Question about IBM 41Y9310 0x1x8 Ip Console Kvm 8-Ports Switch W/Rails P/N: 41Y9310 -
Manual for IBM KVM 41Y9310 - IBM 41Y9310 0x1x8 Ip Console Kvm 8-Ports Switch W/Rails P/N: 41Y9310 -
How to reset to default password of kvm 17353lx
Connect to the console via COM port at 9600 bits. You can change your password to update the firmware, and other features including reset settings to their factory
Apr 27, 2012 | IBM Computers & Internet
Not powering on
check your power cable low power could efect the proformance. try changing it to a more powerful power cord or a different power outlet
Nov 07, 2009 | IBM NetBAY 09N4291 8-port KVM Switch
Keybrd quits working on laptop after ctl-alt_del to reach login
Repeating keys? This is a common problem for KVM switches if you go beyond the devices' capability. As you can see, GCS62 is a PS/2 KVM switch and it was designed to work only using a regular PS/2 keyboard.
This KVM switch does not support PS/2 to USB adapter. It might work but it's not guaranteed to work correctly. This does not work properly if you have a docking station for the laptop. It might work for couple of months then it would stop.
You smay isolate the problem by following the steps below:
1. Connect the keyboard directly to the computer to see if you will get the same problem.
2. Power cycle the KVM switch by disconnecting it from the computers and leave it unplugged for a minute or two.
3. Avoid using hybrid connection (PS/2 converted to USB) only for testing purposes.
4. If that work, then you know the answer is that this KVM only designed an work correctly with native PS/2 connection.
Feb 22, 2009 | IOGear MiniView GCS62 2-port KVM Switch
No itv2
can anybody tell me how to get the starview box3 codes and downloads thanks
Feb 01, 2009 | IBM (17352LX) 16-port KVM Switch
Reset the password to default on an edimax ek16ro Need to reset the password on the KVM,
According to the user manual, the device needs to be sent in. The user manual can be found at:
http://www.edimax.com/images/Image/manual/KVM/EK-08-16RO/EK-08_16RO_M.pdf
  • Note: If you are not familiar with the operation of OSD menu, please don’t change the password – i.e. keep default eight zero (00000000) value.
  • Otherwise, if you have set the password and unfortunately forget the password, you need send it back to your distributor for resetting the password.
Jan 27, 2009 | IBM NetBAY 09N4291 8-port KVM Switch
KVM Switch 4110 8 port
so is the KVM (control side, PS2 mouse / kbd>??)
or are all PS2 ports wired to adaptors,? i cant guess this nor what was used before, no history stated.
what was there before, this act?
and what now?
Ill assume worse cases (tossed a coin)
18 (16+2) adapters now. all devices are USB but KVM
ok.?
what mode fails, both the KVM pushbotton switch and or the hot key commands on the kbd?
Oops no manual button as seen on modern KVM.
KVMs are very complex. the hard part is the vast number of different PC.
USB , PS2, VGA, DVI and HDMI.. yah,..
OK 16 +2=18 x ps2, and 9 VGA ports. it is.
NO KVM does it all, ,, old KVM' do NOT work , on new computers, all folks know this , if they tried. or took readings to learn why it fails.
I bet power to the KVM is dead., no LED./
no manual button ,oops.
pin 4 PS2 reads 5vdc and connected up, same?
we use breakout boxes (DIY) to test ports connected.'
that Compaq is very old and no support now, no books.
why not ask at real HP, maybe some old guy there can dig it lost books>
40 KVM? that what you said, really? (or 40/8=5 kvm)?
my guess is the adaptor does not work or power issues
KVM >>PS2>>>ADapt>>> USB.(server) (usb 1,2,or 3 at server?)
The KVM in most cases, here, steals power from PS2 ports but not this KVM , its better.
i'd bet that adaptor cant do that.
(is the caps lock key working on the KBD and laser LED glowing on said mouse?
ask here, real HP.
lets see tests:
1: pin 4 ps2 5vdc?
2: mouse glows?
3: keyboard led , caps lock toggles? (glows)
4: lost the hot key commands (y/n)
one other problem is the BIOS in the server may not like your adaptor at all. When BIOS scans the keyboard. it expects a ID response if missing or grabled, it drops that device port.
https://h30434.www3.hp.com/
btw, one way to cure this, is run headless server software
end KVM for ever.
i run a LAMP server, that comes in the box, no kvm no any thing on ports. it has a web page to go to and do service that way.
port IP+:12321
modern ways work best.
in a server farm, a keyboard/mouse/monitor on rolling cart
for the super sick servers is best...
the other problem is USB only PC or server
does not scan PS2 ports, it has none
so if the adaption fails, at boot time, all is lost.
(BIOS reports connected devices to the OS)(unstated by you)so if the report fails, problems happen
for sure after the boot.
this device is s business device, now ("Enterprise)
the posts on it are like 10 years ago. all links to books now dead.
infact the compaq server that had them is turned off. (grin)
here is my search there. Why not ask them?
https://www.hpe.com/us/en/search-results.html?client=&qt=kvm+4110&search=%EF%98%90&cc=us&charset=utf-8&hpa=http%3A%2F%2Fwww8.hp.com%2Fus%2Fen%2Fhpe%2Fcontact%2Fcontact.html&hpn=Home&hpr=http%3A%2F%2Fh41131.www4.hp.com%2Fus%2Fen&hps=Home&lang=en&qp=url%3Ah41131.www4.hp.com%2Fus%2Fen+url%3ANEW+URL+GOES+HERE
Aug 26, 2017 | Compaq 242695-001 8-port KVM Switch
Cannot switch between PC's
That unit mention above is a Mountable Dual Output VGA to UXGA Distribution Amplifier with Audio not a KVM Switch.
Apr 07, 2008 | Extron Electronics Extron P/2 DA2 MT...
KVM switch control
APEX switches are manufacturer by Avocent and rebranded by Dell, HP/Compaq, IBM, etc.
The keystrokes should be CTRL-CTRL (Hit control 2 times). Some Avocent switches also use ALT-ALT or SCROLL-SCROLL.
Jan 12, 2008 | IBM NetBAY 09N4290 4-port KVM Switch
IBM 41Y9310 0x1x8 Ip Console Kvm 8-Ports Switch W/Rails P/N: 41Y9310 - Logo
162 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
