Question about Garden
Karcher 550c keeps tripping electric and making a bang
3 Suggested Answers
  • 92 Answers
SOURCE: Karcher electric press. wash. Hums when turned on then trips bre
Dear K_mccurdy,
I am assuming that your washer is single phase. A comon reason for humming is a faulty capacitor. This must be changed by a new one.
Now one must see why the capacitor got damaged. This could happen, when the gun is closed the machine starts and goes off again in short intervals. In this case a control valve, often called the Spill Valve, needs lubrication or replacement. I prefer to replace it. Even if the pump has no faults and you have a habbit of closing and opening the gun more than necessary...the capacitor will get damaged. It is also important that if you use soap or chemicals, always rinse with fresh water before storing away the washer. Also never store the washer with pressure still built up. Always release the gun, before storing. Well in your case it must be the capacitor. If the capacitor is OK or you have changed it....try the washer without load. This can be done by removing the gun. You can leave the water supply, for this has a cooling effect during this test. Things should work fine now. If not...then the electric motor must be checked. But I repeat...the most common fault for humming is a faulty capacitor.
Regards,
Fulltech.
Posted on May 07, 2009
  • 68 Answers
SOURCE: I have a karcher power washer electric.
This could well be just needing a new motor capacitor as this helps the motor to start.
Posted on Jun 24, 2010
Karcher k3-91m electrical box
There is a strong possibility of a defective switch.
Aug 12, 2016 | Karcher Garden
My Karcher MX720 pressure cleaner keeps tripping the mains power.
Jeff, the specs say it is 230 volt, 16 amp minimum, start up would be more, probably minimum 20 amp.or larger, check your manual. Are you using a small gage/ low capacity extension cord this could blow a breaker or may have an internal short have checked by a Karcher repair center. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Any idea why my new 13 amp pressure washer is tripping 15 amp circuit...
http://www.garagejournal.com/forum/showthread.php?t=203916
http://www.electriciansforums.co.uk/electrical-forum-general-electrical-forum/54098-problem-pressure-washer.html
Jun 17, 2016 | Karcher Garden
When turn on power fuse/breaker trips on power up
try to free the motor by turning it somehoe if its free replace running capacitor
Aug 16, 2013 | Karcher 1750 psi Electric Pressure Washer
When I pull the trigger on handle the breaker in the house trips.
if the breaker in the house does not trip with any other appliance connected to it ie another electric motor say a pool pump or electric motor from a circular saw and does not trip
then it sounds like your blaster has a electric phase to earth short circuit
it will be pulling a very large current
i suggest you take it to your local electrical repair shop to check this out
cheers pauly46
Apr 09, 2011 | Karcher K3.68MR Electric Pressure Washer
Re - karcher 330
Overload contition in circuit. Turn some stuff OFF.
Jul 21, 2009 | Karcher K2.26 Electric Power Washer
The gfci on cord keeps tripping
GFCI's trip because theire is current leaking to ground. This often can be be caused simply by electrical components getting wet.
Or, it can be caused by a serious short to ground.
Fist, check to see if the inside circuits are getting wet from an internal leak. If so, fix leak, dry off components with a har dryer, try again.
If GFCI trips, it should be serviced by an experienced appliance repair person.
May 13, 2009 | Karcher K2.26 Electric Power Washer
Beko wma 1510s keeps tripping eletric sockets
I once had a machine that would trip the power if it had an unbalanced load when it went to spin. Whirrr.... bang bang bang bang... click! Lights out.
HOWEVER, this is highly unusual. If the machine is tripping the power then you should take great care. either you have an electrical fault (The motor may be failing and burning out, or another component may be failing unsafe) or you may have a water leak from a defective hose somewhere that is getting electrical equipment wet. Just remember that water and electricity are a very un-funny mix and your trips are there for a good reason.
Does the machine trip the power as soon as it is powered on, even after standing for days (Probably an electrical fault)? Does it trip as a particular thing happens, such as moments after the water coming into the machine or as the drum starts to agitate or the spin cycle starts or as the water empties.
Here are a few suggestions. Having thought about when the fault trips the power, do the following:
TURN OFF THE POWER AND UNPLUG THE MACHINE FROM THE WALL. Isolate the water supply. Make sure that the machine is drained of water. Now it's safe, look for water leaks.
Take the top off the machine (Usually a couple of screws in the back and then the lid will tap forward or pull back depending on the model). Look for signs of water inside the chassis, where the water pipes run from the inlet valve to the soap tray. The rubber gasket around the door may also be cracked and leaking. A classic point for the start of a leak is the rear bearing of the drum (This is the centre of the big wheel of the drum), you may see water marks or limescale buildup that has dripped from the bearing if it is leaking.
If you are looking underneath for leaks, never tip the machine all the way onto its back, you may cause a water leak inside the machine. ALWAYS tip BACKWARDS, so the control panel for the machine is pointing up to avoid water getting to the control panel. I would recommend putting a chair behind the machine as you tip it, so the top back of the machine comes to rest on the seat and the machine is at about 45 degrees. this will give you access to underneath without a leak and make is a lot easier to tip it back on to its feet again afterwards.
While the machine is on its back, look at the motor, If you can, have a good sniff at it (Do you smell burned electrical equipment?) Look around for other components such as printed circuit boards, visually inspect and sniff them too.
The golden rule here is if you can see a leak and you can replace the part, then that's great, go ahead and Do It Yourself. BUT be sure that when you have finished everything is absolutely dry inside (Use a hairdryer if needs be). When you are absolutely sure it is all safe then prepare to test. With everything connected up turn on the mains and start the machine. ONLY TOUCH THE PLASTICS until you are sure it is working exactly as it should. Even then you should of course check to ensure that there is no electrical power leakage. If in doubt, it the power trips, if you have the slightest concern, get a professional in, Your family will prefer to pay for his visit rather than your funeral.
Feb 01, 2009 | Electrolux EW1000i Front Load Washer
The electric keeps tripping in my house, why is this?
it is something that is being pluged in or a short in 1 of the plugs on that circut
Dec 15, 2008 | Dewalt DW824 5" Electric Angle Grinder
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
