper pins rotate around until they contact the tripper lever >> the pins push the lever >> new Intermatic timers have a bit of white grease on the lever where trippers contact
4) Test the manual override to see if it clicks back and forth crisp and clean >> the trippers click the manual override back and forth, so if override is sluggish, then timer might be bad >>> buy new timer and swap out insides without changing box
5) Sit and watch the timer and see if trippers hang up or they skip over the tripper lever> you might need new trippers. This seems odd with a new Intermatic timer.
6) The building electricity may have gone off and the timer is not set on current time and the bldg owner doesn't know how the timer works.
Timer accessories at Grainger
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
Oct 22, 2010 | Intermatic T104-20 Indoor Hot Water Timer
Clock does not work to turn pool filter on and off. do I need a new timer mechanism or clock motor
Things to check:
1) Is yellow dial rotating? If not, then clock motor is probably bad. T-100 240V time clock motor sells for $16 at grainger.
Also timer may not be getting 240V so check manual override.
2) If clock motor is turning, but manual override never clicks on-and-off, then pins are probably worn out. Buy pins at grainger
3) Does manual override work? Does it click crisp? If manual override clicks crisp on-and-off, and pool filter turns on-and-off normally, then a) the circuit is getting 240V and b) the timer mechanism is ok ... so clock motor is probably bad.
4) If manual override snaps crisp but pool timer does not turn on, then then circuit breaker could be bad, wire is loose, motor has gone bad
Test for 240 across poles 1 and 2
... or timer contacts are worn out & you need new T-104
See back of mechanical timer
5) If manual override is loose or sluggish, then you need new T104. You can buy a T-104, T-104R, T-104M etc ... and the interior body will snap into old box.
Note: Do not buy T-101 or T-103 as these have 120V motor.
Sep 29, 2010 | Intermatic T104M 208-277Volt 40-amp Timer...
Malibu ML600TW - Low Voltage Power Pack - 600 Watt - With Timer and Ground Logo
35 people viewed this question
Top Malibu Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
jdthefixer
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
