Question about Home
How to make a thermos - Home
I need new grates and heat deflector?
If you want to purchase the parts online this it the best place to shop. They have a large selection of Thermos grill parts.
http://www.clagrills.com/grillparts/thermos/thermos-grill-parts-home.htm
Mar 30, 2011 | Thermos 6000 Traditional Grill
I need a operators manual and parts list thermos gril2go
Ok, well you didn't list a model number so here is what I can give you: the first link below takes you to the Owner's Manual for a Thermos Grill2Go Fire+Ice Model No. 465630003:
http://www.appliancefactoryparts.com/content/pdfs/8794.pdf
This second link takes you to an illustrated parts list for Thermos Grill2Go Fire+Ice Model No. 465630003:
http://www.appliancefactoryparts.com/gasgrillparts/helpcenter/breakdowns/thermos/thermos-465630003.html
Oct 26, 2009 | Thermos Grill2Go Fire+Ice
Cleaning the thermos on the BUNN single TF DBC
For the thermos you can use a small amount of purocaff and fill the thermos with hot water, let sit over night then rinse with cold water a few times to clean you can also use a soft brush to clean while the purocaff is in thermos. Clean around the showerhead with a clean towel, or you can use a filter with a little purocaff and brew into thermos and clean both in one shot.
Mar 23, 2009 | Bunn BREWWISE Single TF DBC Coffee Maker
Thermos grill-to-go.
found thermos website which I was unable to do previously. Thank you.
Jan 30, 2009 | Thermos Grill2Go Gas Grill 4656110
Ducted gas hetaing keeps tripping the thermo fan switch. We seem to have plenty of air flow out of the vents and have replaced 75% of the ducting
It seems that you are saying the thermo fan stops first, thenfotre the safety limit switch shouts off the gas. This would mean the thermo fan motor is bad. It is overheating, which cuts out the thermo fan switch. The gas only shouts off because the thermo fan motor is bad.
Jul 23, 2008 | Heating & Cooling
Home Logo
476 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
