Question about Video Game Consoles & Games
I have a xrocker model no51231. the battery pack insert has a fried circuit. can you get replacement battery boxes for them?
How do you remove and reinstall bartery-pack on Norelca 6846xl
You will find the correct battery pack for model 6846XL at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
To replace, you will need to remove the back cover by removing the two screws. You may need to extend the long hair trimmer to get to the second screw. Take off back cover to access inside. There are two metal clips that must be unhooked for better access. You can unsolder the batteries from the circuit board but for easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries with small needle nose pliers rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
If you are not able to do this yourself, you can have shaveroutlet.com do it for you. See link below
http://shaveroutlet.com/shaver-replacement-parts/professional-battery-replacement-for-most-models-p-374.html
Feb 20, 2011 | Norelco 8170XLCC Electric Shaver
I was trying to insert the ac adaptor to the outlet of the telescope. It seems that it was short circuted and a smoke came out & I smell something burned. Is there a sort of a fuse that will prevent...
No, you burned out some of the circuits on the internal power board. Meade can repair the scope but you must send it to them.
That's why I always use a 12 volt battery pack and NEVER use the 110volt adapter
http://www.meade.com/support/index.html Meade customer service.
Dec 08, 2010 | Meade ETX-125EC (500 x 127mm) Telescope
My Acer Aspire One model D250 cannot power on even if i already put the power adapter.Is it the battery pack problem or the motherboard?
Firstly insert the battery. When you plug the PSU into the machine does a charging light turn on? If not then check the fuse in the mains plug as it may have blown. If the fuse is OK then you may have a defective PSU, although the motherboard could also be defective. Try a new PSU to determine if which component is faulty.
Now remove the battery and insert the PSU. Will the machine turn on or do any power lights illuminate? If power lights illuminate and the machine will not turn on then I would suggest the motherboard is at fault. If the machine turns on briefly the turns off before displaying the splash screen then I would suggest the RAM, CPU or motherboard is at fault.
If the unit works without the battery installed then it is probably a battery problem, although it is possible the charging circuit n the motherboard is fried.
Hope this helps,
www.PuterCare.com
Jul 03, 2010 | Computers & Internet
Need batteries and instructions for replacing
You will find replacement battery pack for model 5821XL on shaveroutlet.com. See link below.
http://shaveroutlet.com/shaver-battery-pack-for-most-norelco-more-p-278.html
To change batteries, you will need to remove the two screws on the back to take off the back cover. You will then have access to th batteries.
Batteries are soldered to the circuit board. You can unsolder to remove but I would suggest that you carefully break the tabs off of the old batteries. This will leave the old battery tabs connected to the circuit board. You can then just solder the new batteries to the old tabs. This way you dont have to solder irectly to the circuit board.
If you are unable to repair the shaver yourself, shaveroutlet.com can do it for you. See info at link below
http://shaveroutlet.com/professional-battery-replacement-for-most-models-p-374.html
Apr 12, 2010 | Norelco Reflex 5821 XL Electric Shaver
How do we connect xrocker chair to xbox360
There should be an adapter that came with your xrocker chair. Plug in the standard sound outputs into the adapter and plug the other end into the chord that connects to the chair.
Feb 14, 2010 | Pyramat Sound Rocker Gaming Chair
Won't charge
Either the battery pack is fried or the ribbon cable that attaches the battery to main circuit board is loose or broken.
Feb 07, 2010 | SanDisk Sansa Fuze MP3 Player
How do I insert batteries in the music box
if it's a long slim hole try use the coin.
Good luck
Jun 14, 2009 | Graco Pack 'n Play
Hughes direct tv receiver (director pack)
get new ones i just had 2 boxes replaced 1 was sd-hbh and the other was a hi-def box both were fried cause the nit wit that set up the system didn't ground the dish and we got a lightning strike that fried them.... i would call direct tv or whoever your sat provider is because mine were replaced for free with 2 brand new boxes.... and you should check to see if your dish is grounded it will usually be grounded to a water pipe somewhere in the area of where your multi-switch is located
Jul 22, 2008 | Hughes SDHBH DirecTV DTV Receiver
Battery is dying
Nope - that battery is completely rechargeable. There is a small possibility that the battery could have experienced some small corrosion, but this is a slim possibility. The documentation suggests that this model has an external battery pack, and comes with the following instructions:
Slide the external battery pack cover to open it.
Insert four AA batteries, be careful to observe the correct polarity. Slide the
cover back into place.
Inserting external battery pack
Twist the external battery pack to UNLOCK direction. Insert the H300 to the
system slot of the external battery pack.
May 31, 2008 | iRiver H340 MP3 Player
Batteries show charged but no pwr
Clamp one side of [power line of your charger insert baterry pack,if amphere increase the battery pack was ok.select battery good one still run impact diver insert to the charger amphere increase good charger and battery pack. Two only the problem Battery pack or charger, if charger not function , the power transistor will be replace or buy new charger.
Dec 25, 2007 | Makita 18V LXT Lithium - Ion Cordless...
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
