Question about Coleman Powermate Premium Plus 6250W Portable Generator
How to change 4 prong to 3 prong 220 volt - Coleman Powermate Premium Plus 6250W Portable Generator
Buy an adapter.
Posted on Jun 05, 2014
CAN a 4 prong plug be change to fit a 3 prong so it will fit my 3 prong receptical
Hi Anthony:
A 4 prong plug is intended to handle 220/240 volt and also 110.
It has:
- Red and Black - 110 each 220 total
- White (neutral)
- Green (ground)
You will need to shut off the circuit breaker for your receptacly and then determine what power supply you have available.
You MAY be able to change your receptacle to handle your appliance.
I would NOT change the plug on your appliance as it needs both the 110 and 220 functions.
If you are not ABSOLUTELY SURE what you are doing, get an electrician. Not doing it right could start a fire or present the danger of electrical shock. WHICH HAS THE POTENTIAL OF KILLING SOMEONE.
Cheers.
Jan 04, 2016 | Roper Washer Timer Control 3351734D A E B
How do I change the 3 prong wall mount to a 4 prong wall mount for a dryer?
Since you are asking, I would not suggest you try it. 240 volts is deadly. It would be easier to change cord to 3 prong and then add grounding wire from back of dryer to cold water pipe. The 4th prong is a ground connector, new standard for safety. Your house wiring may not be set up for it, or it might be. Unless you know what you are doing, let someone who does do it for you. Be safe pls
Mar 06, 2015 | Dryers
Or all blower motors on electric kenmore 80 series 220 or 110 current
Speaking of these United States, here's how that goes.
In this country, dryers are called 220, but they are really 110 twice!
So, on the back of the dryer is a plug with 3 or 4 prongs.
( hope you can get this from my description. )
On a 3 prong plug, the two "slanted" prongs are each hooked to 110 volt p service.
The "L" shaped prong is a ground.
If you have a 4 pronged plug, the two flat straight prongs are 110 volt each, and the "L" shaped and the round prong are both grounded.
FYI: Each of the 110 volt wires has a different function. One powers the motor, the other the heating element.
Be Blessed.
Jan 23, 2013 | Kenmore 659 Electric Dryer
Bosch Dryer front loading: I just recently moved and had to change my 3 prong to 4 prong cord and hooked up to new location. Dryer will not turn on or light up. Checked breaker box 4 prong terminal and new...
sounds like you wired it wrong really. Do you have 120 volts from either outside wire to the center wire on the unit, and 220 to both outside wires if not its wired wrong
Jul 08, 2010 | Dryers
Change a 3 prong plug to 4 prong
Is it an electric dryer or gas dryer? If it's a 120 volt gas dryer, then no, you need to keep it on a 3 prong cord. If it's an electric dryer, then yes it is possible to install a four prong plug onto it. Although it isn't recommended.
The main thing you need to know is which wire is ground. From the machine, it should be the green wire. On the plug, there should be on prong that is slightly longer than the other 3. The ground has to be the first one in the wall receptacle and the last one out. So the slightly longer one is where the green ground wire needs to be wired in. The other two wires are both power so it doesn't really matter which prong you wire those wires at.
Once again I'll remind you that it isn't recommended to convert 3 to 4 prongs like that. Just be careful and make sure you aren't touching any live wires.
Mar 26, 2010 | Dryers
Trying to hook a 3 prong hook up with 4 prong cord how do i do it?
A 3 prong plug is for 240 volt (hot-hot-ground) the 4 prong plug is for 120/240 volt (hot-hot-neutral-ground). If your device requires a 4 prong plug, it is not a good idea to connect it to a 3 prong circuit (you will create a possible lethal electrical condition). If your device requires a 3 prong connection, a 4 prong cord can be used by not connecting the neutral (white wire). If you have any questions, let me know.
clarkco
Mar 31, 2009 | Maytag Dryers
Truck quit running going down the hyway
distributor only sends pulses when turning,see if your coil is firing
Mar 28, 2009 | 1988 Chevrolet Silverado 2500
Swapping dryers
just remember a 3 prong cord the middle wire goes to the middle on the terminal block,the other 2 does not matter there both 120 volt,same if you have a 4 prong,the white wire goes on the middle on the terminal block,the red and black go on each side and the extra green gets mounted to the cabinet,,let me know how you do-mike
Mar 23, 2009 | Kenmore Dryers
Coleman Powermate Premium Plus 6250W Portable Generator Logo
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
