Question about Febi 1963 - 1966 Mercedes-Benz 230SL Power Steering Fluid W0133-16364
What kind of power steering fluid does a 66 mercedes 230sl take
What type of power steering fluid does a 2008 GL 450 Mercedes take
there are different types for different cars.. call and ask a dealership service department or auto zone might be able to look it up for you.
Oct 08, 2014 | Febi 2009 - 2011 Mercedes-Benz G550 Power...
Mercedes a class steering fluid
Mercedes has a Special Power Steering Fluid but a General Power Steering fluid worked without an issue with MY Mercedes... The NEW CARS are more fickle, Older ones will take everything including Transmission fluid but It does damage to the Seals..
Use General Power Steering Fluid and you will be fine
Apr 06, 2013 | Car Audio & Video
Type of oil in mercedes sl power steering
In the back of your owners manual they list approved fluids or approved fluid types. Mercedes has more up to date lists on the websites. Yours should be a Dexron II type but verify with your manual or dealer (call parts department and ask, they will tell you but service manager won't have a clue). You have to double check as the 90's were transitional where they went from the older style fluids to full synthetics in everything.
Mar 10, 2013 | 1995 Mercedes-Benz SL-Class
Power steering fluid
steering hose my need to be replaced you can try tighten connectors but not sure if that will work
Dec 20, 2012 | Suspension & Steering for Mercedes-Benz...
Hi Mercedes convertible fluid is compatible with BMW?
Are you talking about power steering fluid?Power steering fluid is usually compatible between models.We always use Agip Power steering fluid for both Merc and BMW and we've never had an issue with using this oil.
Nov 14, 2012 | Cars & Trucks
What kind of trans fluid do i use for a 2001 merceds benz slk 320
this is the part no of power steering fluid,
0019892403you can get it from
www.autohouseAZ online shopping,
Nov 12, 2010 | 2002 Mercedes-Benz SLK-Class
Location of the brake fluid input
the brake fluid resivoir is above the master cylinder on the firewall. so on the left side near the windshield. the power steering resivoir is closer to the front end and is distinguished by not being connected to the master cylinder..
Feb 08, 2010 | 1987 Mercedes-Benz 300-Class
What transmission fluid can I use in my 1993 Mercedes Benz 190E
AF3 onepx.gif DEXRON®-III Automatic Transmission Fluid
BMW: Power steering use AF3; Models with combined power steering,
hydraulic brake booster, self-leveling suspension system use SLF
Mercedes-Benz: Use only manufacturer approved fluid
Look on the back of the bottle of fluid you are looking to buy, if it does not say is is approved by MB, don't use it.
Mar 14, 2009 | 1993 Mercedes-Benz 190
STP POWER STEERING fluid is good. Don't put transmission fluid for power steering !
Jul 01, 2008 | 2004 Mercedes-Benz SL-Class
Febi 1963 - 1966 Mercedes-Benz 230SL Power Steering Fluid W0133-16364 Logo
14 people viewed this question
Top Febi GPS Experts
Are you a Febi GPS Expert? Answer questions, earn points and help others
