Question about Miele Washing Machines
Softener is not pumped in - Miele Washing Machines
Installation
Hi David,
Your water softener doesn't have a pump in it. Your home's water pressure comes either from your municipality or from the pump in your well (or basement) which has the power to move water to the top of your building, so yes, your softener will drain overhead, even a couple of floors. There is internal friction in any drain line, so your softener manual likely advises that if your 1/2" drain line is more than 25 feet long you ought to install a 3/4" drain line to reduce back pressure over that longer run.
Dec 21, 2013 | Kenmore 300 Series Water Softener
F3 error on my whirlpool washer
The problem with the fabric softener not dispensing is not likely related to and F03 error code due to the washer not draining.
For the dispenser problem, I recommend that you pull the dispenser drawer out and clean it thoroughly.
The fabric softener dispenser works on a siphoning principle.
Make sure that the siphon hole in the dispenser is clear and not restricted or plugged.
You can fill the fabric softener compartment with water and make sure that it is siphoning properly while you are cleaning it.
Make sure that the cover is properly replaced on the fabric softener dispenser when the drawer is replaced in the washer.
You can use the diagnostic test described below to test the fabric softener dispenser.
If the softener dispenser does not fill and dispense properly, you could have a failed dispenser valve, a failed control board or a wiring failure between components.
You indicated that you tested the pump and that it is good. You could have a clogged drain hose or a clogged washer drain that would prevent the washer from draining.
You could also have a failed drain pump even though it runs. If the impeller is jammed or damaged, it will not pump out the water in the washer.
You will likely need to unplug the washer and drain the water out of the tub using a wet/dry shop vacuum.
To check the pump and drain hose at the bottom of the washer, remove the bottom front service panel and remove the drain pump. You may find a clog or restriction in the drain pump or connecting hoses. If the drain pump is damaged or will not work, it will need to be replaced.
Oct 11, 2010 | Whirlpool Washing Machines
Kenmore electric range gets a f1/f3 error code
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 10, 2010 | Kenmore Slider/Casement Air Conditioner
Error code FO3 Kenmore washer #417.44072300
Oct 14, 2009 | Kenmore Washing Machines
Error message E3 on my Kenmore Elite Dryer
Oct 12, 2009 | Kenmore Elite 45986 Front Load Washer
I have a F 03 code.
Hotpoint aquarius wf 630 error code f-03 how do i fix
Aug 14, 2009 | Washing Machines
Error code 03 what does this mean
For the dispenser problem, I recommend that you pull the dispenser drawer out and clean it thoroughly. The fabric softener dispenser works on a siphoning principle. Make sure that the siphon hole in the dispenser is clear and not restricted or plugged. You can fill the fabric softener compartment with water and make sure that it is siphoning properly while you are cleaning it. Make sure that the cover is properly replaced on the fabric softener dispenser when the drawer is replaced in the washer. You can use the diagnostic test described below to test the fabric softener dispenser. If the softener dispenser does not fill and dispense properly, you could have a failed dispenser valve, a failed control board or a wiring failure between components.
You indicated that you tested the pump and that it is good. You could have a clogged drain hose or a clogged washer drain that would prevent the washer from draining. You could also have a failed drain pump even though it runs. If the impeller is jammed or damaged, it will not pump out the water in the washer. You will likely need to unplug the washer and drain the water out of the tub using a wet/dry shop vacuum. To check the pump and drain hose at the bottom of the washer, remove the bottom front service panel and remove the drain pump as shown in the second image below. You may find a clog or restriction in the drain pump or connecting hoses. If the drain pump is damaged or will not work, it will need to be replaced.
Jul 09, 2009 | Washing Machines
Fault code
Apr 12, 2009 | Washing Machines
Washing machine is showing F-03 on the digital display
Mar 21, 2009 | Washing Machines
Washing Machines Logo
13 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
