Question about Samsung 22" TFT SYNCMASTER P2250 LCD Monitor
Is it possible to replace the backlit power supply wires on a Samsung P2250 LCD Monitor screen? If so, how do I access them on the screen side? Harness connector removed from power supply, cable clip removed...now what, disassemble screen? When I power up, screen flashes on, goes black (led indicator remains red). After removing cover, I identified what seems like a short right around where the backlit power supply wires enter the screen's metal case. I can produce the same sound by loosening the harness for the other set of cables- although that move makes the sound originate at the harness. So, I feel 90% certain that these wires are simply loose or damaged at the point of connection to the screen- but have no idea how to go about safely opening the metal screen case, or if that's necessary. Anyone have any success with anything like this?
    Top Expert:
  • Samsung Master
  • 22,167 Answers
Posted on May 16, 2014
  • Oleg Degenshein May 16, 2014
    Thanks! I was actually able to figure out the disassembly, and identify the broken part. One of the backlight tubes (long tiny glass tube that looks like a flourescent bulb- correct term?) is broken. Do you know where I can find a replacement backlight assembly?
    (just the one tube cracked but looks like I will need to replace the entire tube enclosure that holds them to the glass plate and connects to the power supply)
SOURCE: Samsung v20 disassembly
After removing the screws, lift the keypad by releasing the two latches just below the ALT key and WINDOWS key. Two more screws are hidden beneath the keyboard. Hope this helps
Posted on Sep 05, 2007
SOURCE: Dell Inspiron 1000 Disassembly
The teardown information from rbrown67 was very accurate and easy to follow. It helped tremendously in tearing down my machine to replace the AC plug.
Posted on Mar 26, 2008
  • 4 Answers
SOURCE: Dell Inspiron 1000 laptop LCD screen blackout
I HAVE POSTED THE SOLUTION FOR THIS BEFORE. ON THE LEFT REAR THE SCREW FROM BOTTOM OF UNIT TO THE LCD. LOOK INSIDE WHERE THE TOP AND BOTTOM GO TOGETHER YOU WILL SEE A PIECE OF ALUMINUM TAPE IF IT STICKS OUT PAST THE BOSS TOWARD THE PC BOARD. WHEN YOU MOVE LCD THERE IS ENOUGH FLEX FOR IT TO SHORT TO PC BOARD. TRIM THIS OFF AND YOUR PROBLEMS WILL BE SOLVED. CAUTION REMOVE BATTERY AND UNPLUG FROM AC BEFORE THE ABOVE. BOBBY
Posted on Jan 09, 2009
mdavinci
  • 20 Answers
SOURCE: CMOS Battery dead, No Post, No System Beeps
bloody hell! All the ones I have used (IBM, Compaq and Dell) have clear access to the battery!
That sounds very frustrating!
My Solution, drop kick it out the window if you have to replace another!
Posted on Mar 18, 2009
tommya300
  • 724 Answers
SOURCE: Fujitsu Amilo Pi 1505
With so many questions that really relate to your dexterity and skills! Who can best answer your questions! Yea that person in the bathroom mirror is the only one that will show the fortitude and trail blaze the way. Then boast of their success!
Posted on Mar 25, 2010
Samsung UN55EH6000 has audio, but no backlight LED as seen with flashlight test.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Feb 29, 2016 | Samsung Electronics UN55EH6000 - 55in...
Samsung sync masser p2250 issue
caps in power supply section are shorted out. This fools the monitor into thinking it needs to power into low mode. This is very common. Look at caps and see if they are flat on top.. if you see rounding or any fluid discharge at all, they are bad. These always go bad this way. it is on the power board only... you can take them off and read with a cap tester to see if they are the right capacitance if you wish too. You can roughly do this with a ohmeter too.. but can not see values though. Most good meters have a capacitance meter though.
May 25, 2014 | Samsung 22" TFT SYNCMASTER P2250 LCD...
Does anyone know how to disassemble a Samsung sync master p2250 22 inch? last night it smelled lime burnt Plastik and I want to take a look, but there are no screws ot smth. like that....
It uses internal plastic clips to hold the halves together. Gently pry the edges apart until you find a clip. While holding the edges apart, release the clip. You'll find about 12 of these clips hidden internally. Good luck.
Mar 19, 2014 | Samsung SyncMaster P2250 22 inch LCD...
How do I unlock the monitor, given that I have applied all the usual button pushing solutions bar 1?
If you see a picture but then it fades out after a few seconds then the issue is with the backlight power supply in your monitor, This could be a single component failure or more serious.
Mar 07, 2012 | Samsung SyncMaster P2250 22 inch LCD...
I have Samsung SyncMaster 2233BW 22 inch LCD Monitor, i used it for 3 months already. after sometimes it goes black after 1 second. i switch off and on but still it goes black after 1 second even the power...
nokerns, Internal ac to dc power supply problem might be cause of your "black screen of death" that plagues all brands of "cold-cathode-fluorescent-lamp" back-lit lcd monitors. If unit is covered by Samsung warranty, then contact Samsung and complain about "premature failure" of the unit's power supply and see if they will do a swapout for same model unit. As a side-note, you should also learn how to do the "black-screen-of-death" flashlight test that every owner of a ccfl backlit lcd monitor should know how to perform and understand the results of the test. Do some reading in the FIXYA profiles of "budmrtn" "buddymc" "12fixlouie" and other lcd monitor tech's here on fixya and also view some DIY repair video clips on YOUTUBE. You will truly be amazed to find out how prolific the BSOD problem is in the lcd monitor industry. Please let other know what you will do to solve your monitor's problem by doing a reply to this response. If this was of some use to you then please rate this response on fixya. Bye for now. 12fixlouie
Jul 21, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
Samsung Monitor 731B needs to be turned on and off several times before it will hold the picture. It appears like a flourescent-like starter. It blinks on and off. After about 3 or 4 off and ons it holds...
Look at the power supply for bad caps first, look for caps with bulging tops/seals, see example of failed SAMSUNG monitors due to bad capds: http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can guide you further.
Feb 09, 2010 | Samsung SyncMaster 731B 17" LCD Monitor
Samsung 22" TFT SYNCMASTER P2250 LCD Monitor Logo
73 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
