Question about AEG Washing Machines
Error code C9
WHEN I START THE MACHINE C9 APPEARS. WHAT IS THE PROBABLE CAUSE?
SOURCE: AEG OKO LAVAMAT 86741 UPDATE. WASHING MACHINE
I have washing machine AEG 62800 model.
When I tried to start a washing the error E60 was displayed on screen.
The following actions were done:
1. Turning knob to right to first position "COTTON LINES 95"
2. Pressing on all 5 functions except START button (Rinse Hold, Rinse+, Time Saver, Pre Wash, Stain).
Red lights will flash .
3. Pressing on Start button and simultaneously starting to turn clockwise till OFF position.
It will reset error and will release machine.
I'm hoping it will help.
Boris.
Posted on Jul 31, 2008
SOURCE: AEG Oko-Lavamat 86820 Update Error code C9
Hello. I got error code C9 on a LAVAMAT 86800. It pumped in water, and it pumps out water. You can select pump in or out....But the motor dont turn. It will not sentrifuge. So I bought new carbon brush'es on the net. One of them were totally wore down. Now it works. They lasted for 10 years.
Posted on Feb 05, 2010
  • 174 Answers
SOURCE: What does error code c9 mean?
c9 means there is no motor movement, typically worn out motor carbon brushes.
Posted on Jul 16, 2010
e-Guru
  • 3917 Answers
SOURCE: AEG Washing machine Oko Lavamat
The C9 on some AEG LAVAMAT models like the 71400, 72600,74620, 86720 and possibly others, is the same as the above F9, and is usually MOTOR BRUSHES WORN OUT. After replacement, you will need to clear the fault indication held in the PROGRAMMER PCB logic: With the Switch in the OFF position - Press and hold PRE-WASH and SOAKING buttons in at the same time, then turn the control knob to Short Spin. Wait one or two seconds and all the indicators should illuminate. Then turn the control knob to OFF. All the indicators should go out. Then try and use your machine as normal. This should clear the C9 error code. If it does not -check there may be another fault present.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on May 29, 2011
ftw1952
  • 10319 Answers
SOURCE: Hi can anybody help me
I recently had a situation where my AEG ?ko Lavamat Exclusive S Update washing machine was displaying error code "C9" on its' display. Normally this indicates that there is a mechanical or electrical problem with the motor (often the brushes need to be replaced).
In this case, there happened to be an over-sized load of clothes in the machine, so I wanted to try resetting the machine first before beginning to replace parts.
The solution is to put the dial in the off position, then turn the dial to the spin position while holding down the soak and pre-wash buttons simultaneously.
The procedure above is also necessary to reset the washing machine after replacing any parts once the error condition has occurred.
Posted on Jul 16, 2011
SF-P95JJ GIVE ERROR C9
Not "hitachi washing machine error code c9 what to do"
electronicsfurnitureinfo.com/.../hitachi-washing-machine-error-code-c9-...
Info about hitachi washing machine error code c9 what to do in Electronics ... What do you think about this washer Electrolux ZWT-61M, do you like the design?
Jul 28, 2015 | Washing Machines
I get a error 05 code on my precor treadmill C932/C964
Precor Error 05, Key Depressed at Power Up Probable Cause 1. A key is permanently depressed on the display.
2. An interface chip (IC) has failed in the upper PCA's keypad.
3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
Corrective Action
  1. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 is eliminated, the keypad is the cause and should be replaced.
  2. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 still appears, the upper PCA* is the cause and should be replaced. *Upper PCA's most commonly do not come with software. Remove the software (chip) from the existing upper PCA prior to replacement and install into the new upper PCA.
  3. Wipe away all liquid from the touch sensitive display. Reset power to the unit. If the Error 05 is eliminated, the liquid was the cause.
Precor Error Code 05
Apr 05, 2014 | Precor 932i Treadmill
Corrective Action
Precor EFX 546 05 stuck key
Corrective Action
Jul 02, 2013 | Precor EFX 546i Elliptical Version 4
Every time it rains our instantanious hot water system comes up with error C9 and C12
Before calling service technician, open following link for Rheem troubleshooting resources including contact and chat and typical manuals:
http://waterheatertimer.org/pdf/ErrorcodeTroubleshooting.pdf
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Error codes are start points for troubleshooting and can include long list of things including multiple causes.
Error code 12 shows 'condensation collar' and 'vent lengths' which are associated with the vent to outdoors. Changes in air pressure during low-pressure rain events MIGHT affect the venting and cause tankless not to ignite, and MIGHT cause excessive condensation. Improper condensation can rust out the heat exchanger without showing any signs of problem until the unit is ruined.
C9 is not listed. Contact Rheem, and then add a comment saying what Rheem suggests as solution for C9 error. This will help others in the community with same-similar problem.
Instruction manual recommends yearly maintenance by qualified service technician.
This maintenance would usually check all things shown in error 12.
Jul 18, 2011 | Rheem Tankless Hot Water Heater...
Error code 5
Corrective Action
Aug 11, 2010 | Precor EFX 546i Elliptical Version 4
Jul 14, 2010 | AEG Lavamat 72640 Front Load Washer
Error C9
Hello, to cancel the error C9 try to reset the machine by holding the start Button whilst turning the dial through 360 (from Off-2-Off).
Thanks
Jun 04, 2010 | Washing Machines
AEG 88730 UPDATE
For a solution to your dilemma, I recommend that you first replace the brushes, then to reset the error code C9 hold down the pre-wash & short wash together and turn the control knob from off to gentle spin. this sequence should clear the C9 from your washer.
Aug 18, 2008 | Washing Machines
Boris.
Feb 25, 2008 | Washing Machines
Washing Machines Logo
13 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
