Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
How to replace transmission cable on john deere JS63
Cable for transmission is very frayed at handle. mower not self propelled anymore. how do i remove/re-install or even repair this condition?
3 Suggested Answers
  • 760 Answers
SOURCE: i have a john deere js63 walk behind and the self
See this link and follow directions for servicing drive belt. Scroll down to section for your JS63
http://manuals.deere.com/cceomview/OMGC00397_B0/Output/GC00397B08.html
Posted on Jul 26, 2010
  • 2418 Answers
SOURCE: replace drive belt on John
Remove the black plastic cover at the rear of the mower. Here you will find the belt and transmission/pulleys. Remove the cutting blade, (please render the mower unable to start buy removing the spark plug). The belt will pull over the blade shaft and run to the trans. pulley. re-assemble and go cut some grass. But wait until its cooler outside. Hope this helps Fix ya up.
Posted on Jun 16, 2011
Spark plug gap on 8hp
20 thou or .51mm
Specifications - John Deere
manuals.deere.com/cceomview/OMGX21222_J2/Output/OMGX21222_J212.html
  1. Cached
  2. Similar
Model Series 121602, Intek. Horsepower 5 kW ... Spark Plug John Deere M78543, Champion RC12YC. Spark Plug Gap 0.51 mm (0.02 in.) ... JS63 and JS63C. John deer model 63 Google Search
Oct 10, 2016 | Garden
Why does a transmission on a self propelled john deere 14SZ mower ,18yr old, squeal?
Is it the transmission or is it the drive belt slipping.
That will make a squealing noise as well.
Is the fluid up where it should be?
Sep 28, 2014 | Garden
Lawn mower self propelled cable
John Deere Model JS38 Walk Behind Mower Parts
About half way down the page, left hand side. About $20.
Semper Fi,
Z
Feb 13, 2018 | John Deere Garden
John Deere JS-35 self-propel will not engage now. Help!
Check under the cover of the self propel unit to see if the belt is off the bearing or broken.
Feb 04, 2018 | Garden
Transmission does not work
cable to transmission could possibly b broken
May 13, 2012 | John Deere JA65 Self Propelled Mower
Hi, I have a JS63C self propelled push mower that is having trouble with the self proppelled device. At the first speed 1 you can feel some self propell. However, if you advance to speed 2 or speed 3 you...
Hi Jerry. Sounds like your transmission cable needs to be adjusted. Since 1st gear is easiest for it to move in, you probably have little pressure on the clutch. Take the cover off the back of the mower (Torx T25 or T30 can't remember at the moment.) The spring on the cable should be measured when relaxed (handle not being held) then when you squeeze the S/P handle, it should stretch the spring 10mm. A friend or a clamp will make holding the handle and measuring more simple. Adjust the bracket the cable clips into in front of the tranny to obtain the desired 10mm, and you should be under power again.
Jun 03, 2011 | John Deere Garden
I have John Deere JS63 self propelled lawn mover. It runs rough and loses power. I cannot mow a ful strip of the lawn as it stall. It is extremely nderpowered. It also runs a little rough when idling...
Have the valves adjusted for they are required to be adjusted every year refering by the owners manual. If the lash or gap is too big this will cause the symptoms your having. Also replacing the spark splug and changing the oil is recomended every year too
Jan 16, 2011 | John Deere Garden
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
381 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
