F54 error code
And it smells like something is burning
  • 6 Answers
SOURCE: Kenmore Oasis F54 code
F54 = Motor Control Overcurrent
Does the basket turn freely? If not, determine cause of friction.
There is a detailed repair manual inside the machine. If you open the top of the machine with a screw driver in the front you will find the manual on the inside of the front panel. Good luck
Posted on Dec 15, 2007
57 varieties
  • 1653 Answers
SOURCE: F54 error code
The F54 code is a motor control overcurrent error. If you keep seeing this error then you ned to callin a service man to have the system looked at.
Posted on Oct 02, 2009
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite Oasis Wash Machine Error Code F54
The F54 fault code indicates that the control board senses high motor current.
This can be caused by excessive friction in the spin basket.
With the washer off, open the lid and see if the basket spins freely.
If not, you may need to remove the basket and check for an item stuck between the spin basket and the outer washer tub.
The second and third images show procedures for removing the basket on the Oasis washer depending on whether you have an impeller or agitator in your model.
If the basket spins okay, then you can follow the technical troubleshooting described in the first image.
This may help you determine the cause of your washer problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Removing Tub, Basket, lint filter: http://media.fotki.com/1_p,srfssgbktsdgrrqxgtqsskgwtqkq,vi/rstsfdwbbxwwdskwfgkxrrdqddwqb/1/1303472/5961857/image5139789143943268173img-or.jpg
Removing basket & Hub: http://media.fotki.com/1_p,sqgwstkfwtfwsqwxgtqsskgwtqkq,vi/kbkbfbkgwxbfdtwrdxkrkggrdrw/1/1303472/5961857/image27197img-or.gif
Wiring Diagram: http://media.fotki.com/1_p,srfssgbdfbbkfwsxgtqsskgwtqkq,vi/rstkrrqkkxwrtdkbbrbxbqdswfffs/1/1303472/5961857/image3973684248966800668img-or.jpg
http://media.fotki.com/1_p,wktkgtrtsbsgwfrxgtqsskgwtqkq,vi/wrskkfsfrxwwqgrkddg/1/1303472/5961857/image35809img-or.jpg
Posted on Sep 25, 2010
SOURCE: code f54 I am smelling
You will probably need to replace your drum drive shaft assembly. Its one piece and our part at our local appliance service center gave us a price of $217. Not including labor if you need them to install it.
Posted on Mar 08, 2011
natea190
  • 104 Answers
SOURCE: need to know what the error codes mean on a whirlpool cabrio model wtw6400sw3 F54,F82,F83,F84. Please help.
you may have something between the tubs or your bearing is going bad . does it sound like a jet plane in spin cycle?
Posted on Feb 20, 2013
Testimonial: "thank you and for anyone looking to buy a washing machine stay away from cabrio's they are the worst machine ever produced."
Need code for 7 blonks on power button
www.ask.com/
www.wikipedia.org/
www.infolinks.com/
www.info.com/panasonic_viera/plasma/tv/th42pz80u/blinks/7_times/and/black/screen/mean/
most likely failure of module in the tv, most likely fuse, capacitor, something burn up, find the air vents smell the area your smelling something burn up smell, if you have every smell electronic stuff burning up you will understand what i mean you will never forget that smell.
Oct 06, 2015 | Panasonic Viera TH-42PZ80U Plasma TV
Kenmore Elite oasis washer code F54
F54 is a Motor Control Overcurrent.
1) check to see if there is anything between basket and agitator this can cause this error.
2)move the basket .. should move freely
if all is clear then most likely you will need a new motor
Jun 12, 2013 | Washing Machines
Need to know what the error codes mean on a whirlpool cabrio model wtw6400sw3 F54,F82,F83,F84. Please help.
Feb 20, 2013 | Whirlpool Washing Machines
F54 code
It is detecting a high current load when trying to turn the tub. Lift the top of the washer by using a putty knife and insert it between the top and front panels about 3 inches from each side, push in the clip and lift the top. You will find a tech sheet glued to the inside of the front panel in a plastic bag. Go to page 3 and look up your error code, it will refer you to page 4, test #3. I explains how to test the motor assembly.
Oct 21, 2012 | Maytag Bravos MTW6600T Top Load Washer
Maytag model 2400 stack dryer has error code 3e motor hums but wont spin the tub to dry clothes-also an electrical smell like burned motor windings
Either the motor has gone out, the transmission has locked up or if it is a direct drive system there could be something in the pump that is binding the motor preventing it from turning therefore causing it to over heat giving you the electrical smell.
Sep 04, 2012 | Maytag Dryers
Code f54 I am smelling a burning smell and the machine shuts down on rinse mode
Jan 04, 2011 | Maytag Bravos MTW6600T Top Load Washer
F54 error code
Sep 28, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Dec 01, 2008 | Kenmore Oasis 27042 Top Load Washer
Error code one long beep on startup smells like something burning
Go down about 1/4 of the page to the heading "AMI BIOS beep codes" and look for your BIOS manufacturer. This should help you solve the problem. Please reply which BIOS model you have for more help.
Sep 22, 2008 | Computers & Internet
Dec 09, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
