Question about Poulan Pro Pp2822 Gas-powered 22" Dual Side Hedge Trimmer - Authorized Dealer
Why won't the switch turn the trimmer off
Disconnected spark plug
    Sergeant:
  • 384 Answers
Bad switch
xxxxxxxxxxxxxxxxxxxxxxxxx
Posted on Jun 04, 2014
Stihl fs 80 trimmer, replaced carb, air filter, spark plug, ignition coil. still doesn't start. Next? not getting spark from plug
Loosen coil screws, adjust coil to magneto flywheel magnets with a double sheet of common paper, tighten screws, so that paper will pull out without tearing. That will give you the best chance for a good spark, with all you have done. Pull spark plug out , put top of plug back in spark boot.......crank ovr with rope, and ground spark plug on top of motor(metal), observe the blue spark. If none, check the short wires for any breaks from coil to switch. You can open handle and take out switch, if nothing else works.....then try and start. The wires are just to break the ground, to turn off motor. Can choke motor to stop.
Jul 29, 2016 | Stihl Garden
Check spark?
Benjamin, remove spark plug, attach plug wire onto plug, hold end of plug against cylinder head or a metal fastener that you know is going into engine for good ground. Make sure engine switch is in the on position, now pull engine over, observing the gap in plug for spark. If no spark get a new plug and try.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to check for Spark Plug Fire in any engine
How to Check the Spark Plug of Trimmer or Edger
Homelite String Trimmer Won Start No Spark
Jun 17, 2016 | Garden
Have no spark to plugs
Troubleshooting
If Check Engine will not start ·Battery has low voltage.
·Loose or corroded battery connections.
·Fusible link is melted.
·Spark plug wire is loose or disconnected.
·Faulty spark plug or coil.
·Fuel shut-off valve turned off (if equipped).
·No fuel or improper fuel.
·Plugged fuel filter.
·Defective starter solenoid.
·Open-circuit in wiring.
Nov 27, 2015 | John Deere 2013 Gator Traditional TE 4x2...
Replaced head gasket now there's no spark,
Does anything work? It sounds like you have a flat battery which has gone flat due to the time it took you to change the head gasket.
No spark. No power to ignition system, disconnected wires to coils, disconnected or incorrectly seated spark plug leads, distributor cap off or not seated properly.
Motor not turning over. Flat battery, blown fuse, faulty start solenoid, faulty starter motor.
Oct 02, 2015 | Cars & Trucks
MY WILDFIRE WF 1200 HAS VERRY LITTLE SPARK WONT START
Check for faulty spark plug, fouled spark plug, loose or disconnected wires, broken or shorted spark plug wires, faulty ignition pulse generator, faulty ignition coil, faulty engine stop switch, faulty ignition control module or some others.
Work through these from the start
Oct 16, 2014 | Motorcycles
My RST210 2 stroke petrol strimmer won start it has a spark at the plug also the plug is flooding so fuel is getting through but non start ? Great full for any ideas
Often it's the easiest thing that stump us. Try changing the spark plug first. Sometimes a spark plug just won't fire under load, i.e., while it's in the cylinder but will spark if you have it removed. There are checkers for this, but it's a lot less expensive to just replace the spark plug. Do that first and let me know.
Sep 28, 2014 | Makita RST210 2 Stroke Petrol Line Trimmer...
I have a broken spark plug wire. Can these be replaced?
Steve:
Yes, the spark plug wire can be replaced, but you have to buy the ignition coil as the spark plug wire is hard wired into the ignition coil.
If the metal spark plug connector has disconnected from the spark plug wire, the connector can be replaced, but if the spark plug wire has been cut you'll need to replace the ignition coil.
Nov 29, 2013 | Homelite 200 mph 400 CFM Gas Blower...
Changing spark plugs
Spark plugs look like this:
They are screwed into the engine head, and each has a wire (approx. 7-8mm or .25in) attached to the top of it. A dedicated spark plug wrench or socket is needed for removal of the plug after the wire has been disconnected from it.
Sep 29, 2013 | 2002 Mitsubishi Montero
Gentron pro2 6000p has no spark
With small engines, ignition is magneto. Four things can cause a lack of spark: (1) Faulty plug - try a new plug; (2) Bad, shorting, or disconnected spark plug wire - check for high voltage from ignition coil; (3) Bad ignition coil - check for low voltage at the coil input wires; (4) Magneto failure - the pickup coils next to the flywheel may be shorted, loose, or disconnected, OR the magnets on the flywheel may have lost their field or come out. I would troubleshoot this problem by checking and eliminating each of these possibilities in the above order. If all of the first three check out good; I'd have a mechanic check the magneto because this requires at least partial disassembly of the motor.
Nov 17, 2012 | Gentron 6000 Watt Propane Generator with...
Poulan Pro Pp2822 Gas-powered 22" Dual Side Hedge Trimmer - Authorized Dealer Logo
59 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
