Question about Weber Summit S-670 Gas Grill
How does the gas gauge indicator hook up? Mine always says empty.
My gmc envoy gas gauge always reads empty
I think its time to change your sending unit in the tank,not sending a signal to the gauge
Feb 09, 2013 | Cars & Trucks
How do I use the gas gauge on my genesis grill?
If it's like mine, you literally hang the propane tank on a hook. The gauge is basically a spring and as the propane is used and lightens the tank, the spring contracts.
May 02, 2012 | Weber Genesis E-310 Gas Grill
2003 chevy malibu gas gauge always on empty, replaced the fuel pump
Need to replace the sensor inside the gas tank. I have a 2008 Malibu with the same problem. It was a faulty fuel gauge sensor.
Jan 31, 2012 | 2003 Chevrolet Malibu
My gas gauge is always on "empty." Even after I
Fuel level sending unit. that is the most common problem with these vehicles that cause the gauge to quit working
Jun 03, 2011 | 1992 Ford Taurus
MY GAS GAGE ON MY XJ6 95 JAGUAR IS ALWAYS ON EMPTY, I CAN NEVER NHOW HOW MUCH GAS I HAVE, PLEASE HELP ME FIGURE IT OUT.
Either it is a bad gauge, or more than likely the sensor in you tank is faulty. If you take it to a shop they can hook to it and let you know.
May 02, 2011 | 1995 Jaguar XJ6
My 1969 chevelle's gas gauge is stuck pass full.bad gauge or sending unit? how to tell?
According to what I read, test the gauge first. Hook power to where the white wire attaches. Hook a ground to the black wire connector. The gauge should rise to full. (May take a while). When on full, the tan wire connector to same ground. It should go to empty. If both work, gauge is good. To test sender, in the empty position, your ohm meter should read 0-2. 1/2 tank should read about 40, and full should read 84-88 ohms.
May 17, 2010 | Cars & Trucks
Gas gauge always shows above full with key on . key off goes to empty.
there is a short in the wire going from the gauge to the tank. ck the wiring under the truck from the tank going forward, and ck if anything looks like its rubbing on the wiring harness.
Sep 23, 2009 | 1991 Jeep Wrangler
Gas gauge shows empty after filling gas tank. Eventually the gas gauge will register the proper level.
The gauge circuit is shunted on most cars, this is wierd, but needed to stabilize the readings... Your description sounds like normal function. Drivers would complain if the qauge were to be instant, going around corners, starting, stopping, all move fuel, and the gauge would indicate this, cauing driver alarm...Been this way for ever, although yours sounds like it is on the far side of the scale...if it reads correctly after a while, you could replace everything and you would have the same performance.
Sep 05, 2009 | 2005 Buick Terraza
Weber Summit S-670 Gas Grill Logo
70 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
