Question about VeriFone Omni 3700
Modem profile not set - VeriFone Omni 3700
  • Kelli Sims Jan 07, 2015
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
The modem profile problem is a hard one. The I/O board or the main board or even both may be damaged. Until the unit can be opened this damage can not be assessed. The cost of fixing this problem may be more than this unit is worth. I will be interested in helping you determine if you need to replace it. Frank @ 775-338-6634
Apr 26, 2014 | VeriFone VX510
Verifone Vx570 given an error Modem Profile Not Set?
error modem profile not set appears when your Verifone VX 570 modem profile is not properly loaded or has been errased due to Tamper error or Bad RTC. Reloading back the modem profile will sometimes fix the error, but there is also a chance that your I/O module (form where you connect the power and telephone wire) is also bad, thats needs to be repaired or replaced. Call (775)358-2922 ask for Randy. Thanks.
Backside of the I/O module of VX 570
Jan 18, 2012 | VeriFone VX570 Credit Card Terminal (Dual...
Sir MMX 310G 3G usb modem, when i was connected, the message shows only "dial failed". My profile setting is right, but what's the problem.Please solve the problem. Connection Profile...
there would be some software problem.......... please reinstall the software and use your device......... dont forget to vote for me...........
Apr 04, 2011 | Computers & Internet
All i can see is linksys and not the wireless name i set up. i have reset the modem and wireless router
I suppose you set-up the new name on the routers setup page. Does it save the new name when you changed the ssid? if it does, then try refreshing the list on your wireless computer. The linksys name that you may be seeing on the computer is a profile name. In that case, try deleting all profile and refresh the list again.
Apr 18, 2010 | Linksys WRT160N Wireless Router
How to check the setting of external modem dlink DFM 562 e++ via hyperterminal
Try using "at&v".
This will show you the active profile and stored profiles
You will need to understand the Modem "S" register settings.
Jan 22, 2010 | D-Link DFM 562E (dfm-562e) Modem
Trying to set up xbox live.
you need to make an xbox live profile not mtu for offline. You have to make a new profile.
Jun 23, 2009 | Microsoft Xbox 360 Console
Can not send or receive multimedia messages.
Maybe internet is shut off on your phone?
Here are the internet settings for Cingular: Internet Setting Cingular:
Profile Name: Cingular
GPRS setting:
APN: wap.cingular
User Name: WAP @ CINGULARGPRS.COM
Password: CINGULAR1 (ALL UPPERCASE)
Time Out: Off
Primary Gateway IP: 66.209.11.61
Port: 9201
Secondary Gateway IP: 0.0.0.0
Port: 0
DNS Server:BLANK
CSD setting:BLANK
Dial in number NONE
Query at Logon: (NO CHECK MARK)
User Name
Password
Baud Rate Auto
Line Type: ISDN
Time Out Off
DNS Server:
Then go to your browser and enter the following settings:
Profile Name: MEdia Net
Homepage: device.home
Network Link: Cingular
MMS Settings:
Profile Name: MMS over HTTP
MMSC: http : //mmsc.cingular.com/ (No Spaces)
Max Sending Size: 30K
Network Profile: Cingular
and T Mobile: Internet Setting T-Mobile
T-MobileWeb Settings:
Primary IP Address: 216.155.165.050
Secondary IP Address: (Blank)
Access Point Name (APN): wap.voicestream.com
Data Bearer: GPRS
Profile Name: GPRS
Username: (Blank)
Password: (Blank)
Home Page: http://wap.myvoicestream.com
Picture Messaging Settings:
Multi-Media Service Center (MMSC) Address: http://216.155.174.84/servlets/MMS
Validity Period: 72 hours
Hide ID option (if option exists): set to off, no, or disabled
and Fido: Internet Setting FIDO
Profile name: FidoWAP
GPRS setting:
APN: wap.fido.ca
Username: fido
Password: fido
Timeout: 15 minutes
Primary Gateway IP: 205.151.11.11
Port 8080
Secondary Gateway IP: (blank)
Port: (blank)
DNS Server: (unchecked)
CSD Setting:
Dial in number: (blank)
Query at logon: (unchecked)
Username: (blank)
Password: (blank)
Baud Rate: Auto
Line type: Modem
Timeout: Off
DNS server: (unchecked)
Then press Save.
To get MMS working (what I haven't included are the blanks and all boxes should be unchecked unless specified)
Setup-->Data Network
Profile Name: Fido MMS
APN: mms.fido.ca
Username: fido
Password: fido
Timeout: 15 minutes
Primary Gateway IP: 205.151.11.13
Port: 8080
Baud Rate: Auto
Line type: Modem
Timeout: off
Then click SAVE.
THEN
Messages-->Service Setup-->Multimedia Message
Default profile: FidoMMS
(all other settings are to your preference)
Tap the box beside Default Profile and ensure that FidoMMS is the default profile.
Settings for MMS profile goes
Profile name: FidoMMS
MMSC: http://mms.fido.ca
Max Sending Size: (your preference)
Network Profile: Fido MMS
and Rogers: Internet Setting Rogers
Proxy Name: Rogers MMS
Proxy Address: 172.25.0.107
Access Point: Rogers MMS
Home: ((Set whatever page you like here))
Port Number: 8080
Authentication Type: HTTP-BASIC
User Name: media
Password: mda01
Access Point Name: Rogers MMS
APN: media.com
Authentication Type: PAP
User Name: media
Password: mda01
DNS: <>
Linger Time: 180
MMS Accounts (Main Menu -> Messaging -> Messaging Settings -> MMS Settings)
Profile Name: Rogers MMS
Proxy: Rogers MMS
Relay Server URL: http://mms.gprs.rogers.com
Feb 19, 2009 | LG Shine KE970 Cellular Phone
Acer Aspire5100 laptop modem disappears from hardware profile!?!
Could it be the screen saver when you said about Vertical lines.
I mean ,your computer was set to a certain period of time that if it stay idle, then the screen saver program will start to run.
takecare.
Apr 19, 2008 | Acer Aspire 5100 Notebook
Computer cant connect to internet
set up a new internet connection and configure the modem which yuou are having
Feb 07, 2008 | Conexant All 56K Modems: Amigo V.92...
Retail Supplies Logo
95 people viewed this question
Top VeriFone Retail Supplies Experts
danielle yancer
danielle yancer
Are you a VeriFone Retail Supply Expert? Answer questions, earn points and help others
