Question about Poulan Pro Pp2822 Gas-powered 22" Dual Side Hedge Trimmer - Authorized Dealer
Switch won't turn trimmer off.disconnectd spark plug
Why won't switch turn my trimmer off?
Stihl fs 80 trimmer, replaced carb, air filter, spark plug, ignition coil. still doesn't start. Next? not getting spark from plug
Loosen coil screws, adjust coil to magneto flywheel magnets with a double sheet of common paper, tighten screws, so that paper will pull out without tearing. That will give you the best chance for a good spark, with all you have done. Pull spark plug out , put top of plug back in spark boot.......crank ovr with rope, and ground spark plug on top of motor(metal), observe the blue spark. If none, check the short wires for any breaks from coil to switch. You can open handle and take out switch, if nothing else works.....then try and start. The wires are just to break the ground, to turn off motor. Can choke motor to stop.
Jul 29, 2016 | Stihl Garden
Check spark?
Benjamin, remove spark plug, attach plug wire onto plug, hold end of plug against cylinder head or a metal fastener that you know is going into engine for good ground. Make sure engine switch is in the on position, now pull engine over, observing the gap in plug for spark. If no spark get a new plug and try.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to check for Spark Plug Fire in any engine
How to Check the Spark Plug of Trimmer or Edger
Homelite String Trimmer Won Start No Spark
Jun 17, 2016 | Garden
What can be making my edger turn off right when it sounds as though its going to start?
A faulty on off switch can cause this.spark plug foulage.fuel blockage.loose spark lead.broken power feed to spark.hope this helps
Aug 14, 2014 | McLane 3.5 HP Gas Edger & Trimmer...
My 2003 Husqvarna 326HD60 hedge trimmer was starting ok, but today it failed to start. They is fuel and the plug is wet, but it appears not to have any spark. The switch is set in the off position, but how...
Put switch in 'on' position, remove the spark plug and connect it to the HT lead and earth out the side of the spark plug, pull over the engine to see if you are getting a spark. Check the timing gap between the ignition module and the flywheel. 0.25 filler guage
Oct 23, 2011 | Husqvarna 28cc Gas Line Trimmer
My wipper snipper has no spark, Ihave bridged out the switch to make sure its not the switch, new spark plug ,correct gap .
The switch is a kill switch that grounds out the spark, at least that is how mine is. So assuming you have it correct, and new plug, that leaves the ignition coil. Only component left.
Sep 18, 2011 | Homelite Mighty Lite Lawn Trimmer
Turn but not start
if you have spark, then the carberator is plugged, replace it. Pull the spark plug, ground it to the engine, pull rope, whatch plug for spark. if no spark, remove kill switch wire from coil. pull rope agin, if you have spark, kill switch is bad. if stil no spark, you have bad coil.
Sep 24, 2010 | Craftsman 25cc Gas Line Trimmer
Having a problem starting my Shindaiwa T22 Weed Eater.
take the spark plug out and pull the engine over with the spark plug in the wire and ground the plug to the trimmer and see if it sparks. if not flip the switch the other way and see if it sparks then you shall know.
May 02, 2010 | Poulan Weedeater/Electric Trimmer 4.1 Amp
No Spark
put the kill switch back frist using a test light you can check for spark your coil is set @00.8tm..... good luck
Aug 15, 2009 | Troy Bilt Tb70ss Gas Trimmer
Have a mucculoch line trimmer that does not get spark
Can only be a few things 1, bad switch,2,bad wire to switch 3, bad module,do you have a spark tester? how are you checking it?
May 12, 2009 | Garden
Troy Bilt 4-cycle trimmer won't stop!
Check all wire connections,where they connect to the switch- to the motor-and to each other sounds like a bad ground
Dec 17, 2008 | Troy Bilt Tb70ss Gas Trimmer
Poulan Pro Pp2822 Gas-powered 22" Dual Side Hedge Trimmer - Authorized Dealer Logo
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
