Question about Sennheiser HDR 130 Consumer Headphones
How do I change batteries for plantronics calisto pro series D150
Base does not find headset
On page 41 of the user guide link below you'll have the instructions on how the base and the headset can get reacquainted.
Plantronics CS70 User's Guide
Good luck from Headsets Direct!
Nov 30, 2011 | Plantronics Calisto Pro Series Home Phone...
How do you replace the batteries
There is no battery in the base unit, there is an AC adapter for charging the headset. The headset has a battery but that is not replaceable. You can try to get just the headset, PN 84321-01 (see link below).
Plantronics Voyager Pro Replacement Headset
Sep 02, 2011 | Plantronics Voyager 500A Deskphone Adapter...
How to replace battery?
Just put the tip of a pen into the opening at the bottom of the handset that looks like hole. The cover will pop off.
Dec 02, 2010 | Plantronics Calisto Pro Series Cordless...
I need to no how i can track a owner of a telephone number
one thing you can do, write the number down and track which network provider is that. then write down a complaint on this number submit it to help desk for that network and ask a request for ownership trackdown. they can easily trace it cause it is land or fax line and mostly if it is registered, they can immediately give you the address.
take care..
Mar 11, 2010 | Plantronics Calisto Pro Series Cordless...
Can not get my plantronics calisto phone to par with the headset or the base
We have two of the Calistro Pros and they will lose contact all the time for no apparent reason. Most of the time when I walk to far away from the handset they will beep and there will be the "OUT OF RANGE" will display. I have found that while sitting next to the phone press the ear piece switch straight in. You will hear a series of tones either getting louder or going from high to low. Wait a few seconds after pressing the ear piece switch and then look at the hand set. the No Headset circle should dissaper. If not depress the earpiece switch and listing for the tones again. Wait again and they will find each other. If this does not help you then I think you have a phone issue. I use my for 8 hours a day and have to do this several times a day. I hope this helps.
Apr 09, 2009 | Plantronics Calisto Pro Series Cordless...
My Calisto Pro drops SKYPE calls
Did you install the PersonoCall software (bundled with Calisto Pro)?
Basically PersonoCall is the one in charge of handling all the VoIP applications.
Jan 19, 2008 | Lands Phones
Sennheiser HDR 130 Consumer Headphones Logo
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
