How to fix Savin SLP45 SC 403-00 service call code?
Savin SLP45 black and white printer. Will print a few hundred pages and then stop and in the display window the message appears: Service Call SC 403-00. Is there anything I can do to fix this? It seems to go away if we let the printer cool down, but then the error code reappears after printing a few hundred pages.
jackboy
  • 2985 Answers
SOURCE: Printer stopped printing. Error message
Thjis is indication the Waste in collector pades need changing eventually.- but no now. you have plenty of warning
Reset Epson R300/200
press three buttons to reset the counters
The buttons are "STOP" "Maintenance" and "POWER"
or down load the epson utility www.ssclg.com and use the reset counter feature
The printer will sound like its going to blow up, but thats normal.
You can do this about 5 times before your printer starts to piss out ink over the table because the Waste Ink Ink Pad is full
To avoid eventual flooding go to rear of the machine- remove the little door and rake around for a small plastic pipe buried under some padding under the left side.
Fix to this a thin piece of ploythene tube[Fish tank air supply], extend it to our side the machine and place in a suitable container to collect the waste ink..
Posted on Nov 21, 2007
  • 37 Answers
SOURCE: error code sc 202
This code is a problem with your machine polygon motor it is defective or the cable running to it is defective , it is quite a big job getting to that motor so i sugest you get a profesional to fix that up for you .
Posted on Jan 07, 2008
SOURCE: Ricoh Aficio MP C1500SP - functional error SC202
call ricoh serviceman he/she can fix it.
Defective tank full sensor
• Tank full lever bent or broken
• Incorrect ink suction
1. Check the harness of the tank full sensor.
2. Replace the GJ engine.
3. Replace the maintenance unit.
• The position of the tank full lever
does not stay at the tank full position
after ink initialization or air releasing.
• The position of the tank full lever is
not detected at ink suction.
Posted on Jun 23, 2008
SOURCE: Canon MP830 Service Error 6000
Canon PIXMA MP830 all-in-one Inkjet Printer
Error code 5C10 on computor screen and on the printer it says 6A00
Posted on Mar 25, 2009
  • 5 Answers
SOURCE: Roland SC-545EX Service Call 0110
hahahahhahaha mayra
Posted on Jun 19, 2009
Black streaks at bottom of page after printing
Okay Grehner, I suggest you to perform a complete alignment and cleaning/maintenance-service for this printer.ASAP...this will help you out with this particular problem during printing.
Blessings.
Gladmar.
Mar 18, 2014 | Savin Office Equipment & Supplies
Ricoh Aficio SP 4210N- Code SC 543
This is a common error code for Ricoh copiers, Savin and Gestetner copiers that need service. Recently Ricoh has purchased Lanier and now is naming all their new machines Lanier instead of Gestetner, Savin and Ricoh. However, the copier service error codes have remained he same.
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser's thermistors help regulate the temperature of the fuser assembly. The fuser assembly on all copiers including Canon, Kyocera, Ricoh, Sharp and other brands is the part that melts the toner onto the page.
Getting back to the repairing the copier on Ricoh, Savin, Lanier and Gestetner models that have the fuser or fixing code error. The majority of the time the fusers' thermistors (Middle and read) need to be replaced. Just cleaning them will not solve the copier repair service code.
It is usually, depending upon the machine, its a 1 to 2 hour copier repair job because the copier repair service technician will need to dissemble the fuser, insert the two new thermistors, re-assemble, reset the error code and test the copier machine repair. Also, ask the copier technicians to to do a copier cleaning maintenance while on site.
Aug 18, 2011 | Ricoh SP 4210N Laser Printer
My SAVIN 2575 is giving error code sc820, any idea what the problem is ?
Unfortunately, I've never seen this error, so I can't give you much help beyond what the code means and the possible solutions that the service manual provides...
SC820:
Self diagnostic error: CPU - Unexpected external error or interrupt occurred.
• Controller board defective
• Software defective
The manual indicates this is a "C" type code, so this should not be displayed on the OP panel, only logged in the SC history in the machine.
Jun 23, 2011 | Savin 2575 Black and White Copier
How do I reset the printer error code sc545 on my savin printer
To reset the machine after SC545, enter
simply in the SP mode.
( C 1 0 7 stop )
Jun 22, 2011 | Savin 2575 Black and White Copier
My Savin SDC 103 has an SC-172 call service error. The copier was given to me, it only has 7800 copies on it. The error showed up after they moved it.
That code is related to the scanner unit.
Probably after they move the machine the lamp went out of position.
I advise you to see the all scanner; Lamp, Mirrors, White plate...
May 23, 2011 | Savin Office Equipment & Supplies
I have a service code CS541 for a Savin 2522 - I need to repair it
Ricoh copier service code SC541 refers to the fuser assembly having a problem.
Sometimes they code can be temporarily reset, however, it will eventually come back
and not go away!
While the printer is on do the following:
  1. Hold down both of the arrow keys for 10 seconds
  2. Press ENTER
  3. Select Option 2 for Engine
  4. Choose 7 Data Log
  5. scroll down to 7807 and execute it. click OK
  6. press the escape button until you get to the engine option
  7. then select option 3 to end
  8. restart the printer by pressing the power button.
If the above does not work, repeat the procedure but instead of 7807 look for SC calling, something like that, and reset the whole thing.
The reality is that the problem is fixable though, and do not need to purchase a new fuser, after clearing the code, the printer should work fine again
Jan 31, 2011 | Savin 2545DP Black and White Copier
Savin 2545 communicating light blinks but nothing prints
YOU NEED YOUR FIRMWARE UPGRADED BUT ONLY A SERVICE TECH CAN GET IT AND DO IT.1 HOUR OF TIME SHOULD BE PLENTY AND THAT SHOULD INCLUDE A CLEANUP PROBABLY ABOUT 150 TO 200 DOLLARS
May 18, 2010 | Savin 2545DP Black and White Copier
Printing very light
it is possible the td sensor was left disconnected.If that is the case the dev will be shot to pieces by now. £££
Apr 19, 2010 | Savin 2575 Black and White Copier
Savin printer showing E 54.What does this mean?
If it's actually a Savin 2575, then you're missing a digit in the error message; However, any Savin machine that gas an error of '54x' relates to a fuser problem, and it can only be reset in service mode after the problem is fixed.
Jul 14, 2009 | Savin 2575 Black and White Copier
19 people viewed this question
k24674
