Question about Pioneer VSX-24TX Receiver
What is comcast remote code? - Pioneer VSX-24TX Receiver
Programing my xfinity remote
About 13,200 results (0.79 seconds) Search Results
    Can't program Comcast remote to Element TV - Comcast Help and ...
    forums.xfinity.com/.../XfinityTV...program-Comcast-remote...Element-T...
    Jun 6, 2011 - I have an Element 47" Class LCD 1080p 60Hz HDTV, ELGFT471. My remote is the Comcast Universal Remote - Red OK/Select Button.
    Comcast - what programing code to use with element tv find ...
    https://www.directly.com/.../comcast-what-programing-code-to-use-with-...
    what programing code to use with element tv find a code does not work ... Mymistake. ... Also found that Element has a remote update for some televisions.Missing: panel
    Element Tv Comcast Remote (Tut) - YouTube
    ? 3:19
    https://www.youtube.com/watch?v=ZDBr-hZN2AI
    Jan 20, 2010 - Uploaded by TopBreakX3
    The tut should be in your comcast remote paper help thing but heres the code if u cant see ... cant see clearly ( 10178 ) This is a vid on how to setup your comcast remote for your element lcd tv. ... Who cares program the Comcast remote already ... this was awesome,,,,my sisters tv is on the go now,,,thanx .Missing: panel
    Comcast Remote Codes for TV - Easy PC Tutorials
    www.easypctutorials.com > Comcast
Jan 27, 2016 | Element Electronics Televison & Video
Need codes for my comcast remote
Comcast Remote Codes ' Program Your Remote Control
https://customer.xfinity.com/remotes/
Help and support with your XFINITY® Remote, select your remote control type and get the support you need to enjoy your XFINITY® TV!‎Comcast - ‎Find Your Comcast Remote ... - ‎Control Multiple Devices with a ...
Remote Control Help and Support ' XFINITY® by Comcast
Jan 18, 2016 | Televison & Video
What is the Comcast remote code
Comcast has a web page with the newest codes. If the codes listed won't work, the page tells you how to code scan.
start here:
http://customer.comcast.com/remotes/ Comcast Remote Codes Program Your Comcast Remote Control
Dec 08, 2014 | Proscan 40" Class 1080P LED HDTV -...
Need Comcast 5-digit universal remote code for Sony BDP-S3100
Find Your Comcast Remote Control Programming Code
make sure your using those codes with the AUX button. Comcast does not have all remote codes for every electronic made though.
Feb 05, 2014 | Comcast Custom DVR 3 Device Universal...
Remote control code for a Comcast remote, Hisense LHDN32V tv, code in maual 10748 doesnt work.
here is a site that gives you all of the remote codes for your comcast remote. Scroll down to comcast and select the correct comcast model. It will show you all of the codes for everything
Good luck
http://remotes.com/store/codes_original.html
May 03, 2011 | Televison & Video
I can't program my Comcast remote for my Olevia model 232 S12, I have used all the codes comcast suggested to no avail
The Comcast remote will unlikely have Olevia codes available since its design age is much older than the set's. In addition, it may never have them since Olevia is bankrupt and probably of little interest to Comcast. You might check Comcast's website since the most recent codes will be available there.
Feb 15, 2010 | Televison & Video
Can't find symphonic remote code for Comcast remote
10180, 10171 those are the symphonic remote codes for comcast.
Jul 18, 2009 | Symphonic WF104
Sharp TV (LC52D64U) remote control Comcast cable (DVR) box ?
I had the same problem with my remote. I would enter the code and there would be no response from the remote. I looked up the manual for the other comcast remote and the codes are 5 digits instead of 4. Try codes 10093 or 11602. The reason why there is no response from your remote is because it is waiting for you to enter the last digit of the code. Hope this helps.
Dec 01, 2008 | Sharp Remote Control
Progamming Comcast remote
Go here, it has a viewable manual for the comcast remote and a list of codes. There is also a way to search codes listed. Haven't tried yet, but it can't hurt trying!
http://www.scribd.com/doc/202024/comcast-dvr-remote-manual
Sep 08, 2008 | Sanyo DS20930 20" TV
Program Comcast remote to operate Samsung 46"LCD
Not sure which remote you're using. We have comcast Motorolla box and Samsung LN-T4671F. the code I used was 10812 and it works perfectly.
Go here for more and check the comcast section:
http://www.remotecodelist.com/remotes/
May 18, 2008 | Samsung TV Remote Control
Pioneer VSX-24TX Receiver Logo
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
