Question about Goodman GMS90703BXA Heater
Date code for a Broan gas furnace Serial# kgd120102717
When turn on my fire place heater heats for about 5 sec. Then a little white light flash's it turns the in heat colls off blower never turns on
How to Fix a Gas Furnace: Furnace Blower Does Not Turn ...
? 2:51
https://www.youtube.com/watch?v=XjgLbLYsuHw
Jan 18, 2012 - Uploaded by About.com
If the blower in your gas furnace won't turn off, it can cause major problems with your home heating system ...
Electric furnace blower motor doesn't turn on once in a while ...
terrylove.com > Forums > HVAC Heating & Cooling
Mar 7, 2014 - 16 posts - ‎5 authors Hi everyone, I'm having a problem with my Broan Electric furnace lately. Sometimes the blower motor doesn't want to switch on. Sometimes it ...
Oct 24, 2015 | Heating & Cooling
Furnace wont work
Have to know the model and serial of the furnace.
locate code list usually inside or on the back of a door.
Operation sequence= call for heat--inducer blower motor--makes pressure switch--signals board to bring on hsi--after a set time gas valve opens and you have ignition--main blower motor comes on after a set time
Feb 14, 2014 | Coleman 7990-319p Evcon Gas Furnace...
Furnace error code 42
have to know the model and serial of the furnace.
Feb 12, 2014 | Heating & Cooling
System lockout code keeps flashing and furnace won't start
Jan 21, 2014 | Heating & Cooling
Request the date of maunfacture of my Hunter Comfort RB 115 oil fired hot air furnace, the first serivce date from the furnace oil supply company service man was 20/05/97. ULC - 742 Thanks
If you have or can find the serial number of the furnace, you can contact Hunter directly and they can tell you the manufacture date. Their contact information should be on the Manufacturer's data plate on the furnace.
Mar 07, 2011 | Heating & Cooling
How old is my Coleman Evcon Furnace, Modle Number: DGAT056BDE? I can't seem to find a Manufacturing date sticker. It was claimed to only be a year old, now living here a year it would now be 2 years old. ...
The Serial Number would really help in defining how old your Coleman furnace is. The model you have is used predominantly in manufactured housing. To find the Serial Number, you will need to remove the upper shroud of the furnace. There should be a sticker or plate on the back of that shroud of just inside the housing of the furnace, that will give you the Model # & Serial #. Armed with that, you can do a little detective work, as to it's age.
Mar 03, 2011 | Coleman Heating & Cooling
I have an older Luxaire furnace: Model # GSU137FF Serial # NAJTE Input 137000BTU out 110000Btu Natural GAS. What is age of unit, are parts available, whats is its efficiency rating. Should I fix or...
Your effeciency rating is 80%. Divide your output capacity 110,000 by your input capacity 137,000 and that will give you your effeciency.
The manufacture date is usually in the serial number.
You need to go to Luxaire.com and they can answer that question for you.
As far as parts there be parts available.
Fix or replace, if you are happy with the equipment and not really having a lot of problems, you may want to keep it. The newer equipment is more efficient, so if you think your gas bill is to high or you want to save some money on your gas bill, you may want to replace it.
Apr 09, 2010 | Heating & Cooling
The swich on the stove fan has stopped working
Hi
I called the company, they had the spare part and is shipping it shortly. I have some friends who will be able to help me install it.
Thank you
Anne
Jan 09, 2009 | Stoves Broan 40000 Series Hood - 30" Hood...
Goodman GMS90703BXA Heater Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
